Question about Leupold RCX-1 Trail Camera System Kit
Leupold RCX-1 not taking night pictures
The camera was working great for 4 nights and now the infrared flash will not work and we get a bunch of black photos. How do I fix this?
  • andrewzobava
    andrewzobava Jan 10, 2013
    I suspect that since the moon was at crescent, there was not enough ambient light to work with the flash to take a night time picture. Same goes with night vision goggles. There has to be some small light source for them to work effectively.
What setting is best for taking pictures at night(?)
IR/ night vision, Black and white also seem to work good most of the time too. Just keep playing around until you find one that suites your needs. Happy refraction !!!!.
Apr 03, 2015 | Vivitar ViviCam 5385 Digital Camera
Vm321 infrared leds stoped working
it might be cause of open infrared diode or shorted
Nov 28, 2014 | Vtech VM321 Video Baby Monitor 1 Camera...
I have the swann 8 channel platinum cctv camera system and whilst it works with amazing quality during the day, the night vision is almost non-existant, it won't trigger cameras and is very dark on sc
Nearly all cameras work well in the day. Night vision depends on the type of camera and the technology it is using. For example a CMOS based camera will provide a very poor quality picture in the dark. A CCD Super HAD CCD II will provide a good picture with 0.01 illumination and a EXVie HAD CCD II will provide an even better picture with lux of 0.001. You really need to look at the specifications of the camera before you buy and not go with the "Platinum" or hype keywords used by the manufacturer. I have seen a lot of SWAN Cameras which are basically useless at night.
Aug 21, 2014 | Swann Communications Home Security
Cameras flashing between infrared (night) and NO SIGNAL - 1 is off (4 total)
Sounds like you have a power supply problem in the DVR, get your installer to check it
Jul 30, 2014 | DMCOM Zmodo Pkd-dk4216-500gb Complete 4...
No night pictures
You cant see infrared flash, but it is not working. The only way to check this is with special equipment. If the unit is new, send it back.
Nov 18, 2013 | Moultrie Game Spy M80XT
My leupold rcx-1 trail camera will not read the SD card and will not take pictures.
I own 5 of their cameras...what I have to do to get mine to read the sd card is anytime you plug in your controller to the cam start by going to set up camera every time. you don't have to do anything in set up camera just go in and back out and it reads the card. don't get me wrong I have had a lot of problems with them ( I have to use the quarter trick on 2 of them) and have had some other issues but when they work they do pretty good.
Aug 22, 2013 | Leupold 112201 RCX-1 TRAIL CAMERA KIT
Bushnell Trophy Cam -Infrared Not Working
I have the same problem. I had the first camera relaced under warranty, but still have the same problem with the replacment.
May 14, 2010 | Bushnell Trophy Cam with Text LCD
Camera takes pictures at night but pictures are black it appears that the flash is not working
My Moultrie Came Camera takes pictures at night but they are just black, flash doesn't seem to be working, once in a while it will work, shows 18 pictures taken, only one came out. Batteries are showing 70%.
Dec 19, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moutlrie I-40 IR flash doesn't seem to work
error 020000 relates to flash/flash charging...if new, take it back.I have repaired several by replacing the IR LED flash...easier fix than the incandescent units.
Nov 09, 2008 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Night problems
have you tried it with the led flash mode
Sep 23, 2008 | Bushnell 11-9900 Camcorder
Leupold RCX-1 Trail Camera System Kit Logo
21 people viewed this question
Top Leupold Computers & Internet Experts
David Payne
David Payne
Are you a Leupold Computer and Internet Expert? Answer questions, earn points and help others
