Question about Lexmark X5150 All-In-One InkJet Printer
We reciently bought new ink cartriges and now when we try to print nothing is printed. There are no error messages on anything either....the paper just comes out blank. We also tried changing the ink cartriges and still the same problem happened.
  • 3 more comments
  • Jenny89 Jan 21, 2009
    We have the exact same problem with no soloution.
  • herm8501 Jan 21, 2009
    yes, i removed the protective tapes. And I just double checked that.
  • rpoezina Jan 21, 2009
    i have the same provlem. I changed 2 times the ink cartige but nothing
  • aawolters Jan 24, 2009
    We're having the same problem. We've tried to fix it with whatever we can think of, and still nothing!
  • Derek Fuller
    Derek Fuller May 11, 2010
    You did remove the protective tapes from the cartridges before fitting them?
  • 24 Answers
Try reseating both ends of the printer cable.
Assure that there is nothing in the cartridge carriage to block the contacts and/or cause a seating issue.
Jidza
Posted on Jan 23, 2009
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
All 8 new ink cartridges, new MT tank, nothing prints. it goes thru the motions of rinting, but no little to no ink is on paper, less and less ink each subsequent print. Most recent print has a hint of...
take your ink cartridge out from your printer. you can see at the ink carriage there are little pipes where the ink usually flow from cartridge. If head cleaning and power cleaning does not work, then try to clean those pipes by using 96% alcohol fluids and **** the pipes using something.
Sep 12, 2009 | Epson Stylus Pro 4800 InkJet Printer
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Nothing prints on the paper when I print. I have brand new printer cathridges and still same problem.
Make sure you pull the CLEAR Plastic Protective tab off the bottom of the cartriges.
Also check the front of these print cartriges to be sure that they are the same type as the old ones.
Unplug the printer, reconnect and try again.....
and try printing something of a different format
also after it starts working (it will) run your test sheet/setup for the printer.
Apr 19, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Ink cartrige error(epson 9800)
I would try getting new EPSON brand cartridges for it and trying after that ...
Jan 19, 2009 | Epson Stylus Pro 9800 InkJet Printer
Installing ink cartridge
I've had this problem too. The only way to make the message go away is to buy the ink from Dell. Although generic ink cartriges will work the printer will not/can not reset the "low ink" message unless you buy the cartriges directly from Dell. So you can use another brand, but you'll just have to overide the low ink message when it pops up by telling it to continue printing. Then you can tell when the ink is low by seeing it when it prints out.
Sep 10, 2008 | Dell 924 All-in-One InkJet Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Black ink not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 09, 2007 | Brother DCP-340CW All-In-One InkJet...
Lexmark X5150 All-In-One InkJet Printer Logo
60 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
