Tv cuts off as soon as i cut it on and the standby/temp light and the lamp light keeps blinking
    Problem Solver:
  • 11 Answers
Buy new tv
Posted on Jan 12, 2013
  • 4 Answers
SOURCE: picture and sound cuts off ,greem stb light keeps blinking
I had this problem and ordered a new replacement XL2200 lamp from Sony and that fixed it. By the way, the lamp installs from the front so there's no need to pull your TV out from the wall. Look at you manual, it is accurate in this respect. My lamp only lasted about 15 months. It costs $200 plus about $16 to ship. ou can order direct from Sony on line service.
Tom
Posted on Feb 27, 2008
  • 453 Answers
SOURCE: getting to my tv to come on
need new lamp
Posted on May 02, 2008
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Posted on Oct 21, 2008
  • 21 Answers
SOURCE: the red lights are blinking under lamp and temp.
did you try setting the lamp over the red light on the tv?
Posted on Jul 14, 2009
welcomejee
  • 10594 Answers
SOURCE: standby lamp keeps on flashing.
Seems its time to replace lamp in your Sony KDF-E50A10
When lamp in TV got weak in result, standby light start blinking and if lamp got broken / dead, you will see lamp light ON.
Lamp replacement procedure is easy and written in user manual, please buy Sony original lamp for TV safety.
Thanks.
Posted on Jul 30, 2009
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions:
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
My standby/temp light is blinking and my lamp light is blinking. tv is about two years old. Just started happening out of the blue. It will come on for a few minutes. I have three dogs and it gets dusty...
check the lamp if you havent changed it before that would be the easiest place to start. if the lamp is popped you will see glass pieces rolling around in the lamp.
Dec 22, 2010 | Samsung HL72A650 Television
My Samsung Dlp model hlt5075s was working great with great picture for last 2 years. This afternoon I went to cut it on and it the three lights on the bottom right started blinking(standby, time, and...
The projection lamp life is over.2 years has not been replace projection lamp,tv on daily watches like 4 or 5 hours a day?u need to replaced the projection lamp.
Sep 12, 2010 | Samsung HLT-5075S Television
Sony sxrd --cuts off after a few seconds then cut itself back on.
Symptom shows lamp is weak and requires replacement.
Please buy Sony original lamp for TV safety and good picture result.
May 31, 2009 | Sony Televison & Video
Tv will not stay on
If the lamp light is not on, then the TV is flashing because of overheating or because of a fault.
Try first unplugging the TV and leaving it unplugged overnight, this will drain power completely and may solve some problem.
If the TV keeps having a problem, then there is a fault.
Many units have more than one fan (one for lamp, one on ballast, one on board). In that case ensure that all fans are working.
If the problem is not a fan, then parts can cause the problem are ballast board and DMD board.
In that case the parts must be tested before replacement.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here, a common fault is PSU, but part must be tested before replacement.
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts.
May 16, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Live Chat Session
i have 3 lights blinking on my samsung dlp...the lamp light flashes a few times then timer and standby/temp flash....can any1 help
Jan 01, 2009 | Samsung DLP HL-P5663W 56" TV
TV and Vedio-Projection televisions
what i would do is crack into the tv and watch the individual parts being careful not to unplug anything while you take the back panel off.....turn it on and see what happens. let me know what happens
Sep 30, 2008 | Televison & Video
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
