Question about Dell Precision M60 Notebook
Whats the specific drivers for wireless lan for dell precision m 60
I want to download wifi drivers for dell pecision m60 but there are many drivers to download which is most important to download
  • 61 Answers
Check which wireless lan is in your computer by using device manager in control panel - system - device manager, then go to dell.com support, enter your serial number or service tag number from label underneath and look for updated driver for your specific wireless lan
Posted on Jan 08, 2013
  • 90 Answers
SOURCE: Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Posted on Apr 20, 2009
  • 3940 Answers
SOURCE: how to remove the cmos battery on a dell precision
Here is the link to removing the reserve battery. http://support.dell.com/support/edocs/systems/wsM60/SM_En/reserve.htm#1123661
However, if you are trying to bypass a BIOS or HDD password removing the battery will have no effect. Those can only be removed by tech support or a hardware replacement.
Posted on Dec 05, 2009
SOURCE: Dell XPS M1210 -- wireless not working and other devices
where i can get driver network conrtoller for my dell inspiron1000
Posted on Jan 17, 2010
  • 97 Answers
SOURCE: dell precision m60 press the power button the
You could have a bad peice of memory or a bad memory slot. Pull the memory out and try one peice at a time in each of the two slots. If you only have 1 peice you will need to either borrow a peice of the same memory or buy it. You also could have a shorted battery so pull the battery out if the ram is ok and try to boot. Another idea is the cd rom may have a problem so pull it if the ram and battery are ok. After doing all this if the system will still not boot the motherboard must have a short and needs replacement. This model also had an issue with the power board where the power button is. The connector on the motherboard was poorly designed and very sloppy. Over time it gets worn and causes a similar issue. The temporary cure is to press very hard on the power button to see if it will boot and then leave it running. You can also put pressure on the underneath side around the docking port and press the power button. This issue however requires a new motherboard. The M60 is almost the same as the D800 infact most parts are interchangeable. You could switch out the motherboard to a D800. I refurbish the D600 AND D800'S daily so I am fimilar to this issue. Let me know how you make out. Phil pmgibs1@verizon.net
Posted on Feb 23, 2010
What windows 7 ultimate drivers do i need for it to work with pecision workstation 670
You will need audio driver, possibly Network adapter driver and in some cases you may need to find the manufacturer of your optical drive by pulling out of the case to get model type and then the the driver from the manufacturer's site. Finally a chipset driver. check this site for most of the drivers.
http://www.dell.com/support/drivers/us/en/19/product/precision-670
Apr 23, 2014 | Dell Precision Workstation 670 PC Desktop
Sound driver
If the sound driver you're after is for the XP version then here it is, BUT if later version such as Vista, 7 or 8 then I can't help you. http://www.dell.com/support/troubleshooting/us/en/19/Product/precision-m60
May 03, 2013 | Dell Precision M60 Notebook
DELL PRECISION M 60 HOW DO I GET WIFI TO WORK
Whoever you have internet service with should help you get it up and running. Just contact their Customer Service line.
Oct 30, 2012 | Dell Precision M60 Notebook
I have upgraded my Dell Precision M60 to Windows7 OS. audio glitches during play back. how do i solve this issue.
well download the driver for windows 7 compatible from the dell website ....install it ....restart your system ....it will work fine...
good luck :-)
Apr 26, 2010 | Dell Precision M60 Notebook
Touchpad no longer working
go to control panel and click on devices. click mice and see if it has been disabled.
Feb 28, 2009 | Dell Precision M60 Notebook
Not detecting Wireless Adapter
Reinstall the wireless adapter driver, if need download a copy from www.dell.com use the Service Tag number (its printed on a label on the bottom of the laptop) to get the correct model laptop drivers.
Use another computer to get on the Internet.
You could use the Restore function, select a date before you installed SP2, then download the driver before you install the SP2.
Please note, you should be installing SP3 not SP2.
Jan 13, 2009 | Dell Precision M60 Notebook
Browsers/ PC
Check there is no proxy server in internet explorer
Open IE
Click Tools --> Internet options
Click Connections Tab
Click Lan Settings
Make sure "Use a proxy server for your LAN" is not checked
Check "Automatically Detect Settings"
Click OK and OK
If this doesn't work check there are no values set for IP addresses in
Start --> (Settings) --> Control Panel --> Network Connections
Right Click your Wireless Connection --> select Properties
Scroll down to TCP/IP in the centre box and Click it to select
Click properties and chose "Obtain Automatically" for both IP and DNS
Click OK OK or Close
Try Internet again
Dec 16, 2008 | Dell Precision M60 Notebook
Dell Precision M60 Notebook Logo
70 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
