Destroyj it 2205 motor turns on but doesnt turn blades
  • 3,904 Answers
There is a gear not engaging or it is worn to the point of no longer working. If that is the case it will have to be replaced.
Posted on Jan 09, 2013
Lennox XC21 (7 yrs old) compressor motor does not turn fan blades
Check the motor by hand to see if it turns freely, if it does then the issue is the motor controller not being able to sense where the motor is. Check for 240 Volts on the red wires and then check for 24 volts dc between black and blue and black and yellow.
May 27, 2016 | Heating & Cooling
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
Dose anyone have a owners manual for a true refidgerator GDM-12
The fan your referring to is the condensor fan. it should not be tight to turn. it should spin freely. if it is hard to turn, its probably stuck, which is why its not spinning. Remove grill, slide the nottom portiom out so you have access to fan, remove fan blade, and spraylubricant on fan motor (around the area that the screw that held blade). Remove hair, dirt, string, or anything else that might be prevrnting fan from spinning. sometimes its easier to burn it off. If fan still doesnt spin you may have to replace fan motor.r
Sep 26, 2012 | True GDM-12 Refrigerator Commercial
My electic chain saw works intermitently. motor goes, chain doesnt.
yes the gears can strip look at sears parts online for a break down
Mar 24, 2012 | Ryobi Garden
The A/C does not turn on when i turn the controls on. i heard a loud boom while it was running and then it stopped. It sounds like it turns on but just doesnt pump out any air. What is wrong
Hi, it sounds as though the blower/condenser fan motor has maybe hit something, the blades on the shaft if its not blowing any air. You can go outdoors to see if the condenser fan motor blade or cage is turning, as this is a dual shaft motor. Sometimes if the bearings wear, they will be out of balance and hit another part in the unit and bind up. I would check this for sure. If you have something slim but hard you can stick inside to see if the motor turns at all this would tell you that the motor is either bad or the blades have hit something and locked it up. Do this and get back to me. You can use my user name below. It may be a faulty blower motor. Please rate me and I know you will be kind. I will keep all of your information filed, so I will remember this unit and what happened. Please let me know.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 06, 2010 | Friedrich QuietMaster KM18L30 Wall/Window...
Motor works but doesnt turn spindle with blade on it
you may have (probably) put something in there that wouldn't chop or grind, and the blade wasn't able to turn. When this occurs, a safety feature called a 'shear pin' breaks. The shear pin passes through on side of the base of the blade, through the motor shaft, and out the other side of the base of the blade. The pieces of the shear pin have to be removed, and replaced with a new pin. A common roll pin of the appropriate diameter should do the trick. Bear in mind the shear pin is a 'pressed fit', so removal of the old bits may be difficult. But it can be done.
Feb 06, 2010 | Microwave Ovens
92 FORD TAURUS COOLING SYSTEM FAN NOT WORKING
Fan Relay. In the fuse box under the hood
Jun 04, 2009 | 1992 Ford Taurus
Bosch table saw model 4000
It sounds like the pinion on the armature and or gear are stripped. The only way to find out is to tilt the blade and remove the motor housing from the diaphragm and check it. If replacing the armature I would recommend also replacing the bearings and brushes as preventative
Nov 08, 2008 | Saws
Central A/C motor blade turns all the time
it is just possible that an air draft thro rhe fan blades is turning the motor. to check, disconnect the motor and see if it still turns. disconnect from mains before doing this
Mar 25, 2007 | Goodman CLT36AER36 Air Conditioner
20 people viewed this question
k24674
