Question about Whirlpool WFG231LVS Stainless Steel Gas Range
My Whirlpool standard cleaning oven keeps beeping the code FS or F5. What does this mean?
This usually happens when warming the oven. However, It did it this morning when the oven wasn't even turned on.
SOURCE: On a Whirlpool Super Capacity
What is the fix for this error message, my oven door is not locked, but the error message keeps appearing.
Posted on Feb 03, 2009
  • 333 Answers
SOURCE: I am trying to self clean my Whirlpool stove/oven.
use easy offoven cleaner. when using the self clean feature the oven gets so hot that it's likely to burn out some of the electrical components
Posted on May 20, 2010
Testimonial: "Thanks I had the same thought. Hubby tried unplugging and nothing changed. Oh well, Easy Off..is for me. =) "
heatman101
  • 43501 Answers
SOURCE: Whirlpool Self Cleaning oven error code
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Jul 18, 2010
  • 5188 Answers
SOURCE: I have a electric whirlpool self cleaning oven, after the cleaning process the door is still locked. It's beeping and error message E1 F5
Assuming the door is still locked after cooling, then either the door switch is bad or the wiring from the control panel to the door switch has a problem. First disconnect the power from the oven. Then check the wiring and connectors (from the control to the switch and back). If those are fine, you need to replace the door switch. After replacing the switch or fixing any bad wiring/connections, reconnect the oven to power. Press and hold any key on the panel for at least one minute to clear the error. You should see F2 on the LCD panel. Press Cancel to clear the error then check to see if any new error (or the old one) message occurs. (Usually a new error message will come up within a minute.)
Which model Whirlpool oven do you have? If you add a comment with the model number, I may be able to provide a parts list and diagram of the unit.
I hope this helps.
Posted on Nov 22, 2011
richroth
  • 9472 Answers
SOURCE: whirlpool gas range f5 code
F5 is a fulty display control board. Unfortunately there is nothing you can do to fix this problem but to order and replace the display control board.
Here is the board to order.
Posted on Dec 02, 2012
The F5 error code?
WHIRLPOOL
Range/Stove Oven Fault Codes, Common Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
Kenmore model 790.96113403 F5 error code
it means that your oven is showing a restart code
Jun 13, 2012 | Kenmore 99123 Electric Kitchen Range
I'm getting an E1 f5 error code and my oven won't light
The F5-E1 error code means that their is a problem with the switch on the self clean door latch...it (the switch) is telling the control board that the door is locked even though it may be open so it will not let the oven come on
GENE
Nov 14, 2011 | Whirlpool SF325 Gas Kitchen Range
Selfcleaning won't come on E1 F5 keeps flashing with a beep
Hi
Thanks for using FixYa. Error F5-E1 means that the door latch/switch has gone bad or is not operating. To resolve this issue check the door latch and replace if its not working. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 05, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning keeps popping up beeping with F5
Hello,the F5 beeping is all about the Push button stuck.
Check for the binding of Push button and control panel glass.If OK,replace the touch panel.
Thanks
Jun 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
Jun 19, 2007 | Whirlpool GBS307PR Electric Single Oven
Whirlpool WFG231LVS Stainless Steel Gas Range Logo
446 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
