Question about HP CB534A LaserJet M1522NF Multifunction Monochrome Laser Printer
Cost of upper scanning bed on HP M1522nf printer .. Does anyone know ? Out of warranty trying to decide if I should fix or just get a new one.
  • HP Master
  • 1,121 Answers
Not required to replace entire scan bed assembly, if you are facing any problem related to scan or copy.. There is a part called "optical scanner"(CCD) need to replace to resolve the issue, costing INR 3,500( in India).. You can try for it.. See the part:
Cost of upper scanning bed on HP M1522nf printer . - 1_8_2013_6_41_38_pm.jpg
Posted on Jan 08, 2013
SOURCE: Error Message HP Cue DeviceDiscovery Services - HP Laser M1522nf
Go to HP as per attach link http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-56725-2 and download the software. After extract it to another folder, and click install. Voila the printer now work like a charm.
Posted on May 02, 2009
  • 5 Answers
SOURCE: HELP
Downlaod the driv
Posted on Jul 10, 2009
SOURCE: hp M1522nf big problem
paper jum
Posted on Aug 12, 2009
  • 31 Answers
SOURCE: How do I scan a document on a HP Laserjet m1522nf...
install full software, download from www.hp.com
Posted on Aug 10, 2010
SOURCE: I had download the full software for my HP printer
moz-screenshot.pngmoz-screenshot-1.png the Error is "the software had trouble scanning or was cancelled" in HP printer 2727 MFP please advice
Posted on Jan 24, 2011
Scanner Error 5
Remove flat bed glass take out optical scanning assembly(detach flat cabl & belt).gently hold the unit & remove bannet of the unit care fully clean the reflecting glasses with ear buds gently. fix it back & clen flat bed glass both surface with glass cleaner fix every thing back,take care of finger prints not to print on glass, check if not resolved replace optical scanner assm.Note:technical skills & patiency required to do this process ..Best of luck
Oct 11, 2011 | HP LaserJet M1522nf Multifunction Printer...
Hp laserjet m1522nf 52 scanner error
Step 1.Switch on the machine observe Optical scanner assm moving forward & reverse for checking home position? remove flat bed glass,clean it especially at black band area, fix it and check..Step 2. Switch off the machine, remove power cable, remove left side door,dis connect Scanner cable(connector J4) on formatter, switch on the machine, check if same error? replace formatter assm..if different error replace optical scanner(CCD) assm..
Sep 20, 2011 | HP LaserJet M1522n MultiFunction Printer
Doc feeder jam error on HP laserjet M1522nf continuesly also due to that i am unable to scan and also its showing that "Device is busy try again later"
Open adf cover, remove adf pick up unit, two sensor located in it 1. paper leading edge sensor, located upper portion of the unit.2. paper out sensor located back side of the adf pick up unit. Carefully open this unit your will easily find out the sensor location..
Sep 13, 2011 | HP LaserJet M1522nf Multifunction Printer...
Scanner error 8 in hplj m1522nf printer
A Scanner error 8 indicates a problem with the upper scanning bed.
There is no other solution than to replace it.
This printer is still under a warranty extension until 3/23/2011for the scanner and formatter boards that should be replaced at the same time.
Contact Hewlett Packard Technical support.
Jan 14, 2011 | Office Equipment & Supplies
On my hp lasserjet M1522nf when it is turning on the exclamation mark is blink and the screen saids "scanner error 5 turn off then on", the printer is out of warranty, can i fix it or maybe i haver to buy...
This is an official known issue by HP. Call HP Tech Support (800 334 5144 )and claim your warranty. Good customer service! The warranty has been extended for products presenting this issue!!!
Jun 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
It will not initialise,frozen,will not start
There is a problem with a circuit board it will need to be replaced. HP will have you unplug it and hold down the up arrow and cancel key at the same time while holding down the keys you will need to plug back in and turn power switch on hold down keys until you get a message let go of arrow key and cancel key let initialize . If you purchased a HP warranty it will cost you nothing to have HP send you a new or refurbished printer. If you have no warranty it will cost you around $69.00 plus tax? for shipping. That is one option the 2nd option is to take to the nearest service center which HP will let you know the closest to you charge should be free.The 3rd option is to box it up and sent it to HP you will pay for shipping and HP will pay return shipping. Please note this is a known problem.
Feb 16, 2010 | HP LaserJet M1522nf Multifunction Printer...
How can I scan with the HP Laserjet M1522nf?
Try rerunning the installation disc, you will find and option that reads "install more software, install this a restart your computer
May 01, 2009 | HP LaserJet M1522nf Multifunction Printer...
Scanner crisis
I searched HP.com but they don't have anything like this on their Customer Care site (or I don't know how to search for it successfully). I'm going to take a stab at it anyway, but it's just a guess. It sounds like a mechanical problem, with the scanning arm not moving all the way across the scanning bed.
The white area of your graphic probably describes the area where the scanning arm moves. I know the light is bright, but have you tried running a scan with the lid up, so you can see how far the scan actually moves?
Assuming this is the correct problem, your only option would be to have the device serviced so the fault can be repaired. If it's under warranty, that should work out OK. If not, you have to balance the cost of a repair against replacing the entire All-in-One unit.
Good luck.
Aug 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Scanner failure
You can copy, but not scan or fax from the flatbed...
You can copy, but not scan or fax from the feeder...
Am I reading this correctly?
Oct 18, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP CB534A LaserJet M1522NF Multifunction Monochrome Laser Printer Logo
69 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
