Picture problems on my LCD logik tv (plus listen for the sound at the end ) or it could just be the tv speakers lol
  • 691 Answers
Sounds like a capacitor has given up the ghost. If you can do a bit of soldering and aren't scared of taking it apart, then you might find a repair kit or second hand power board for less than 20. It really is a cheap option. If you can't and don't know anyone that can I would get a new TV. As a repair guy will cost you at least 50 and you don't know how long the rest of it will last. People will buy these TV's on ebay to repair so you can get some money back.
Posted on Jan 08, 2013
  • 304 Answers
SOURCE: 46" Samsung LCD, no sound output whatsoever
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
Posted on Jul 16, 2009
SOURCE: No sound on my Samsung 2333 LCD TV
use the menu setup and tell it how u want it to be configured and make sure tv speakers are on if u are using the tv, if not use the computer settings on the menu, u probaly already have found this out, by looking fully at the onscreen menu.
Posted on Dec 01, 2009
  • 1027 Answers
SOURCE: sound but no picture
Most likely - the CCFL backlight is not getting the power it needs to come on. You can verify by shining a light on the front surface of the set - if you can just make out a dim image, then that is it. On some sets, the CCFL can be seen through the vents on the rear.
Posted on Jun 19, 2008
  • 13 Answers
SOURCE: my logik lcx27wn2 tv has sound but no picture
I know not of this specific model, but it is not uncommon for ribbon cables to become loose or dirty. It is usually pretty easy to pull a tv apart just remember where all screws and cables came from, and then reconnect them and power up before putting it back together, in case there is anything amiss. Ribbon cables can be easily rubbed clean with an eraser. or alcohol and Q-tip
Posted on Jan 31, 2010
mace1mace
  • 1138 Answers
SOURCE: my philips lcd tv has sound but no picture what is
change the backlight (cold cathode light) on your monitor.. If you are able to open the back of your lcd monitor carefully, the backlights are located at the upper and the lower part of the edge .. replace it with conventional cold cathode lights(protective tube was removed)... there are also instances that backlight was good but the ballast transformer is burnt. Replace the ballast. Its very cheap to replace that.
Posted on May 18, 2010
Turned on, has sound but no picture. Why?
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little ... +ducksfans76 have you done the flashlight test? what that is is turn the tv on in a ... screen that means your backlight is out and with LCD tv's most likely is the inverter. ... Samsung Flat Screen No Picture Only Sound 002 - Duration: 1:26.
Repair A TV With Sound But No Picture - YouTube
? 2:30
https://www.youtube.com/watch?v=MQj2t4nNVYc
Sep 18, 2012 - Uploaded by MonkeySee
Learn how to troubleshoot your television if you've got sound but no picture. ... I have a logik lcd tv and for some reason thescreen always turns ...
Dec 25, 2015 | Sanyo Televison & Video
Code for logik l22fed tv
I have a logik 22'' HD model no L22fedc the sound works but have no picture can anyone help
Jun 15, 2013 | Televison & Video
I have a logik LCD hd ready television and when I turn it on it clicks then the screen just stays blank but I can hear it just no picture any suggestions? Thanks
If you can listen to the sound of the program, try showing a flashlight on the screen from a safe distance. If you can see the picture, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 22, 2012 | Televison & Video
I have a 22" Logik
The problem is related to the section which processes the video/picture information in the TV. Most likely an IC or its surrounding components.
Try consulting TV repair technician.
All the best
Rjn
Sep 20, 2011 | Televison & Video
Hi i have a krf-v5030d and i am having trouble woking out how to connect it to my panasonic 37'' plasma th37px70b and my sky plus box can you help me please .thanks john
Hi John,
I have the same amplifier, a Sky + HD box, an LCD TV an surround speakers. We wont go into the Wii, PS3 and PC also hooked up. Essentially the best way to go (whatever you connect up) is to split the video and audio signals.
Sky: The Sky box has an audio outputs (left and right channel) found at the back of the box. You get some twin audio cables, plug into the back of the Sky box and the other end into the Kenwood Amp (for example we use Video 1). This means that the sound from Sky can be found on Video 1 on the Amp.
You take the video signal (picture) from Sky using a SCART cable and put into the back of your panasonic TV. This does mean that you can watch a picture without the sound and listen without a picture. The Amp remote controls the sound, the Sky / TV remote controls the picture.
You may need to tinker with some settings on the Amp, for example on the front of the Amp you will find a source button, toggle through the 3 or 4 options to give you the right sound. But essentially that should be it. The same process is used for any other things you want to add, like a DVD player, a games console and so on.
Hope this helps.
Regards, Mohammed
Oct 05, 2009 | Kenwood Audio Players & Recorders
Connected pc to logik 32in lcd tv, getting picture but no sound
Need clarification. Do you have speakers hooked up to your computer? Or did you just plug in a VGA cable from your computer to the TV? The sound can't magically go from your computer to the TV, because VGA cables don't transmit sound. So if you are indeed using speakers, which I doubt, it's a computer problem.
Basically, describe exactly what components you have and how they are hooked up.
Jun 27, 2009 | Compaq Presario SR1010NX (DW254A#ABA) PC...
Sound problem
check the menu on the tv to see if the speakers are set to off
I think if you connect it to external amp the tv's speakers must be shut off beofre it will activate the line out audio
Nov 05, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Picture but no sound on Hyvision LCD monitor MV190
I had the same problem. The speakers are mounted below the the LCD Monitor. There is no internal connection between the speakers and the TV Audio. There should have been a short patch cord in your box having one jack on one end and two wires with mono jacks on the other. Plug the stereo jack into the audio out on the monitor and then plug the other jacks into the left and right side of the speakers (the wires should be marked L and R). If you cannot find the jack, I'm sure that you can find one on line or get one from Radio Shack.
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
