How do I stop my intertherm furnace model # MGH065ab fan from making so much noise?
Our fan on the furnace sounds like a jet taking off. how can I quite it?
SOURCE: furnace fan running off and on blowing cold air
Need a little more info. Does the fan never stop? Is this a gas furnace? Is your thermostat in the fan auto not fan on position?
Posted on Dec 09, 2007
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
kf4rwe
  • 25 Answers
SOURCE: Intertherm model e3eb020h electric furnace won't start just hums
Check fuses. one may be blown, and the other one not, Therefore you are getting only 110V to a 220v circuit.
Posted on Dec 03, 2008
SOURCE: Clunk noise Ruud Furnace
I had the same problem, the motor shaft and bearings were going bad. There was about 3/16" travel on the shaft that the blower attaches to. I replaced the motor myself and it runs nice and quiet. I have had that noise that you describe for over 8 years, but it got real noisy about a week ago. I talked to the maintance department about it where I work and they said the motor bearings were probably going bad. They were right, I took the motor out of the furnace and they took it to a parts store and got me a new one $270.00 for it. It is a special motor due to the fact that the frame mounts bolt directly onto the motor housing. Make sure if you do this job yourself that you take the motor to the parts store so that they can match it up. The guy at the store told our maintance man if it didn't require the bolt holes in the motor housing it would have been $100.00 cheaper.
Posted on Dec 24, 2008
  • 659 Answers
SOURCE: intertherm propane furnace makes popping sound when running
It sounds like you have a possible hole in the heat exchanger. Turn the heat off and turn the fan on. If you feel any air coming back out of the heat exchanger, you have a hole. A yellow flame is not a good sign. I would even consider having a service professional come out and take a look.
Posted on Apr 05, 2009
Furnace won't stay lit. Intertherm Model M2RC-080A-16BN. Ignightor glows, flame starts and after a few seconds the flame shuts off. Then it starts the cycle again. It goes thru this cycle a fe
It sounds like the flame sensor is bad. If thats not the case you may need to replace the control board. You should make sure the flame sensor is directly into the flame.
Nov 20, 2014 | Intertherm Heating & Cooling
Intertherm Furnace Model #mmhb070abhr06. Burner lights up but shuts down after about 10-30 seconds then recycles over & over again when fan is set to auto (because fan does not cycle on when set to...
Sounds to me like it is going off on a weak high limit switch. With the fan on it will prolong the event but will not stop it. I would check all of the high limit switches. It would most likely be one close to the heat exchanger.
Apr 06, 2014 | Intertherm 56000 Btu Gas Furnace
Furance starts, runs short time, blower stops short time, then blower comes on, burner still runniing.
Sounds like you fan limit control is not set properly. Or the blower speed is set to high.
Jan 03, 2014 | Intertherm 56000 Btu Gas Furnace
Intertherm furnace/AC, fan on the furnace won't shut off.
How old is the intertherm. The old ones have fan limit switch and sometimes they stick. The new ones have a fan baord or time delay relay. They go bad from moisture and they just go bad sometimes. It sounds like you just have a shorted relay. If you think you can replace it you can get a relay at any parts store. Need the model number of unit. If not just call a service tech for free estimate. Russ
Jul 24, 2009 | Heating & Cooling
Intertherm propane furnace makes popping sound when running
Apr 05, 2009 | Intertherm P3RA-048K Air Conditioner
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
Furnace won't stay on
Flame sensor could be dirty. It is located right beside the last burner looks like a thick piece of wire. Take steel wool and gently clean the probe 4 or 5 strokes is all it will take to take off the carbon build up off. Lets eliminate this item and see if it clears up okay. ken
Dec 21, 2008 | Intertherm P3RA-048K Air Conditioner
Intertherm gas furnace model number m6bb070abfc01
Check for a open limit switch caused by a dirty filter or poor air flow
Dec 24, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
