Question about Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty 80 series won't stop filling with water.
I had to fix the lid sensor switch and now I'm afraid there is a fill sensor that I've messed up, but I can't find a diagram to tell me what things should look like.
  • chrissea125 Jan 21, 2009
    I think my lid switch just went as well. How did u replace it? Did you remove the lid and machine top or did you go through the back of the machine.
    Problem Solver:
  • 8 Answers
I removed the top of my washer to access the switch. I had to pull some screws out on the back and pulled the whole top forward and then up.
Posted on Jan 22, 2009
Kenmore series 80 model 110 wont stop filling!
There is a clear plastic hose that runs from the load selection switch to the side of the washer drum. This hose connects the fill sensor to the load switch. without it being in good condition and connected properly the washer won,t get a signal that it's full.
May 09, 2013 | Kenmore Washing Machines
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
Oct 19, 2012 | Kenmore Washing Machines
Kenmore 80 series washing machine will fill up with water, then nothing happens
Kenmore Ultra Fabric Care Heavy Duty 80 Series washing machine (Model # 110.92389200; Serial # CF 1122814) went through the wash cycle completely, but rinse not the rinse cycle. Motor was going but washer not spinning. Also smelled something like burnt rubber. Could the belt have gone out? Is this something that I can fix myself?
Mar 18, 2010 | Washing Machines
Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Aug 21, 2009 | Kenmore Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 series
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your model number (located around the tub opening under the lid) and look under the "Top and Cabinet" heading. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Oct 21, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series heavy duty 3 speed
This problem is generally caused by a pressure switch failure. The pressure switch controls when to shut the water inlet valve off at the appropriate level and is located behind the load level or water level selector knob on the operator console. Before assuming, however, that you have a defective switch, read the following link first:
http://www.fixya.com/support/r762094-washer_overflows
In the majority of the problems I have experienced with an overflow condition on a washer, it has been caused by the air hose coming off the pressure switch. Hopefully, this will be the case with your washer and will not require parts. I hope you find this information helpful. Let me know if you require additional assistance.
Sep 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
May 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
159 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
