Question about Microwave Ovens
Panasonic nn-sd691s microwave is very loud when operating , is that the inverter making noise , is it normal
Microwave is loud when operating , is that the inverter making the noise , is it normal
  • Microwave Ovens Master
  • 9,098 Answers
It may be a shorted high voltage diode or failed magnetron.
Posted on Jan 09, 2013
daverh
  • 117 Answers
SOURCE: Makes a loud humming noise while operating
Almost certainly, the component called the "magnetron" has died. This is the valve (tube in the US) which actually generates the microwaves. The loud humming is the transformer that supplies the magnetron being overloaded and/or the magnetron itself. If the rest of the appliance is OK and not too old, the magnetron can be replaced. If you aren't familiar with these appliances, you *must* get this done by someone who understands the dangers of messing with them - if you get it wrong, they can bite! In some countries, only qualified engineers can buy the spare parts. In the UK, the part costs around £40 - £80, depending on the model. If the appliance is more than around three years old, it may be a false economy to repair it as other parts may fail soon after the repair.
Posted on Sep 24, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: PANASONIC INVERTER MODEL NN-S76OWF
While your exact model in not available for download, you should be able to find one close enough to work here:
http://panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=2&productCategoryID=87
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 07, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Inverter Microvave (NN-T990SA) Does Not Operate at Full Power
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Dec 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Hi, I have a NN-C784MF
Chances are there are other bad parts blowing the diodes, most likely a MOSFET.
Also, the ESR of the electrolytic capacitors should be checked and all board connections must be checked and resoldered if suspect.
If you're not experienced in troubleshooting switched-mode power supplies (inverters) then you can probably save a lot of timer and money by replacing the whole inverter.
You can find the nearest spare parts supplier by selecting your country then the support links at Panasonic.net.
Posted on Jan 02, 2009
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
Panasonic microwave model NN-H275: Oven door doesn't open; Makes crackling or arcing sound when turned on;
If you do not see actual arcing in the cavity making the noise it is probably components on the inverter. Too exppensive to repair. Get a new one. Dont like or trust the inverters.
Jun 25, 2017 | Panasonic Microwave Ovens
Panasonic Dimension 4 Microwave- Model NN D801. Whilst microwaving for 2 mins on high - heard a zapping noise. Didnt heat food. Front operating panel works. turntable still works. Any suggestions?
A "zapping noise" usually indicates a problem in the high voltage circuit. If it's an inverter oven, it should have provided you with a fault code. If a non-inverter, the most likely causes are a shorted high voltage rectifier or bad magnetron. But there are many other possible causes.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Oct 02, 2016 | Panasonic Microwave Ovens
Panasonic inverter microwave nn-sd688s, stops and resets but then will work again after, seems to do this just by opening and closing door. What could be the problem?
I'd check the door switches to make sure they are being reliably activated when the door is closed.
Apr 08, 2016 | Panasonic NN-SD688 Microwave Oven...
When started,light& turntable operate normally,but no heating by microwave. Transformer normally sounds smooth,but now makes rattle or vibrating noise,like something is loose.
Check the door safety intertlock micro switch for proper behavior. If it is faulty, the oven will think the door is open and will not turn on the magnatron.
Sep 22, 2010 | Panasonic NN-C980 Convection/Microwave...
Operating instructions how to set the clock etc con my mircoware
hit clock button press in the time with the numbers on the pad and press the clock button time solved
Apr 03, 2009 | Panasonic NN-P794SF Microwave Oven
Panasonic Microwave NN-C980-B buzzing noise but it still works.
All:
I have a 2003 Sears Ultra Wave microwave 721.63682300 with a similar problem. A few months ago it started giving off short buzzes when turned on. That stopped but then I noticed that everything took twice as long to heat up. After quite a bit of teardown&inspection I found a circuit break in the inverter board leading to ZD704 diode (pictured). I will now try to find a replacement diode to see if replacing will fix it. Thanks for your postings.
Feb 15, 2009 | Panasonic NN-C980 Convection/Microwave...
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 14, 2008 | Panasonic NN-S753 Microwave Oven
Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Dec 26, 2006 | Panasonic NN-S950WA Microwave Oven
Microwave Ovens Logo
259 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
