Question about Polycom SoundPoint 330 IP Phone
Waiting for network to initialize - Polycom SoundPoint 330 IP Phone
Network drivers are not worke propely
Instructions
    • 1 Check which communication port and interrupt your modem is set to use. Typically, these are hard-wired selections on the board itself. Changing the jumpers on the board changes the port address and interrupt number. You must give forethought to the consequences of the decision. There are only two interrupt lines usable and four port addresses that are possible. Only one port can utilize an interrupt number at a time.
    • 2 Change the port and interrupt assignment if required. Restart your system and see if this solves the problems. If not, find the documentation for your modem. You must now generate the proper initialization string for your modem to maximize your communications. Some of the settings in the initialization string determine the audible sound of the modem when dialing and connecting. More important settings have to do with number of rings to wait before hanging up, time to wait between redials, sensitivity of the modem to line noise and enabling or disabling the transfer mode of X2 or V.90 (the two formats for 56K communication).
    • 3 Find the modem driver that you are using and check that it is the correct driver. There are many drivers available based on manufacturer and model of the modem. Not only is the driver modem specific but also the recommended initialization string. Make sure your modem receives the correct initialization string in the setup file or preference window in the application that uses the modem.
May 13, 2011 | HP Pavillion DV6227 Notebook
Plycom ip330 phone - works fine when connected directly to Brighthouse modem, however when brighthouse modem connected to belkin router then to phone says - waiting for network to initialize, please help
sounds like your belkin router is not setup as a DHCP server or the DHCP is disabled. The DHCP in the belkin assigns addresses to the internal network, the error "waiting for network to initialize" means that the phone is waiting for an IP address, to which its not getting. When you connect directly to your modem you get an IP from your Internet service provider. I'll bet your internal network is setup using "static" ip addresses, if thats the case you will need to surf into the phones web console and set a static IP address. Or the opposite, enable DHCP in the belkin. hope that clarifies things a little.
Aug 28, 2010 | Polycom SoundPoint 330 IP Phone
Cannot set IP address on Toshiba e stuido 16s copier
In order to set IP address, make sure printer kit/NIC is installed. Plugged network cable, Press Program button--> Initial Setup-->Network-->TCP/IP to configure IP address. Once finish, back to Network-->Complete to save the settings.
*Machine need to initialize network during startup, once finish initialize network then only u're able to access network settings. A status page will print out by default after finish initialized network.
Jan 10, 2010 | Toshiba E-Studio167 Copier
Connected WGR614 v6 to DG814. Have internet light on, no wifi. Can't connect to the WGR614 via lan from pc. Tried to hard reset nothing happens. The PC and DG814 show connection to the WGR614 but can not...
Is this the initial set-up of the network? Sometimes it just needs to be rebooted a few times to connect. The way to reboot the network is to turn off the computers, then unplug the router, next unplug the modem. wait about 30/60 seconds then plug in the power to the modem. Wait for the modem to fully boot. Wait a minute or two, then plug in the power to the router. Wait till it has booted, another minute or two. Once the router is fully booted, then turn on the pc and check to see if it connects. If the computer was previously connected to the modem, before the router was incorporated, it still has the ip address assigned by the modem and has trouble releasing it and getting an ip address from the router.
Dec 02, 2009 | NetGear WGR614 Wireless Router
Network will not initialize
you need to shut the machine down, turn off power and restart it... it should go through the Network Initializing after it has connection with the network, this screen should go away..
Jul 21, 2008 | Toshiba (GM1030) for E-Studio 200L Print...
Network
restart, wait a 1-3 minute, when the printer shows ready for copyng then look again.
Nov 16, 2007 | Konica Minolta bizhub C250 All-In-One...
Verizon V3C connected to network full bars but wont make/receive calls or texts. What gives?
the problem you have guys was a hardware failure and we cannot fix it here probably your p.a. ( power ampli ) is faulty or the uem ( power and audio ic ) go to your nearest service center... or try this , this may solve the problem... go to menu, settings, initial set up, master clear, code (000000 ),,, then phone will boot just wait,,, then again go to menu, settings, initial set up,,master clear with d same code... wait till it boots up.... let me know if your problems solve..
Dec 17, 2006 | Motorola Mobility RAZR V3
Open Questions:
See all Polycom SoundPoint 330 IP Phone Questions
Polycom SoundPoint 330 IP Phone Logo
155 people viewed this question
Top Polycom Computers & Internet Experts
Michael Vincent Cruz
Joe Lane
Darren  Means
Darren Means
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
