Question about Nikon D60 + AF-S DX VR NIKKOR 18-55 mm Lens and AF-S VR DX 55-200 mm Lens Including Charger, Lithium batt... Digital Camera
Where is the reset switch of nikon d40 camera ?, how to reset camera?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
There're actually two buttons. Press and hold the Info and zoom-in buttons (both marked with a green dot) for more than two seconds.
Full details are in the "Two-Button Reset" section of the manual (page 38 in my copy). If you need a manual you may download a copy from here.
Posted on Jan 08, 2013
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
Posted on Jun 01, 2008
  • 6 Answers
SOURCE: Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
Posted on Jun 06, 2008
SOURCE: d40 software
No drivers needed for Vista either. But make sure that you use the USB cable included with the Nikon D40x. My Cannon cable (although it looks identical, produces a Device not recognized error) with the D40x. The Nikon cable works fine, of course... I now have them marked.
Posted on Jun 20, 2008
  • 115 Answers
SOURCE: problems taking pictures with nikon d40
Chances are good that it's not your camera, but your lens. In a darker atmosphere, you need a fast lens, meaning you need a lens that has a wide aperture (1.4 to 2.8) I'm guessing you're using a lens thats' 3.5 or larger. (Yes, the larger apertures have the smaller numbers)
If your camera was spending all it's time moving in and out trying to focus, it's probably because there was not enough light for the camera to distinguish a focal point. Same thing happens when you shoot a solid blue sky. No focal point.
Help me understand by telling me what lens you're using and what settings you were using on the camera.
Posted on Apr 27, 2009
  • 375 Answers
SOURCE: Computer cant find USB drivers for Nikon d40
I had the same problem with my D40x - I changed my USB cable to a much more robust one and all my problems went away.
You shouldn't need a driver, most OS's will recognise it as an imaging device.
Posted on Jun 30, 2009
How to turn on Discovery Mode for Nikon D40 Digital Camera
There is nothing about a "Discovery Mode" in the D40 manual. I am not sure if this will work, but try resetting the camera to its default settings. Push the menu button on the left side of the LCD and scroll down to the pencil symbol. You will find an item on that menu called "Reset". Once you do the reset, see if the "Discovery Mode" is there. Frankly, I think you would be much better off if you read the D40 manual. In case you lost yours, I have attached a link where you can download it in pdf format.
Jun 30, 2014 | Nikon D40 Digital Camera
I have lost the software for my Nikon D40 camera.Model n16184. I want download the software.
This is the Nikon support web page that has the firmware updates for your camera. Current Firmware downloads available for Nikon products Nikon... The D40 is near the bottom of the list. Follow the instructions carefully.
Jan 24, 2012 | Nikon D40x Digital Camera
Var hittar jag nikon d40 manual att ladda ner???????
Hej,
Du kan ladda ner handboken genom att klicka dessa lankar.
Nikon D40 svenska handboken
Nikon D40 engelsk manual
Tack for att anvanda FixYa.
________________________________
Translated using Google Translate
Mar 04, 2011 | Nikon D40 Digital Camera
Using a Nikon D40 digital slr with a AF-S DX Nikkor 18-200 1:3.5-5.6 G ED lens I was previously able to autofocus bun now am not. Can you suggest reasons why this may be?
Please check if the Autofocus-switch on your lens is set to M/A. Also check if the Autofocus on your camera is switched on. For detailed information about your cameras autofocus, please check this site: http://www.kenrockwell.com/nikon/d40/af-settings.htm
Jul 18, 2010 | Nikon D40x Digital Camera
Can you use nikon sb25 flash with d40 dslr?
You can but with limitations;
Save me explaining,please read this http://forums.steves-digicams.com/nikon-dslr/137618-sb-25-d40-non-ttl-auto-mode.html
Apr 14, 2009 | Nikon D40 Digital Camera with 18-135mm...
Nikon d40 lens
The Lens focusing motor is broken and it is replaceable
Jul 31, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
May 26, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
New Camera can't set the language
try this - describes the reset on page 14 or the language menu on page 35 http://www.kenrockwell.com/nikon/d40/users-guide/d40-users-guide.pdf hope this helps:)
Mar 09, 2007 | Nikon D50 Digital Camera
Nikon D60 + AF-S DX VR NIKKOR 18-55 mm Lens and AF-S VR DX 55-200 mm Lens Including Charger, Lithium batt... Digital Camera Logo
61 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
