Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Hpm1522nf - scanner error 8
Printer gives me scanner error 8 or scanner error 5 when trying to start it up
  • HP Master
  • 1,121 Answers
Replace Optical Scanner Assembly(CCD).. Some technical knolwdge required to replace this part.. See the part:
Posted on Jan 08, 2013
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
  • 108 Answers
SOURCE: Scanner 5 error - turn
The laser assembly or main board might have an issue.
Posted on Jul 31, 2009
brett207
  • 231 Answers
SOURCE: my hp M1522nf printer is giving a scanner 8 error
Is this device still under HP Warranty?
I hope so.
Several HP models have Scanner failures, which require the Scanner replacing...
Try to find this Part no:
CB534-67903
Posted on Dec 09, 2009
sandimcp
SOURCE: Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
Posted on Sep 01, 2010
puertobori
  • 7733 Answers
SOURCE: i have printer hp laserjet
Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English).
If you need more help come back.
Post / thumbs / testimonial are welcome!
Posted on Jan 16, 2011
Scanner error 5
Follow these steps:
1) Switch off the printer
2) Open the upper cover where the scanner is
3) Clean the white stripe, which is on top of the scanner "home"
4) Open the right side cover - it has two screws that hold it in place
5) Switch on the printer
6) On start up, put the upper cover back on the scanner
7) Then the scanner starts moving, unplug and plug back in several times the green, blue, yellow, red connector which is up on the upper left side of the metal cover
8) Then the error should go away
Good Luck
Nov 09, 2011 | HP Office Equipment & Supplies
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
Its showing scanner error 8 and 5
Hello, this indicates aproblem with the copier scanner assembly.
For more information follow the posted link.
Scanner Error 5 CLICKHERE
Feb 15, 2011 | HP LaserJet M1522nf Multifunction Printer...
Printer is freezing up have to turn on and off the printer for it to unfreeze
HPM1522NF - Freezes or Restarts Randomly.
Hello, this is caused by the "formatter" board being defective, it needs to be replaced. This printer also has a scanner problem, the error code of 5 and 8 are reported. This printer should be covered under an HP Extended Warranty Until Mar 23, 2011 Contact a local HP Authorized Service Center for further assistance.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Jan 09, 2011 | HP LaserJet M1522nf Multifunction Printer...
Lemon law.... 1522nf can only use for 2yrs, after change the formatter board
Hello, this is caused by the "formatter" board being defective, it needs to be replaced. This printer also has a scanner problem, the error code of 5 and 8 are reported. The Foramtter and Scanner should be changed at the same time. This printer should be covered under an HP Extended Warranty Until Mar 23, 2011 Contact a local HP Authorized Service Center for further assistance.
"scanner error 5 turn of then on" reads on the display screen
Sorry but I have a bad news. Scanner error 5 or 8 means that the scanner lamp is not able to move and if it does it cannot go all the way. The printer need service, probably a new scanner. The repair might be too complicated and expensive (over $250) I suggest to get a new one. HP can provide a deal to recycle the unit and give you a credit, maybe not a lot but its something.
Aug 30, 2010 | HP LaserJet 2840 Printer
Printer freezes after about 20 min. No buttons
Please contact your local Hewlett Packard Repair Center.
I hope this has been of assistance.
HPPARTNERLOCATOR
May 14, 2010 | HP LaserJet M1522nf Multifunction Printer...
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
442 people viewed this question
Seeker5211
Seeker5211
