Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Tv sony kdlv40xbr1 stable vertical lines, no resonse from control except power buttum, plays only through hdmi input. no other inputs working. has vertical lines covering entire screen. could this pro
No standby light is working and don't hear a click from relay when powering up. Green power light only one working and takes about two minutes for vertical lines to appear.
    Top Expert:
  • Sony Master
  • 74,459 Answers
The T'Con board should be checked and replaced. Before replacing it check all connections comes to it and go out from it. Re-seat all flat cables connected to it. Check this to know more about the fault to this set.
Posted on Jan 08, 2013
Testimonial: "thanks so much I will do that right away"
mistersony
  • 320 Answers
SOURCE: HDMI Input Stopped Working Sony Bravia KDL-40S2000
Bad input board BU or AU
Posted on Oct 18, 2008
budmrtn
  • 11361 Answers
SOURCE: Sony Bravia KDL-V40XBR1, no picture
You either have failed 24vdc power supply section or failed backlight inverter board, check for 24vdc first, look for caps with leaking/bulging top.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sony+BRAVIA+KDL+-V40XBR1+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 13, 2010
experttv
  • 203 Answers
SOURCE: Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
Experttv@comcast.net
Posted on Sep 11, 2008
  • 267 Answers
SOURCE: Sony 46" LCD tv hdmi input replacement kdl-46v2500
replace that board
Posted on Mar 06, 2009
SOURCE: KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Posted on Apr 01, 2010
How to fix no sound audio on Panasonic viera when connected from hdmi 3 port to Sony bluray BDP s480 hdmi port?
Well, first make sure you don't inadvertently have the "mute" control on your DVD player turned to the "on" position. Does it work on HDMI 1 or 2? Play with it a bit. Connect it to other TV HDMI inputs and see what happens. Obviously, the video is getting through, just not audio. HDMI inputs on your TV carry both (unless there is a problem with one of them), as does the HDMI output on your Blue ray. Also, make sure the HDMI OUTPUT from your DVD is connected to the HDMI INPUT of your TV.
Aug 19, 2017 | Sony Televison & Video
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
Hdmi inputs select
This is a 720P TV, please try set up your Samsung DVD play video out put format to 720P, then try it again.
Aug 15, 2017 | Sony KDF-50E2000 50" HDTV
My emerson tv say device control inactive
John, I've ran into this issue a couple of times myself. In most cases, there are easy fixes to the issue. #1, Does your TV have multiple HDMI inputs? They may be labeled HDMI1, or HDMI2, etc. I know this sounds strange, but many people don't realize that the signal source is important. #2, Connect the cord, from another device that you know works(laptop-monitor) to eliminate the possibility that your HDMI cord is bad. #3, (Probably most common) The PS3 is not the most stable platform when using the HDMI cord. Remember that the PS3 was one of the "pioneering" platforms using the HDMI connection.As such, the "auto-detect" feature is sometimes confused when switching between RCA inputs, and HDMI input. (Happens every time actually) To fix this, try a video reset on your PS3 system. It's fast, easy, and doesn't effect anything except the video/audio settings. I'll put in a link to get you started in that direction. It is the same with all models of PS3. Good luck! ^^
How To Reset PS3 Video Settings PS3
May 06, 2013 | Sony Playstation 3 (PS3) Console
I have a Vertical Line down my Tv? Its a Samsung LN46B550 Sound Works I can still see some of the picture... All HDMI Inputs work... HELP
So your HDMI inputs work fine without the vertical line?
If every input displays like this, there is a high chance that the problem is in the TV panel itself.
I had something similar with a Sony TV, except the lines were horizontal and the panel was replaced for free under warranty.
Dec 17, 2012 | Samsung Televison & Video
DAV-DZ260 + KDL-32V4000 - no audio from TV to DAV via HDMI
Check DAV amp menu and select DTS surround or any other digital sound option.
Jun 15, 2009 | Sony Audio Players & Recorders
How do i get on the HDMI input channel?
Hello Jeff. I just have a basic question for you. Was the Blu Ray player turned on when you first plugged it into the tv? TV's are becoming so complicated that they are becoming less user friendly. Try setting your tv to the first HDMI input using your tv remote's input button. Then unplug the HDMI cable from the tv, make sure the player is turned on then plug the HDMI cable into the left most input if horizontal or top input if vertical. Hopefully if you do that and have the input selected, it should work for you.
Also: Whi9le attaching the cable, I find it helpful to have it in a position where I can see the tv, because when a device hooks up the screen usually flashes or turns blue or something similar.
Hope this helped
-Chris
May 01, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
No video input -- all ports -- for JVC LT-37X688
JVC may allow warranty exception or some accomodation for 15 days out. You have 2 seperate issues
1. White lines spreading is probably a video process problem. I think this TV has 3 Boards inside. Middle one is most likely suspect followed by the one on the Right
2. HDMI input not working is because they were turned OFF. JVC TV's have a sensor that will shut off the HDMI if the TV's back cover is removed. This must be reset in the Service Menu.
Nov 16, 2008 | JVC LT-37X688 37 in. LCD HDTV
Input 5 not playing audio via HDMI or stereo
HDMI can be problematic. Follow these steps in order for the best success with HDMI.
1) With all devices off, turn the TV/monitor on first and wait for it to come on.
2) Select the HDMI input.
3) Turn on the next HDMI device (stereo amp if it comes before the video device, or the video device itself and let it come on.
4) Play the video.
Some video devices may need the audio output to be set to PCM or 48k/96k datastream to work correctly.
If this doesn't help, you may have a compatibility issue with your HDMI device. Usually it is the fault of the player/video receiver and rarely the display/TV. All the TV/monitor does is query the source device as to what type it is and the resolutions it's supports.
May 31, 2008 | Sony KLV-S23A10 23 in. LCD HDTV
HDMI inputs stopped working
I had the same problem with the HDMI connected to my HD cable box DVR. We called the cable company and he changed the box and the problem remained. He said there was something wrong with my TV.  The component (5-wire) jacks on input 5 work fine.  A few months later i got the 'green tint" problem and the tech came out to replace the whole optical box.  I asked about the HDMI problem and he said that the Sony protocol for HDMI is the problem. It will "talk" to some hardware and not others. He has not found a fix, except to use the other A/V inputs and abandon the HDMI (#7) input.
Mar 22, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
160 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
