Question about Hitachi 12v 3/8" Driver Drill Kit with Flashlight DS12DVF3
Can the charger be repaired for clarke 24 volt cordless 1/2" drill model ccd240
The charger will not charge the battery , bought new battery and can not charge it.
3 Suggested Answers
SOURCE: chargers
went to blackanddecker on google and found everything I needed. Thank you
Posted on May 26, 2008
SOURCE: have a workforce brandname drill/hammer cordless
Replacement batteries for the Workforce 18V cordless drill are available @ 888-315-3080 for $15.00+
I currently have 2 on the way via UPS
Note: This drill is no longer marketed under the WorkForce name (and Home Depot won't help you) but is marketed under several other names including Hillman.
Posted on Jul 28, 2010
My Lumia 520 is dead! It wouldn't charge, so I bought a new battery, the battery worked till it drained now it won't do anything. Checked the battery points & charger entry, don't know what else to do
Hi , you have to check that you might need a new battery charger. The new battery the bought had a charge then you used it up it sounds like your charger might have the light on but is not charging.
Dec 27, 2015 | Nokia 5700 Cellular Phone
Batteries wont charge
If there is less than 10 volts on the new batteries, then use an automotive NON automatic battery charger to charge the batteries individually.
Feb 08, 2014 | Pride Health & Beauty
Kodak easyshare dx6490 charger indicator light is on but battery wont charge
Sounds to me that if you bought 2 chargers then you have a bad battery. what are the odds that you have 2 bad chargers ? Time to buy a new battery.
Jan 25, 2013 | Kodak EasyShare DX6490 Digital Camera
Need a battery charger for the 21.6 volt battery
It will work if it is of the same charger/receiver style. The only issue is that you will only be charging to 19 volts and not 21.6, I would estimate by doing some simple math that you would lose about 6-8% of the batteries capacity but you would be able to use it.
Jun 05, 2012 | kawasaki 21.6 volt Cordless Drill Driver 2...
New drill batteries wont hold a charge also, Bought a new battery screwdriver, the charger has exploded within 1 week
Don't even bother to try repair either of them, Take them back to the dealer under warranty and make them his responsibility, If you try repair them the warranty will fall away.
Feb 10, 2011 | Ryobi 18volt 12" Cordless Drill Model P206
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
Hitachi 12v 3/8" Driver Drill Kit with Flashlight DS12DVF3 Logo
98 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
