Question about LG F1402FDS6 Front Load Washer
How to turn the chime up on model #fafw3921nw
My Howard Miller battery operated mantel clock model 612-588, movement 354078F doesn't chime. My wife thinks she might have changed a setting or switch accidentally. How do I re-set it?
There is a switch from 'chimes off' and two variants. There is also a night clime cut off or volume reduction.
. CHIME MELODY
Use the switch with the symbols
OFF, WEST, and MELODY2
to select the chime melody according to the following settings:
O
FF = Silent
WEST = Westminster melody and full hour strike
MELODY2 = Ave Maria melody and full hour strike (Beethoven's Ode to Joy on select models)
. VOLUME CONTROL
The volume of the chime can be modified by turning the Volume Control knob.
5. AUTOMATIC NIGHTTIME CHIME SHUT-OFF
The movement has automatic nighttime volume shut-off or volume reduction options for a period of eight (8) hours after the switch is moved to the shut-off or volume reductions positions. This feature will automatically repeat at the same time every 24 hours. Use the switch with the symbols to select chime silencing according to the following settings:
Chime silent for eight (8) hours
Reduced volume for eight (8) hours
Full chime volume
Here is the manual
http://bigbenclocks.com/img/products/manual/quartzmanual.pdf
Nov 07, 2017 | SHE Home
Why does my Carlon Plug in Chime Model RC8253R keep going off?
Carlon Plug in Chime Model RC8253R?? What is this?
Jan 18, 2017 | Cars & Trucks
I cannot figure out how to syncronize the time and chimes for a Seiko model AQF 153B with Westminster Whittington chimes.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Feb 25, 2011 | Seiko Mantel Clock
I need instructions on how to use and program a nutone door chime. Mine is a musical style for front door. I can change the chime to many different sounds, but have no instructions on how to use or program...
The 515N number is a transformer part number, do you have a photo of the chime you have? Is it wired or wireless? Is it a newer chime or and older model? Check Nutone's website to see what model you have, then search their site for the model you have. The model page will have an instruction sheet PDF file download of the instructions.
Oct 11, 2017 | Broan-NuTone Door Chime Kit by NuTone
Same problem, I cannot shut off hourly chime. Men's model CG111M
On the CG 111M, the chime is turned off and on by pressing the start and reset buttons at the same time. Those two buttons are on the right side of the watch face.
Oct 05, 2009 | Watches
How do I trun of the change of hour chime on my son's tghk watch
Press the bottom right button and while holding it down press the bottom left. All the days will show and the hourly chime is off, if the days aren't lit the hourly chime is off.
Sep 11, 2009 | Watches
Turning off the on/of chime for a samsumg series 5
In SETUP you will see.
Melody → Off / Low / Medium / High
# NOTE - If this info was helpful to anyone please click on yes!
Jun 11, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Casio G-Shock alarm not working
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
( ) Button reference
C __D
6) Hourly Chime (SIG):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Press C to return to Timekeeping mode.
Good luck,
Techjoel
Feb 04, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
LG F1402FDS6 Front Load Washer Logo
47 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
