Question about Vizio VW42LF 42 in. LCD HDTV
Sound but no picture
Didn't get sound nor picture. Replaced mainboard and now when I turn it on I get sound and the backlight and picture (blue screen) flashes briefly before going black again. When I turn it off then back on the same thing happens.
    Top Expert:
  • Vizio Master
  • 74,377 Answers
After replacing the main board, a software update will be necessary in most cases. Check it.
Posted on Jan 08, 2013
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
  • 92 Answers
SOURCE: Plasma does stay powered on
Your sustainer board is probably bad. You need to get the Y & Z sustainer boards replace then it should be okay.
Posted on Feb 09, 2009
phongnv
  • 56 Answers
SOURCE: vizio p42 very dark screen backlight off
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
Posted on Feb 17, 2009
  • 19 Answers
SOURCE: How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Posted on Mar 27, 2010
budmrtn
  • 11361 Answers
SOURCE: 26" LCT HDTV Backlight Problem
It can be that the inverter is not getting the 24vdc fromt he power supply module, check for that first, you can check it at either the power supply termninals or at the inverter board. Look to see if the power supply has any leaking/bulging top caps. Modules are easy to replace, fixing it down to component level is not so easy unless you have proper tools an electronics knowledges.
Power supply and Inverter bd: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VA26L+
Learn more here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 14, 2010
Testimonial: "Thanks. I swapped out the inverter board for one that I know works, but still have the same proble. I'll look for indications of a bad power supply for the backlight."
Magnavox lcd tv 37md350b/f7. Has sound but no picture.backlight ok.In about 90 seconds a picture appears from top and rolls down .picture frozen. then fades.
I'm an authorized service provider for Samsung and Vizio. Your problem sounds like the mainboard. You can find usually on ebay by searching for your tv model and then mainboard.
Hope it works out for you.
Preston
Jun 15, 2017 | Top Computers & Internet
I have a 50in Hisense 50K360G. The backlights come on, but no picture or sound. I replaced the main board and power supply and when that didn't work, I took it to a TV repair shop for a free
As far as the TV is now at any service center, it will be wiser to make it repaired there. Otherwise, you might have to spend more; sometimes will get it back in irreparable condition. I assume that, you will understand my words. Gopakumar Gopalan Google
Jan 20, 2015 | Hisense Televison & Video
Need solution for Samsung 39EH5003, Has sound but no picture
if the inverter board for backlight get to work so the cause either your lcd panel get malfunction or the t- con board doesn't work.
Jun 15, 2014 | Samsung Televison & Video
I have a 26' Toshiba LCD TV Model: 26WL65G. When I plug in and turn it on it seems to start normally, but when screen turns on blue screen appears as normal and it goes back to stand-by mode...
Note that if it is a backlight inverter board problem you will still have sound. SInce you have no sound I would suspect a power supply or main A/B board malfunction. Do you know how to use a multimeter?
Dec 11, 2011 | Televison & Video
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
Tv picture went out no sound nothing i can unplug it and plug it back in and turn power on get no picture or sound and cant power off?
Sounds like it's time for a new mainboard, these can be quite costly depending on the model. Do the backlights come on? New boards can be purchased from places such as Shopjimmy.com, Ebay.com, Majictvparts.com, tristatemodules.com and many other carriers. They aren't hard to replace, just shop replacement board cost, find a bargain.
Sep 22, 2011 | Vizio L32 32 in. LCD HDTV
42" vizio vw42l - no picture or sound
If the backlights for the screen do come on and you also have 12v and 5v feed the main board then it does sound like the mainboard will need to be replaced.
Nov 28, 2009 | Vizio VW42LF 42 in. LCD HDTV
Sound turns off after tv is started sound only one
Hi my name is Roety,
I can help you with your issue ,
Without a model number, I do work on sony LCDs.
The audio is on the mainboard. You need the mainboard replaced.
Reboot every device by unplugging the AC power , if the sound still cuts off replace the mainboard
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
Eric
Oct 10, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No picture on vizio lcd
It's likely not a backlight, but a mainboard. If you are feeling frisky, take the back off and get the model number off the mainboard and check eBay.
Jul 26, 2009 | Vizio P42HD Television
No picture and sound from my LCD 32
ya kunle bawo ni ? are u a technician? well do this .check your power moudle outputs if all are ok(no voltage drop, no fluctuation & no burst or swolling electrolytic capacitor). disconnet your backlight inverter supply from the power moudle.plug your speaker & antenal firmly. plug your tv & power on, scrol tru your channels, if sound. your backlight inverter is bad. if all still remains dead ur analog/digital converter(mianboard) is bad
thanks. o seun.
Dec 13, 2008 | Goodmans W280NS Television
Vizio VW42LF 42 in. LCD HDTV Logo
42 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
