Pc will not boot need to know the beep codes, to solve problem
Mother board beeps three times quickly with the GeForce & the LeadTek two quick followed by 8 medium length beeps, nothing appears on screen & does nothing else, this only happened after adding PCI-E video card, onboard video still runs, but was insufficient for the games I want to play, so I bought two identical cards from different makers, Leadtek WinFast PX8800 GTS TDH fan double slot 320bit 320mb gddr3 & a GeForce version that's single slot & water cooled. I have pared the system down to just the new Cooler Power 750W PSU Part No. P4N8-N 3.3v-24A, 5v-30A, 4 separate 12v rails all at 32A, -12v-0.5A, 5vSB-3A, no -5v rail, though it runs with onboard video... Two sticks of Kingston ddr2 800 2Gb ram, as before this board runs with these memory sticks, it just doesn't show 4Gb due to 32bit AMD Phenom x4 9750, this CPU runs at 2.4Ghz, but runs happily @ 3.2 with about 6 degrees C above normal on standard cooler, no temp increase noticed with water cooling... Seagate Barracuda 7200.12 500Gb Sata II Hard Disk, over 3 years old, but still runs like new, with a fresh install of Win XP Pro SP3 & all updates integrated into the installation files, including drivers for almost everything (which XP never had), up-to July 2012 most non essential parts of windows has been removed to improve performance including defrag, notepad, wordpad & many other parts of windows that normally can't be removed, they were never installed, I own many original versions of windows, from Win 3.1 all the way through to Win 7 & most variants of all versions, until I got win 7, then I gave the disk away & downloaded Win XP Pro the Pared Down version for people who want a bleeding fast Win XP Pro PC, yes it had been hacked, by an ex-microsoft employee, who knew what he was doing, he did leave the code entry system alone, so that only genuine Win XP Pro holders could use it, he even beefed it up a little to not work for the many codes that are floating around the internet. The first time I loaded this, I was gob smacked at how fast it booted, 5 seconds from the post screen, which shaved over 40 seconds from the bought version, with it's hundreds of updates that windows HAS to wade through, not with this version, it's only got to glide through a few new one's, auto update is locked on, the usual place to activate or deactivate is not there, but there is a load of tiny apps that do the jobs of many things that were removed, all non MS stuff, but the new defrag tool is VERY configurable, it even runs in the background while PC is using say 25%(adjustable) of CPU power, it can even move immoveable files! Even Quicktime, Flash etc is all there, Apple will NOT be impressed, but they may like it that Safari is there also & IE is NOT !!! OOppss, sorry about the OS stuff, but I couldn't help myself, it's SSSSSSOOOOOOOOO good, I just had to tell you, if you want to know where to get it try demonoid.com or piratebay.org, you also need utorrent & peerblock, run both before you search for it...
  • Steve Taylor Jan 15, 2013
    Whooopps, that's a big mistake, it is a MSI MS 7302 ver 1.1, great little board, but that's it's problem, it's an mATX with it's SATA II plugs inline with the PCI-e 16x slot, no good if you need to use a double slot card, but I am still interested in knowing what the codes mean exactly or better still, where to find them myself. Because for this motherboard & another GA-MA770-S3 Rev.2.0 (error codes were just long loud blasts, that didn't stop), codes are NOT published on Mobo manufacturers websites & I think that is not fair that the error codes are not listed in the manual & in the case of different bioses in different versions of the same board, they should list them all & tell you how to tell the difference between bioses !!! I have since borrowed a brand new video card & discovered that I was sold two LEMON video cards on eBay, 'cause the new card worked straight away. So will have to save up my pennies & bite the bullet & buy a new card... As I bought another Mobo (the Gigabyte) without onboard video, I have no choice...
    Scholar:
  • 127 Answers
All that typing and you still didn't list your motherboard make and model ?? different motherboards have different BIOS's and their respective beep codes are different for each
try looking in the BIOS and checking the video section for a PCI-e setting. sometimes it has to be set to look for a PCI-e card first, especially when the motherboard has on-board video.
Posted on Jan 10, 2013
    Thank you for the good advice, I checked the settings & they were already set to PCI-e, perhaps because the onboard video uses this as-well ?!?!?! Dunno, just guessing, because I have some older systems with AGP slots & AGP onboard video. I also have two fully functioning IBM PS2's with 2Mb ram & 31Mb HDD's both with Windows 3.11 for workgroups on them, which is not supposed to work, but I don't tend to listen when I'm told it's NOT possible, it is when you install via floppy. one is in a museum, the other I have at home & let the kids play the old dos games on it, as it's indestructable, as is the keyboard, mice are cheap so am keeping the original.
  • D Peterson
    D Peterson Jan 15, 2013
    Well, if it is this one : MSI K9A2GM-F V3 Socket AM2+ Micro-ATX Motherboard, AMD 740G and Radeon 2100 Chipset, Supports AMD AM2+ Processor, DDR2 800 Memory, PCI Express 16x Video Card Slot, SATA RAID, with HDMI, GbLAN and Realtek ALC888 audio. MSI Part No: MS-7302-020, then it has an AMI bios but I dont see that particular beep code. See my thread about bios beep codes here :http://www.fixya.com/support/r15891519-b... I hope it helps
4 Suggested Answers
techcrazy
  • 72 Answers
SOURCE: Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Posted on Feb 04, 2009
SOURCE: Gigabyte GA-M57SLI-S4 (rev. 2.0) 3+3 beeps on start up, no display.
Make sure your RAM is pushed in fully, even if the tabs have clicked, it may not be fully in, especially if your ram is wide (heatsinks etc) test it with one stick till it works, then get the other working :)
Posted on Feb 25, 2009
c-tekk
  • 177 Answers
SOURCE: no post to bios on new pc build
FIRST....... Make sure you remove the stock thermal compund (pasty/sticky stuff) from the bottom of the heat sink as well as from the top of the cpu.........
Second APPLY some ARCTIC SILVER 5 compound-ust a thin coat of it over the top of the cpu......use an old credit card.....keep it ff the sides and bottom though......it's important not to use too much........one little tube will do anywhere from 3 to 5 CPUs...!!!
(stock thermal paste/thermal compunds......**** BADLY and can cause a cpu to burn up)
reseat (properly) the cpu and carefull
Now make sure you're 24 pin or 20+4Pin Power connectors are connected, as well as your fans..........disconnect all your SATA Devices, and remove everything but the video card , CPU, and fans.......Now it should post (if all your jumpers are set correctly...........
IF it still doesn't post, remove the video card and reboot.
If it doesn't beep at all......... You have one of 2 things.........A DEAD CPU, or a DEAD MOBO
Posted on Mar 19, 2009
1 long beep 2 quick flashes on power button
Flashes & beeps indicate a start up failure on the motherboard. You'd need to google the trouble codes for your particular make & model to determine which mother board system is the problem. It might be simple like a mother board battery failure or something more complex like unreadable bios. If the computer is a few years old, it's not good. If you are curious, bring it to a repair shop but I can tell you 95% of the time you end up buying a new computer after you pay the shop fee. Why? Because you find out the repair costs almost as much as a better replacement on Amazon. Do yourself a favor. Get the replacement and have the computer shop recover your files from the old unit or pay $23 and get the DIY kit on EBAY. Good luck.
Aug 05, 2015 | eMachines Computers & Internet
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
2 quick beep codes
You're right about 2 beeps means "No RAM Detected"
Maybe re-check the RAM chips for bad connections or broken pin.
Also you could measure DC power to the RAM connectors.
Hope this helps.
Feb 19, 2012 | Dell Inspiron 537 ST PC Desktop
Boot failure, beeps and no display
Hi.
Do this solution first in the motherboard only processor installed need no memory.then power on your PC.if your motherboard no continues beeping.that need replacement of parts specially capacitor
leakage,became big or burn parts.
See beeping code.
Beep Code:
Description of Problem:
No Beeps
One Beep
Two Beeps
POST/CMOS Error
Motherboard Problem
Video Problem
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
CPU Overheating
Jun 17, 2011 | Dell Motherboard For Precision 470...
I have a brand new SAM4S ER-180 cash register. If I plug in the power it immediately goes to error mode & beeps at me. The LED screen is reading E Lo0000 or E Lo0.00. I have tried everything & dont...
A beeb normally means defective (hardware failure) DOA. Go back to your store for a warranty replacement.
Does it start without the scanner?
http://tinyurl.com/69hd8kf
Does computer beep when you turn it on? Information on beep codes bleeps on booting, boot codes led flashing flashes 1 2 3 4 5 once twice three times on and off times on boot. power on self test fail, boot failure.
Quick help guides and LED flashing errors codes search for error codes using your
Service manual.
Maybe more info here
http://www.goodson.com.au/service/FrmService.htm
Feb 13, 2011 | Computers & Internet
Pc won't boot, just beeping
firt well try the easiest solution.... did u take out the cmos battery on the board for a few minutes, put back in and try again. of course, unplug your computer before u do this. is there a beep pattern?, how many beeps...
Jan 14, 2011 | HP Pavilion a1720n PC Desktop
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
My comp wont boot up
Try reinstalling the OS, I hope this will resolve this issue.
Aug 02, 2009 | Computers & Internet
Computer won't boot and keeps beeping until I shut it off manually. Short very quick beeps, no pauses whatsoever. Frozen at Vaio boot screen.
How many beeps do you hear? Going on assumption, you may need to replace the memory cards - making sure they are the correct type for your board and making sure that you are using memory in pairs -- Using 2 512MB cards verses 1 card,
Good Luck
C2Solutions
Aug 01, 2009 | PC Chips PCChips A13G+ v3.0 Motherboard -...
Computer Won't Boot (Anything?)
ok sounds like a bad power supply , i would get a new one
Jan 21, 2008 | Computers & Internet
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
