Question about GE JE1640WA/GA Microwave Oven
Vent fan Very little air flow from air intake on bottom of oven.
  • GE Master
  • 9,047 Answers
I would be sure the filters and ducts are not blocked.
If you recently had a problem with your cooktop lights, that can affect the fan, too, but that can usually be economically repaired.
Posted on Jan 09, 2013
My Bosch Microwave oven (build in ) model#HMB8050 Is shutting off after 7 mins. What could be the problem? I have no access to unplugged it:(
That's probably your magnetron overheating due to either a defect or due to a lack of cooling air flow.
Consult your onwer's manual and check your filters, vents, and air ducts for blockages.
Also, your hood vent exhaust fan and / or internal cooling fan should come on whenever you cook.
See my profile picture if you need to contact me for more free help.
Nov 28, 2016 | Bosch Microwave Ovens
My microwave shuts off, black no power when ever I cook tv dinners, potatoes etc. after 2.5 or 3 minutes. After 10 minutes or so, power comes back on and it displays PF. lots of steam inside after.
Hi Kerry,
"PF" is power falure if you didn't aready know this. It sounds to me like the coolig fan might be running slow or there is blocked or restricted air flow through the unit. This cooling fan is only for the HV transformer and magnetron. Sometimes you may get air flow around the door but this is incidental. The PF tells me that the power is being interrupted either at the power source (wall outlet or circuit breaker) or the magnetron TCO is cutting out. It also could be a bad magnetron running too hot. As far as the steam goes, I usually just leave the door open on my microwave for 10 or 15 minutes to let the condensation evaporate.
Jun 25, 2015 | Hotpoint RVM1435 Microwave Oven
When turning Fan on (any speed), top vent grille blowing lots of air, but not pulling air underneath
some microwaves vent to the exterior. check outside for a vent. If it is a recirculating model, perhaps the filters are plugged, the vent pathway is blocked (packaging material) or a loose panel at the back so that the exhaust fan air is leaking out somewhere else. I don't know what else it could be unless the fan is loose on the motor shaft and the fan motor is running but the fan blades are not moving air.
Nov 15, 2014 | Microwave Ovens
What is the probably cause of the fan turning itself on?
Keith, I am going to assume that this is happening shortly after you may have used the microwave and after sitting for a little while the fan comes on. The fan blows across the transformer and magnetron to help keep them cool. If there is not good air flow the fan will come on and run to get them cool even after the timer has stopped the cooking cycle. If this is a countertop type microwave I would suggest turning the microwave around and check the vent area where the fan is mounted and see if there is a build up if lint and dirt on the vent holes. If there is clean it off with a soft rag and hopefully that should take care of your issue. If this is an over the range microwave/range hood combo you will need to check your filters and probably clean or replace them. Hope this helps.
Jul 03, 2014 | Electrolux Microwave Ovens
Ge spacemakerxl microwave jvm1650 vent is not drawing air
It is possible, you have removed and checked the filters, still the intake is low even without the protective filters. The system will need to be taken apart to find the opstruction, or as you said a hole in the venting mechanism.
Jul 04, 2012 | GE JVM1650 1000 Watts Microwave Oven
Oven is installed not outside vented. There is
It could be that the filter elements are clogged and need to be cleaned. Remove then from the underside of the micro hood and clean them using a good quality cleaner, such as Simple Green. Clean and allow to air dry before reinstalling.
While the filter elements are out, you can check for obstructions and run the fan to see if it is better without the filters installed.
If there is no noticeable increase in the air flow, it is possible that the exhaust vent baffle was not installed correctly, when the mircrowave was first installed.
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | GE Advantium 120 Convection/Microwave Oven
Whirlpool microwave oven mh7155xmb0 not venting
Possibly a bird built a nest (swallows) in or on the roof vent. Make sure the fan turns freely when off. Check the vent tube that goes up to the roof--if flex-tubing, it may have collapsed and pinched off the air flow (it may be too long). Make sure that a one-way valve which should be near the exit of the hood is free to move when air flow pushes on it. This valve is supposed to prevent back-flow of air into the house. Hope this helps!
Mar 09, 2009 | Whirlpool MH7155XM Microwave Oven
Microwave oven exhaust fan
The Intake is gentle. It is not designed to have a great pull of air from the Cook Top.
TEST: Turn Exhaust Fan ON
Hold a sheet of your printer paper up to the INTAKE GRILLE (bottom). Will the sheet of paper stay? Held up only by the suction? If it does, Air Intake is OK.
Feb 02, 2008 | Frigidaire PLMV169DC Microwave Oven
My microwave is sweating
No. This is usually a sign of poor venting or air flow. It's possible that the coling fan is not circulating the air properly due to a problem with it or maybe the air vents are blocked. Also, there needs to be a couple of inches around a countertop model on all sides - especially the back - to ensure air flow. Look for buildup on the back vent grille. You can listen for the fan to be running and feel the air flow while it's running. If it's weak or not there, it needs inspection / service. A lack of air flow can cause the magnetron to overheat and be damaged. If this is a built-in model also check your air filter, air duct work and outdoor vent flap. Write back if you still have trouble.
Mar 12, 2007 | Kenmore 64282 Convection/Microwave Oven
GE JE1640WA/GA Microwave Oven Logo
194 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
