Sytem wizzard for my acer wont run it keeps telling me to restart but it doent work
I recently reformatted my laptop all things work fine except my finger print scanner.. everytime i try to open it it says run system wizard.. when i try to run it it says i must restart for chnges to take effect but when i restart i get the same error msg.. can anyone help me with this??
  • megan_n_donn
    megan_n_donn Jan 08, 2013
    i do have some screen discolouraration at the top of my screen.. stranges pixels apear and flash.. would this have something to do with it.. i assumed it was a simple graphics card problem..
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 40 Answers
Re install operating system
Posted on Jan 08, 2013
  • megan_n_donn
    i dont have the original disk so how would i go about doing so??
3 Suggested Answers
SOURCE: Sony Vaio Finger print scanner
Yes it was built orignally with XP but was told that upgrades of the OS was not a problem.
Posted on Nov 13, 2008
SOURCE: Installing Sprint Smartview on Windows Vista --Dell laptop
Smartview is supposed to work with Vista. Did you right-click on the install file and run as administrator?
If you can not get it to work there is a work around.
First, download and install the BlackBerry Desktop Manager software. After installation, plug in your BlackBerry and start up the software for the first time. Open the Options -> Connection Settings… window and set the connection to USB. Plug in the BlackBerry, enter your password if applicable, and Vista will find the device and install a “standard modem”.
Open the Control Panel
Network and Internet
Connect to a network
Set up a connection or network
Set up a dial-up connection
Select Standard Modem
Dial-up phone number is #777
Connect.
Everything should work, some have reported faster speeds using this method over the Smartview program.
Posted on Mar 15, 2009
System wizard
Try to repair the window again.
Oct 11, 2013 | Acer Computers & Internet
My acer aspire one wont come off the 'Setup is starting services' screen. After a while a message will come up saying it cant complete because windows isnt installed. Then it restarts the laptop and does...
The error is in your Operating System or your last Installed Application.
you should do this first.
1.Try boot the computer in Last known good configuration to go back to the earlier configuration when it worked fine.
Keep tapping f8 key when you restart the computer, from the advanced options, select Last known good configuration .
2. Reformat your PC this was the best Solution
Aug 21, 2013 | Acer Aspire Computers & Internet
When I go to start menu to shut down and press shut down it will just reboot and will ot shut down
Step 1:
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Feb 20, 2013 | Acer TravelMate 2300 Notebook
System keeps restarting
try run your sytem repair and if it is not ok re install or reformat your your system!
Feb 05, 2013 | Acer Computers & Internet
ACER 5570 won't load Windows XP keep getting error
Hello shannon_enns,
You might need to go to your BIOS first. When you power on your laptop, keep pressing F2.
Once you're on your BIOS, go to the hard drive & choose "Compatible" since you have Windows XP.
If you have Vista, you'll need to choose "Enhanced."
After that, you may need to reformat your laptop one more time.
Here's a guide on how you can reformat your laptop,
http://helpdesk.its.uiowa.edu/windows/instructions/reformat.htm
Hope this helps & best of luck!
Art Pena
Tech Support
Nov 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3610 wont start up, black screen comes up stating disk error. I am unable to have it start in safemode by pressing F8, nothing happen. THe only thing that does happen is a black screen appears...
The other way to fix it, you need to disassemble your laptop if you've familiar the unit. Usually the HDD has not been attach check the HDD cable (SATA or IDE) replace it. On other hand if the same things happen and you don't have windows CD, it's time to buy an windows CD installer. Reformat your unit to fix the problem.
Regards
PCmania
Sep 28, 2009 | Acer Aspire 3610 Notebook
Acer Aspire SA80 No Sound but drivers are OK.
you frist uninstall the sound device and restart the pc.
Put *********** bord cd now automatically sound device will be installed.Restart the pc again check the sound
May 28, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
My webcam
when did it happened?
1.If it just recently happen, perform sytem restore and select the date that you cam work well.
how to perform this: read here:http://laptop-driver.blogspot.com/2008/09/system-restore.html
2.if you install a program after that the webcam not working it might cause by the software.
Jan 28, 2009 | Acer Aspire 5610-4648 Notebook
Mouse wont work
HAVE YOU CHECKED DEVICES
CLEAN THE MOUSEPAD
ARE YOU SAYING YOUR SYSTEM WON'T RESTART
CHECK MOUSE SETTINGS IN CONTROL PANEL
LET ME KNOW IF IT HELPS
Jan 23, 2009 | Acer Aspire 5050-3242 Notebook
System slows down because of dvd rom problem
I suppose you could try to stop apps starting up with your system, sounds like you may have too much junk running with your system. It could also be that you have some malware on this DVD that's causing you problems.
roger andre
Nov 22, 2008 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
