Question about Kodak EasyShare C340 Digital Camera
Easyshare C340 charging problems
My Kodak Easyshare camera doesn't appear to be charging when it is placed in the charging dock. The camera will not switch on which i am assuming is because it will not charge. Is there anything i can do other than change the batteries??
SOURCE: Battery won't charge on printer dock any more?
I have a similar model Kodak camera. The paper trick did not work but the problem was the same.
I put a piece of tape over the plastic bump on one side of the battery. That pushed the switch in and the battery charges now.
Posted on Aug 09, 2008
SOURCE: kodak easyshare camera dock 11
Not a solution, but just today mine is doing the same thing. Left light is on but not charging. I thought maybe it was the batteries needed replacing, but putting the new ones in did not change a thing.
Do these cameras ever go defunct? Guess I will take mine to a camera shop tomorrow and see what they say.
And I just used it to take a picture the other day. Usually by pressing the left light it stars the charge.. but not today.
Posted on Sep 26, 2008
SOURCE: Charging...Red Light
Check the plastic insert that fits onto the top of the docking station.  Take it all the way off, and then carefully reseat it onto the station.  Make sure this plastic insert is fully seated onto the docking station.  If it's loose at all, you are likely to have the red-blinking light which indicates the camera is not charging properly.
Posted on Oct 27, 2008
SOURCE: My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Posted on Jan 26, 2009
SOURCE: Kodak EasyShare Z760 won't charge.
The problem might be that the battery has developed memory and won't charge further. My first battery used to do that, but then I read that you shouldn't leave the camera on the dock all the time nor keep the battery fully charged all the time because of the problem of developing memory. You might try running the battery completely down by taking pictures until it shuts down. Sometimes when my battery is low the dock won't charge (but goes straight to the red light), but when I run it completely down when I put it on the dock it charges properly. I hope this information helps. :-)
Posted on May 27, 2009
  • 6831 Answers
SOURCE: kodak easyshare ls743. lens wont retract. camera error #E45 shows on screen. battery is fully charged.
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Posted on Dec 14, 2010
0 characters
1 Points
Will the battery recharge inside the camera while it is plugged into a power source?
Kodak EasyShare Z650 zoom digital cameraUser guide
Battery charging options Visit for:
Kodak EasyShare camera dock series 3 - powers your camera, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak EasyShare printer dock series 3 - powers your camera, makes 4 x 6-in. (10 x 15 cm) prints with or without a computer, transfers pictures, and charges the Kodak Ni-MH rechargeable digital camera battery.
Kodak 3-volt AC adapter - powers your camera.
IMPORTANT: Do not use the AC adapter included with the Kodak EasyShare camera dock or printer dock to power your camera.
Mar 22, 2016 | Kodak EasyShare Z650 Digital Camera
Camera-easy shareCX7530
The dock will only charge KODAK rechargeble batteries.
Dec 18, 2009 | Kodak EasyShare Z740 Digital Camera
My Kodak C340 wont charge. Help me
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may require professional repair.
Oct 19, 2009 | Kodak EasyShare C340 Digital Camera
unplugged everything and waited 5 minutes befor replugging everything
Sep 05, 2008 | Kodak EasyShare C340 Digital Camera
Cannot transfer photos from c340 camera
Make sure that the camera has sufficient power when connecting and aslo try connecting the cam w/out the sdcard
Feb 15, 2008 | Kodak EasyShare C340 Digital Camera
Will not charge
1st place to try is the Kodak technical support team on the web site. If it is still under warranty then this will be dealt with. If out of warranty then a low cost replacement may be on offer. A repair does not seam feasible if it is deemed to be a hardware failure.
Jun 16, 2007 | Kodak EasyShare C340 Digital Camera
Can't charge camera on printer dock
go bak to Kodak- looks lick a Dock/Camera mating problem
May 16, 2007 | Kodak EasyShare CX7300 Digital Camera
The only type of batteries that will recharge on the printer dock are kodak rechargables. Just place the camera on the dock and leave it. It should begin charging on its own.
Mar 28, 2007 | Kodak EasyShare Z650 Digital Camera
Kodak EasyShare C340 Digital Camera Logo
43 people viewed this question
Top Kodak Digital Cameras Experts
Are you a Kodak Digital Camera Expert? Answer questions, earn points and help others
