Question about Casio G-Shock GW300CA-1V Wrist Watch
G shock indicator not working - Casio G-Shock GW300CA-1V Wrist Watch
  • 1 more comment
  • biggi1
    biggi1 Jan 08, 2013
    just changed battery and seems like everthing got reset. ive got the xl 100 ga... the eye doesnt show the slines anymore. ho do i change this?
  • biggi1
    biggi1 Jan 08, 2013
    *lines
  • biggi1
    biggi1 Jan 08, 2013
    heres a better pic
  • Casio Master
  • 18,391 Answers
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Posted on Jan 08, 2013
  • biggi1
    biggi1 Jan 08, 2013
    the eye will work if i have the stopwatch running, but it used to have lines through it before i got the battery replaced.
I have G-shock 3011 and it stopped working after a session of sea walk
if you dry the watch out completely and the battery is good it might work again. when the battery is removed there is often a couple of pins you need to short out before the watch will work
http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html
Apr 06, 2012 | Casio Watches
How can unmute my watch. even the alarm tone is on mute.
Um, well I had the same problem on my baby-g watch, but i fixed it so here:
- dunno if this'll work, but hold the bottom left button for a long time. never let go till you here a beeping noise. like DO NOT let go. like this is a g-shock and not a baby-g, i dunno where the mute is indicated, but u might see it somewhere. so, just do that dunno if it works as, again, i have a baby-g. good luck! :)
Nov 30, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
What is the meaning of wr20bar?
"wr" is water resistantance and indicates the degree of protection agianst water entering the watch.
Nov 27, 2010 | Casio G-Shock G2600 watch
Light on g shock does not work
The Casio G shock is the most asked about watch here. It is certainly a very complicated watch. My best advice is to ask Casio directly at the following link:
http://www.gshock.com/support/
Aug 20, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
How do i get the atomic signal indicator to work on a g-shock 2688
Try the manual : - http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2688.pdf
although, unless you're in North America, you probably won't get the signal the watch needs to synchronise.
Jul 30, 2010 | Casio G-Shock GW500A-1V Wrist Watch
I have a g shock riseman g-9200, what does the letters PS mean(just to left of hour in time keeping mode, also is there any indication that i am getting a atomic time keeping signal?.......Thanks.....syd
PS means the watch is in power save mode if there is an indicator under the PS on your watch. this means the watch will go into a sleep mode when it is left in the dark for extended periods. change this setting by holding the top left button until a city code starts flashing, then press the bottom left button until "PSON" is flashing , you can switch between "PSON" and "PSOF" in this way by pressing the bottom right button. i, and casio recommend leaving the watch in the powersave mode though to help extend battery life. I got all this info from my G Shock manual.
Jun 12, 2010 | Casio GShock Riseman AltiTherm GW92001...
Is the battery on the G-Shock MT-G recharge either by motion or sun light?
As you will see from the extract from the web site, these watches are solar powered.
" Tough Solar Power
  • Shock Resistant
  • 200M Water Resistant
  • 29 times zones (48 cities), city code display, daylight saving on/off
  • 4 Daily Alarms and 1 snooze alarm
  • Countdown Timer
    Measuring unit: 1 second
    Countdown range: 1 second to 60 minutes
    Other: Auto Repeat
  • 1/100 second stopwatch
    Measuring capacity: 23:59’59.99”
    Measuring modes: Elapsed time, split time, 1st-2nd place times
  • Auto Calendar (pre-programmed until the year 2099)
    12/24 Hour Formats
  • Accuracy: +/-15 seconds per month (with no signal calibration)
  • Storage Battery: CTL1025
  • Battery Power Indicator
  • Power Saving Function
  • Approx. battery life: 6 months on full charge (without further exposure to light)
    Module 5055"
Feb 03, 2010 | Watches
Casio G-Shock GW-300 2608
Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
After changing the battery I can now press the light switch button and the watch works normally.
Tony
Feb 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio 2654 mtg 901
sounds like it might not be getting enough sunlight. If it has the solar cell in it tape it to the inside of your window for a weekend. If it doesn't charge up the battery enough to make that bar quit flashing then you may need to have the battery changed.
Jan 02, 2007 | Casio G-Shock MTG900DA-8V Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
29 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
