Question about Intel PRO/Wireless 2011B LAN Enterprise Access Point (WEAP2011BRW) 802.11b
My unit does not want to power up. No lights coming on.
The power supply works on another unit.
    Sergeant:
  • 366 Answers
Your AP is dead.
Posted on Jan 26, 2009
Power supply green light comes on but unit does not power up.
When you say 'checked leads' does this mean you checked to see if they were firmly plugged in? or that there was power on the power leads... If there is power, you probably have a 'smoked' drive. If no power on the leads more than likely a blown fuse in your power supply.
May 03, 2015 | Power Computers & Internet
I GOT A YAMAHA SUBWOOFER SW 315 FROM USA WITH 120V RATING. BY FAULT I PLUGGED IT INTO 220V . NOW THE POWER LIGHT IS COMING BUT NO SOUND IS COMING FROM SUB. HOW CAN STANDBY LIGHT COME IF I BLOWN THE...
chances are that you have blown part of the circuitry insode the power supply. The power supply is recieving power, hence the standby light but not giving any actual output. If you are competant with electronics and can work on the power supply safely, take a part the power supply and look for any components which look to have scorching around them and test for operation. Obviously make sure that the units is UNPLUGGED from the mains supply before attepting this.
May 02, 2011 | Yamaha YST-SW315 Subwoofer
Lights dont come on the sliders.
The miniature light bulbs have probably burned out or the power supply circuit to them is not working if it is an older unit; on a newer unit, the leds are probably bad or the power supply to them is not working and will have to be replaced or repaired.
Feb 10, 2011 | Marantz Audio Players & Recorders
Not working or coming on
Check to make sure the power cord you are using is getting 120 volts and that it is plugged in properly to the pc. If you are sure your power cord is powering to 120 volts, plug it in to the computer and see if the power supply light (in the back of the computer) is coming on. If it is, then the power supply is good, if not, you need a new power supply unit. If your power supply does not have a power light on it, listen for the cooling fans to come on when you press the power button, if they don't, it is very possible that the power supply is bad and will need to be changed.
Feb 10, 2011 | Computers & Internet
APC power supply. My backup power supply "online"
How old is the unit? They only last so long before the battery can charge no more.
Dec 30, 2010 | APC Back-UPS CS 500VA UPS System
My xbox is giving me 3 red rings which should mean that there is a connection or hook up problem ive gotten it to work after this once but there were no connection problems then after not playing it for a...
Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
  2. Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  3. Make sure that all three connections are firmly secured.
  4. Turn your console back on.
  5. Check the light on the power supply. If this solution worked, your power supply light will be green....
Dec 23, 2010 | Microsoft Xbox 360 Console
My laptops screen does not come on even though the unit powers up,i have tried another screen,and tried using external monitor,neither worked,the lights by power button also don;t light.
Did you check the power supply? They go bad and if you get no power, nothing else will work. You can check the power supply by plugging the unit into an outlet and then using a volt-ohm meter measuring the voltage at the cylinder which normally plugs into the computer. If there is no voltage (DC) present, then the supply is bad. You can get a replacement online or at the place you purchased the unit.
Feb 01, 2010 | Computers & Internet
Clicking sound when power is off
have the power supply tested or use a diff power supply in your cpu, just to see if the clicking sound will disappear,if it disappear then a power supply replacement would be beneficial, if not then have your cpu check by a qualified tech to see where is that sound coming from
Nov 21, 2009 | Gateway Bestec ATX-300-12EB3 305w Power...
Flickering green light on power supply
power units not working,, the light means power problem you will need to replace the power supplie
Apr 23, 2009 | Computers & Internet
I have a hp pavilion 513c it wont boot up! the
There are only two ways this can go for you.
One- you need a new power supply
OR
Two, you need a new mother board
You can verify the power supply by checking it on another machine
If the power suppy is good
And you do not hear the bios beep- then you are looking at a new motherboard- I would double check the powersupply first- most stores that sell them will let you check before you buy a new powersupply.
Mar 26, 2009 | HP Pavilion 513c PC Desktop
Intel PRO/Wireless 2011B LAN Enterprise Access Point (WEAP2011BRW) 802.11b Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
