Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Hi, I was looking at the menu in my sansa and I press a key by mistake and I locked my sansa. It turns on and turn off right away. What I can I do? Is this an issue that I have to access internaly through windows to fix it?
  • 8,596 Answers
There is a lock switch on the back (or the side?) - consult manual for full details. Manual is available from www.sandisk.com
Support --> Sansa Players --> Documentation and manuals
-Tha Mp3 Doctor
Posted on Jan 21, 2009
My sansa is locked. how do i unlock it
Hi strena2u..
  1. Power off
  2. Turn ON lock/hold switch so it shows the orange
  3. Hold down the "DOWN" BUTTON
  4. Press menu/on while still holding "down" button
  5. Please take time to rate me
Aug 18, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
Hi! I have the same problem wich was commented about the refreshing database screen with my sansa e260 v2, but the supposed solution is i have to turn hold button on, then keep pressing rec, then turn mp4...
Recovery Mode: download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer
Start the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually...
follow instructions on the updater and the sansa.
http://www.youtube.com/watch?v=_95hLqZxCHc&feature=related
here is a link to a kid showing you how to goto recovery mode.
Update software from this link..
(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe)
and install the software before you recover
Jun 15, 2010 | SanDisk Sansa e260 MP3 Player
When turning on the Sansa e260 it is now in the Key LOCKED mode
I had a similar problem with my e250. The problem was that one of the plastic arms on the lock switch had broken off. The one that locked it was still in place but the other wasn't, so I could always lock it but never unlock it.
Since you already know how to open the case, take a look at the switch at the top. Use a pen or something and slide it to the unlocked position (away from the headphone jack). Put it back together and see if it works. If it does, just remember never to lock it again.
Mar 10, 2010 | SanDisk Sansa e260 MP3 Player
I turn it on and the screen is white.
when that happen to me i held the power button and the middle button at the same time for like 15 sec then it turned off  try that  then turn it back on
Nov 09, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa Express mp3 locked. How to unlock n access the mp3 player?
The lock symbol means that the hold is on. Next to the power button is the hold switch. Make sure the switch is away from the power button so that the red is not showing. If the hold is off and it is still showing the hold symbol, then the hold button may be messed up and may need replacing. But first, do this to check that it isn't just malfunctioning: First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
May 31, 2009 | SanDisk Sansa MP3 Player
Does not turn on
try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
if you get it to turn on and the above doesn't work follow instructions below
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
Apr 12, 2009 | SanDisk Sansa e260 MP3 Player
I turn my sansa 280 on, it displays "key locked, system shutdown
there is a hold button on the top of your device. move it to the left and then turn it on.
Mar 22, 2009 | SanDisk Sansa E280 MP3 Player
Sansa mp3 player.
Question: How do I reset my Sansa?
Answer: Press and hold the Power/Menu button down for approximately 15
seconds.
http://www.sansa.com/support/sansa_e200/faqs
Nov 09, 2008 | SanDisk Audio Players & Recorders
Sansa e260 key locked(?)
seems kinda obvious, but did you turn off the hold switch on the top?
Sep 18, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
35 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
