Question about Dual Electronics CECT P168 Cellular Phone
Cect i9 slide to unlock will not open
I recently bought an i9 cell and Iam already having problem. the slide to unlock feature will not work. the slide to unlock feature will appear for about half a second butwhen i try to "slide" it open it disappears. Is there a reset button somewhere on this type of phone or is there a"trick" to bypass this feature? If there is anyone that can help pleeeeeeaaase do. thank you
  • 13 more comments
  • Anonymous Jan 27, 2009
    Could you find the solution? i have the same problem
    Plase help.
  • Anonymous Jan 28, 2009
    Hey, I have the same problem, with the slide not working so you can access the phone. thanks
  • Carpenter212 Feb 08, 2009
    I have the same problem. The unlock function gave up after two days!!! Is there anybody who has a solution besides throwing away the phone?
  • kristalynnd1 Feb 10, 2009
    I'm having this problem too only the screen saver appears so fast that i dont get a chance to slide it to unlock. i've had this phone for like 2 months no problems then today it started this, i've changed batteries, charged it, left it off, still nothing. it'll accept incomming calls but i can't call out.
  • i2ozt Feb 12, 2009
  • chuck_farmer Feb 17, 2009
    My I 9 does the same thing but I am able to unlock after I reset the Stylus
  • texascampgal Feb 19, 2009
    There are touch screen calibration instructions on the inside of the battery cover, but they will not work for me.
    I'm having the same problem.
  • bdmoore Feb 22, 2009
    Can ANYBODY help me, I need to reset this phone the slide to unlock will not open the screen saver don't let me do it. anybody knows a SOFTWARE that I can use for this because by the phone is not useful. This I9 SUCKS!!!!!
  • dasungod Feb 26, 2009
    The exact same thing and the phone is only two months old as well.
  • wvwineguy Mar 23, 2009
    I bought 3 I9's in Dec 2008. March 2009, 2 are not working and the other is so flaky that no one will use it. JUNK!
  • Anonymous Mar 30, 2009
    I have the same problem, I can't get into my phone. Can't unlock it HELP!!!!!!!!
  • otislafayett Apr 05, 2009
    Incoming call and it pops up "slide to unlock"? Many times by the time you are able to actually do the slide it's too late. How do you turn off this "feature"?
  • Anonymous Apr 14, 2009
    i have the same problem- the slide to open function stays on for a few seconds and then disappears before you can open the phone
  • drice830 Apr 21, 2009
    here also, and the instructions on inside cover do not work
  • Anonymous May 11, 2009
THIS WORKED FOR US: Hold down the power button until you see the "CANCEL" icon; tap around the screen until the "CANCEL" button turns blue - this will take you back to the slide feature. MAKE NOTE OF WHERE THIS SPOT IS ON THE SCREEN. Repeat the "cancel-screentap" process to find a 2nd spot in another area of the screen. While on the "slide" screen, draw a line between the 2 spots; when you return again to the "slide" screen, the "slide" should work.
ONCE YOU HAVE OPENED THE PHONE do 2 things:
  1. RECALIBRATE the screen
  2. LENGTHEN the screen saver time-out to something other than the shortest time available.
Hope this works for you - GOOD LUCK!
PS - dunderground posted the following solution in Apr 2009:
"The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until "Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen, immediately press the side volume button in the down position. A white calibration screen should now show & you can calibrate the touch screen using the stylus."
Posted on Oct 14, 2009
My i9 will not unlock from the wallpaper page, can any one help me
Posted on Aug 25, 2009
Maybe you can reset the phone to the fabrik settings... in te menu with settings, anybody tryd it already or?
I'm trying to unlock the CECT I9 so that i can change the backgrounds etc. but with no succes already.
But just try to reset the phone in the phone settings menu.... if that dont work just get the battery out when the phone is on. that maybe works, else i dont know what the problem is, maybe then you can read the manual for reset the phone.
I dont have that problem, but if my phone is doing nothing any more, then i just get the battery out when the phone is still on, than restart your phone and than is the problem fixed.
I hope it works!
Greetzzzz
Blackdog
Posted on Feb 20, 2009
SLIDE TO UNLOCK ON MY i9 WON'T OPEN MY PHONE
Posted on Dec 30, 2009
My iPod won't change can you please help me thank you xxx
Posted on Apr 24, 2011
  • 1 more comment
  • Linda shaw Apr 24, 2011
    Download cydia from app store press search Type slide to unlock text done xxx
    **** **** birtch
Just got my i9 charged batters but it wont come on what am i doing wrong help
Posted on May 08, 2010
Once I power on the phone, I have to wait for several minutes before I try to open the screen. After a few minutes the slide works and I am able to slide between screens with no problem. Every click requires patience. This phone is slow to respond, but works well once you accept the fact that you have to wait. Don't try to rush, it will crash.
Posted on Jan 22, 2010
Im having a problem with the screesaver too i cannot open my phone and i've tried everytrick on this forum....can anyone help with an over all reset or does ne1 know of any tricks to solving this problem cus i know i'm not the only one
Posted on Apr 26, 2010
    Problem Solver:
  • 20 Answers
Hi
Thanks a lot RJ318. This worked with my mini i9. Thanks, thanks a lot.
Posted on Nov 13, 2009
Not recieving call having problems making calls poor reception? everywhere
Posted on Jan 10, 2010
  • 11 Answers
Is their a way to hard reset these I9 handsets the sim2 will not read any cards I believe I need to hard reset the ahdnset so I can use it.
Posted on Jul 20, 2009
How do i unlock my sciphone i9
The SciPhone i9 is not locked to a specific carrier from the factory. That is, it comes from the factory SIM unlocked.
Jan 27, 2010 | Dual Electronics CECT P168 Cellular Phone
I recently bought a sciphone i9++ and i dont know how to install java...Can yu give me the step by step procedure on this
You don´t need to install java. It is already installed.
Just put Java applications (jar files) into the Java folder and run them by double clicking.
Oct 18, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I have a CECT Phone i9 and the slide wont unlock...?
you can try to reload that particular file it might have been corrupted it happens with thoses phone under certain circumstances
Jun 26, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I9 cect
When you first get it or if you change it to factory settings it will do this until you change the pen calibration. Just keep working at it its just not very sensitive till you do that. I had the same problem but was able to get it so just keep working at it.
Jun 07, 2009 | Dual Electronics CECT P168 Cellular Phone
I purchased a unlocked cect i9 and it states to insert sim card how do i unlock phone?
This phone is NOT 3G compatible (it's just it's name ...) if your Tmobile card is 3G it will not work. All CECT phones are factory unlocked !
Jun 01, 2009 | Dual Electronics CECT P168 Cellular Phone
Can't get into my i9 phone
send it back, these phones are COMPLETELY worthless wihout the touch screen. the person i bought my phone was always happy to helpme out, hopefully yours is too.
Apr 21, 2009 | Dual Electronics CECT P168 Cellular Phone
Need wap settings for unlocked cect i9
Go to Main menu> Services>Data Account>GPRS
Select a profile and select "Edit profile"
Enter the following settings
APN: wap.cingular
user: WAP@CINGULARGPRS.COM
password: Cingular1
Go to Main menu>Services>WAP>Settings>Edit profile
Select a profile and select "edit profile"
Enter in the following settings
Homepage: www.google.com
Data account: GPRS>Cingular
Connection type: HTTP
password: Cingular1
Then to browse, Go to main menu>Services>wap>homepage
You may get an error "Unsupported scripts in content" Just click ok.
If you have more problems let me know, we may have to tweak some things if you don't have a data package.
Jan 19, 2009 | Dual Electronics CECT P168 Cellular Phone
My i9 phone's slide to unlock feature wont work
THE I9 IS A JAVA BASED JAVA APP PHONE THE JAVA APP THAT RUNS THE SLIDE TO UNLOCK FEATURE HAS MALFUNCTIONED THE ONLY WAY IS TO HAVE A TOTAL FIRMWARE RESET BUT AT THE MOMENT CECT ARE NOT SUPPORTING THIS YOUR ONLY HOPE IS TO CONTACT THE SELLER OF THE PHONE AND TRY TO GET A REPLACEMENT HOPE THIS IS OF SOME HELP THERE IS A CECT FORUM IF YOU SEARCH GOOGLE
Jan 19, 2009 | Apple iPhone Smartphone
HOW CAN i FIX M I9 phone/
is it stuck..like the slide feature wont let you slide to get to the main menu??? Mine did this and it lasted for almost a day..i had top take the battery and sim card out and keep putting them back in and keep turning it off and on and eventually it became unstuck. and has worked since and not gotten stuck..if its not that then let me know..also
Jan 09, 2009 | Dual Electronics CECT P168 Cellular Phone
Dual Electronics CECT P168 Cellular Phone Logo
3,766 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Michael Terence...
Michael Terence...
venugopal durairajan
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
