Question about Genuine Konica Minolta Konica Minolta Bizhub C220,c280,c360 Genuine Fuser Unit A0edr72022
Fuser on C220 Konica Minolta
Printer is not fusing correctly on card stock; prints fine on 28 lb plain paper. We have tried every brand of card stock we can purchase all with the same problem result.
  • 19 Answers
Use the setting thick 3 its the catch all for weird issues. make sure the paper is not coated also. if that still does not work you can go into service mode and bump up the fuser temp , its the number 1 button(machine).
Posted on Oct 19, 2013
Hi toner doesn't fuss on the paper. what could be the problem or settings can anyone here help. its konica minolta C6000
Is the fuser running hot at all? It should throw a C-Code
Or is your paper type settings correct? Are you running Thick Card stock on plain paper? If you do the fuser is not keeping up with heating up the temperature required to melt the toner to the paper.
Aug 15, 2017 | Konica Minolta Office Equipment & Supplies
Why does my Konica Minolta 1690MF have a fuser jam error whenever I print in color?
Everything you checked sound good. Might be printer software problem, and needs to be re-flashed. Software only available from secure web site that a technician would have, see what it cost if to much buy a new one with extra bells and whistles !
Jun 18, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Color print not coming proper on 300 gsm cards
Well, I think that is over spec for your machine. Are you using a coated stock? What type, gloss, silk, matte? Is your paper cut 18 x 12?
Mar 22, 2014 | Konica Minolta Bizhub C220 Color Copier
Fusing heater trouble konica c220
You need to change the thermistor on the fuser unit.
Sep 11, 2013 | Konica Minolta Bizhub C220 Color...
I'm printing on 110 lb card stock and the toner gets crispy..and actually flakes off on the edges and sometimes leaves smears and clumps of black or burnt toner on the paper. It prints fine on 20 lb paper...
could be the fuser but there is a setting for heavy paper or card stock which will slow it down and increase the heat. depends on your model as to where this can be changed.
Jul 27, 2017 | HP Color LaserJet 2600n Printer
Trouble printing Clean Edge business cards
not tru. you need to go to printer set up and chane the setting to heavy paper so that the fuser will fuse the toner in to the card stock
Dec 03, 2008 | Brother MFC-465CN InkJet Printer
Printing on Card Stock
Hi Harold,
Most laser printers automatically adjust not the temperature so much as the speed at which the media travels through the fuser when thicker stock is used.
The important thing here is to make sure that when you are using card stock that you insure that the printer is set for the correct "PAPER TYPE" from the tray you are using.
When the paper type is set to card stock, you should notice that the media will print somewhat slower, thus giving the fuser the ability to achieve the correct fusing temperature through the thicker stock.
Good luck
Oct 09, 2008 | Konica Minolta PagePro 1350W Laser Printer
Printing faded color text on my color paper...
That stock might be too heavy for a bizhub.
Specifications state the following:
Plain paper (16 lb to 24 lb),
thick paper 1 (24-1/4 lb to 40 lb),
thick paper 2 (40-1/4lb to 55-1/2 lb),
thick paper 3 (55-3/4 lb to 68 lb),
thick paper 4 (68-1/4 lb to 72 lb)*, OHP transparencies*, postcards*, letterheads,
colored paper, envelopes*, label sheets*, banner paper (24-1/4 lb to 55-1/2 lb)*
Duplex: Plain paper (17 lb to 24 lb), thick paper1/2/3 (24 lb to 68 lb
*Can only be fed through the bypass tray.
These specs are directly from the user guide.
Is the paper running through the bypass tray?
Jun 09, 2008 | Office Equipment & Supplies
Printing avery labels
You need to change the paper settings from plain to something thicker. The toner is not being heated properly for it to fuse to your paper. It needs to run at the correct speed and temperature in order to adhere properly.
Set it to a heavier stock.
Apr 29, 2008 | Konica Minolta magicolor 2430 DL Laser...
Genuine Konica Minolta Konica Minolta Bizhub C220,c280,c360 Genuine Fuser Unit A0edr72022 Logo
166 people viewed this question
Top Genuine Konica Minolta Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Genuine Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
