Sagemcom dtr67320t 320gb hard drive replacement
3 Suggested Answers
JimBelushi
  • 19 Answers
SOURCE: have hp a1240n media center pc. hard drive failed
You can recover data from hard drive with data recovery software.Then format the drive toget it fixed.
For data recovery program,here are two of the best Iused.
For Windows: http://www.any-data-recovery.com/index.htm
For Mac: http://www.stellarinfo.com/mac-data-recovery.htm
You can download one of them and scan your hard drive for free to previewwhether your files can be recovered. They will show you the file name, type, dateand of your files and thumbnails for your pictures that it found on yourdrive.
Posted on Sep 26, 2011
bronk50
  • 27725 Answers
SOURCE: my seagate free agent 320gb hard drive won't power on
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if this fails to fix the problem
check usb leads for secure dust free seating
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Jun 19, 2012
I have a MSI CX420 laptop with 320GB hard disk, can i replace the 320GB hard disk to 640GB toshiba hard disk?
Hi znehbeurt_12
Yes you can replace your 320 for a 640 hd....
It will partition itself at the start when you install your operating system
Please rate me
Bud
Sep 25, 2012 | MSI 500GB Hard Drive for CR400, CR410,...
Have hp a1240n media center pc. hard drive failed and was replaced with 320GB hard drive & windows xp pro by local repair shop (no xp disk) shop is gone; computer loads, but now says windows not valid...
Sep 26, 2011 | Computers & Internet
Is Hitachi 320GB SATA 2,5"
you perches ata to sata connector or sata to ata connector
Sep 07, 2011 | Hitachi 320GB SATA 2,5" HTS543232L9A300...
Lost power cord for simpletech pininfarina 320gb external hard drive. Where can I buy a replacement?
Hi
Please the the adepter for the mention below Inputs
Input 1000-240v-1.0aMAX
50-60Hz
Output +12v 1.5a
that's help u
May 05, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
The 320GB does not seem to connect with my laptop. The blue circular lights come on just briefly when the power is turned on but then are replaced by a single red light that also goes out soon thereafter....
Looks like the power of your external drive is not functioning very well. Mostly with this kind of issues, it needs a port replacement or the external drive cable, and if it still does not work, then a complete external drive replacement maybe needed.
Jul 18, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Simpletech Signature Mini not reading
It is easy, just conect it to the motherboard as a slave disc
Sep 04, 2009 | SimpleTech Signature Mini 320GB External...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
Simpletech 320GB BOM No.: 96300-41001-012 is new has never worked
The original power supply is "SB2D-020-1HA SIMPLETECH AC ADAPTER 12V 1.5A FOR EXTERNAL HARD DRIVE" . Just find a replacement with the correct size plug (center positive) that supplies 12v DC at 1.5amps (1500ma)
Mar 10, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Western Digital 320GB USB 2 My Book External Hard Drive
ALL hard drives need to be formatted... The question is, why wasn't this hard drive already formatted when you bought it?
Jan 09, 2009 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
