Question about Microsoft Windows XP Home Edition
Task manager has lost it's headings
My windows task Manager has lost its headings, The close, minimise, restore buttons and also the "Resources, Programs and Processes etc headings". It is stuck in Resources. I have to shut down to remove the page. There are 3 users of the PC. The other two can get Task Manager quite OK. Any idears how I can fix it?
  • Microsoft Master
  • 2,878 Answers
It's running in tiny mode. Double Click on the top right corner or near the top. It is something simple, but it has happened to me as well.
Posted on Jan 08, 2013
Testimonial: "perfect advice. Thank you"
3 Suggested Answers
  • 50 Answers
SOURCE: open task manager and only get list of processes, no other option
Double click the border around the task manager window.
Posted on Mar 16, 2009
efs_perpends
  • 1996 Answers
SOURCE: Missing taskbar button
Take a look here:
http://www.vistax64.com/tutorials/151890-taskbar-toolbars-enable-disable.html
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 08, 2009
Don't have a an icon
Please give more details as to what is happening and when it happens?
If you are saying your computer boots up but there are No Icons on the desktop, then a virus or infection has hidden them or changed some settings.
Click the Ctrl/Alt/Del keys to start the Task Manager. Press and Hold the Ctrl and Alt keys then hit the Del key. When the task manager opens up click the Processes tab. Under the processes tab click the columnar heading Image Name to sort the items running in alphabetical order. Look to see if you see explorer.exe running under the image name. If you do click it one time to highlight it then click the END PROCESS button at the bottom right of the Task Manager Window.
Next click FILE at the very top left corner of the Task Manager Window and select New Task (Run..). When the Create New Task window pops up type in: explorer.exe and press OK. Your desktop icons and start menu should start populating.
Apr 18, 2012 | Computers & Internet
Lost start button and icons
Are you saying there are no icons on yourdesktop and the start menu is missing? If so try this: Click Ctrl+Alt+Del to get the task manager to come up. Press andHold each key (Ctrl+Alt) until you hit the Del key, then you can release them.
When the task manager opens up click the Processes tab. You can click theImage Name column to get them in alphabetical order. Look forexplore.exe, if you see it listed click it once to highlight it then click theEnd Process button at the bottom right portion of the task manager window.
Next click File at the very top portion of the task manager window on the leftand select the option New Task (Run). When the Create New Task window openstype: explorer.exe and press OK. Your items will start populating andappearing on the desktop.
Mar 29, 2012 | Computers & Internet
I can't successfully install the yahoo messenger after being lost in the program
1. Reboot your computer.
2. Press Ctrl+Alt+Del on your keyboard. This will bring up the Windows Security window. Click the "Task Manager" button and then click the "Task Manager" tab.
3. You will see a list of files/applications. These are the applications running in the background on your system, whether they show on your taskbar or not. Any one of these applications could be causing a conflict with the Yahoo! Messenger installation.
4. Click the top item on the list to highlight it. Then hold the "Shift" key down and click the last item on the list. This should highlight the whole list.
5. Click the "End Task" button. This will temporarily close all background applications on your system.
6. Click the "X" in the upper right corner to close the Task Manager window.
7. Install Yahoo! Messenger. You should not experience the same issue that you had before.
8. After Yahoo! Messenger is installed,run registry cleaner reginout also reboot your system. All other background applications will return to their original configurations.
Feb 07, 2011 | Yahoo Messenger
I have lost ALL of my taskbars!! How do I get them back?
A program called explorer.exe controls the display of your taskbar and desktop icons. If for some reason it goes missing (you may have killed it using Task Manager, for example, or something more sinister like a virus has deleted it from your processes), then try this first:
  1. Open Task Manager (press Ctrl+Alt+Del, then click Task Manager).
  2. On the Applications tab, click New Task at the bottom right of the window.
  3. Type explorer.exe, then click OK.
If nothing sinister caused it to disappear, it should all come back as it was and you can stop panicking, breathe a sigh of relief, and continue working.
If that doesn't work, then try this:
  2. Go to the Processes tab.
  3. Click on the Image Name column header to sort the list alphabetically.
  4. Find all explorer.exe processes - select each, then click End Process for each one.
  5. On the Applications tab, click New Task at the bottom right of the window.
  6. Type explorer.exe, then click OK.
Are you using snagit, try to uninstall it and then check if you still get the errors. If you donot use snagit then there would be another error.
If you cant access control panel use the "Windows Key+R" on the keyboard which opens the run dialog and type in 'sysdm.cpl' which opens the control panel.
You could also try to restore you windows using System Restore and select a date of the backup when the computer was working well.
Make sure you do a complete virus scan with a good antivirus with updated virus definitions as it could be a virus too.
Jan 21, 2011 | Computers & Internet
I lost my taskbar and start
press CTRL-ALT-DELETE, then select TASK MANAGER.
in the taks manager window, select FILE, then RUN.
type in the word "explorer" and press enter.
this should restore your task bar
Oct 18, 2010 | ASUS Essentio Desktop with Intel Pentium...
How do I turn task manager ON?
Hi, It can be due to virus issue. Kindly have an Anti-Virus installed and then try.
Jul 15, 2010 | Microsoft Windows XP Professional SP2
I keep receiving the error message that Adobe Updater is running and should be closed. I ran a search and I can't find Adobe Updater on my PC.
Hi. Just press Ctrl-Alt-Del, select Task Manager Button to open the Windows Task Manager. Go to the Processes tab, look for these image names and terminate (end process) them:
adobeupdater.exe or Adobe_Updater.exe
Close the Windows Task Manager and you're done.
Hope this helps.
Aug 29, 2009 | Adobe Photoshop CS4 for PC
I was lost my task manager in vista home basic how can i get it again pls help me
Hit the start button and type "taskmgr". That should bring up your task manager.
Apr 22, 2009 | Microsoft Windows Vista Ultimate Edition
System Restore
try geting the task manager i belive tthts del+alt+cntrl (i have a xp but am not tht sure abt vista)
so after getting the task manager try clicking on new task from the filemenu then typein
explorer.exe andhit enter should work
Sep 26, 2008 | Acer Aspire™ T180 PC Desktop
Minimised
You can Alt+Tab to bring back up a minimized application, or use Task manager to switch to that application (right click on the task bar and select task manager to start it)
I hope this helped...
Feb 28, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
102 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
