Question about Wacom cintiq12wx Cintiq 12wx 12.1" Interactive Pen Display
Cintiq 12wx with broken display
Broke my display,. ( only upper part, video display is fine ), local reseller ( in Denmark ) will not support producst outside warranty or advise any servicecenter . The screen is easy replaced, is it possible to buy this as part.
techie2050
  • 126 Answers
SOURCE: Cintiq 12WX screen not working :(
may be the power chord is damged go to a nearby shop and tell tham to give you a new power chord of monitor and then try it should work fine
thank for visiting fixya
have a nice day
Posted on Feb 19, 2009
  • 3 Answers
SOURCE: Hi, having problems with my
Hey guys,
I have posted the solution to this problem (or my version of a solution) elsewhere on this site - but here it is again, just for you!
I had a similar problem with my cintiq 12WX!
The way i did it was by going into CONTROL PANEL (please note i am using XP windows), then into DISPLAY, then into the last tab on the right aka SETTINGS. Once in SETTINGS go into the ADVANCED section, then click on the DISPLAY tab. In here you should have 3 things - monitor, panel and tv. The tv bit is irrelevant. Look at the MONITOR and PANEL tabs, if your wacom IS set up correctly when you click on the button (it is a circle with a line inside it) on the title (it will either be greeny/turquoise or red). If it is red, click it and the same button on the panel title will turn green aswell. Below the pictures of a computer and a laptop there should be 2 buttons that are the same for each. Currently, my almost working cintiq is set to having the button with two squares on it under the heading of 'MONITOR' and the button with a circle is on under the section entitled PANEL.
If this doesn't work I dont know what to suggest.
Hope this helps.
M
Posted on Mar 26, 2009
SOURCE: Wacom Cintiq 12WX
I had the same problem with the "signal out of range" box in the middle of the screen. I went to Display on Control Panel and clicked the Settings tab. Click the monitor icon for the Wacom tablet in the window (if you are using more than one monitor) and set the screen resolutioin to 1280 by 800 pixels. The "signal out of range" box disappeared.
Posted on May 07, 2009
SOURCE: Cintiq 12wx
I was just having this same issue.
My 12 inch Cintiq has always worked properly until I turned my laptop on today (windows XP). The Cintiq said "no sync" and went to sleep immediately. I checked all of the plugs.. turned it on and off, restarted my computer.. did just about everything I could think of.
I found my way here and tried the other solution above with no luck... however, it led me to another solution... which was super easy.
Somehow in my Control Panel-Display-Settings the box that says "Extend my Windows desktop onto this monitor" was unchecked. I'm not sure why it decided to uncheck itself randomly.. but I clicked on it and then hit "Apply" and waa laa. It's working again :)
Posted on Oct 03, 2009
  • 3 Answers
SOURCE: I just got a cintiq
I had this same problem and just had to go into my system preferences on the imac and select display and then select/check the mirror monitors and now it is on sync-hope that helps! After I did that though my color is off on the cintiq so I am looking for suggestions on how to fix it as the calibration did not fix the problem.
Posted on Feb 23, 2010
My Cintiq 12wx is suddenly yellow-tinted
Did this problem get fixed? I am having the same issue :(
Sep 04, 2012 | Wacom Cintiq 12WX Interactive Pen Display...
Wacom cintiq 12wx calibration
I had a similar issue using the 12wx with a 15" MacbookPro Retina. Screen displayed the desktop way too much to the left. I found that the refresh rate of 59.8 hertz seemed to not be compatible despite it automatically being set. After changing this to 74.9 Hertz, the desktop is now properly centered on the Wacom screen and can be calibrated now. Not sure if this applies to Windows machines but perhaps something to keep in mind.
Jun 09, 2012 | Wacom Cintiq 12WX Interactive Pen Display...
Connect 12wx via usb, no picture displays
see the link below.(in Japanese)
http://tennaru.blog97.fc2.com/blog-entry-160.html
DVI-USB converter(I-O data: USB-RGB/D2 ) seems to fit with Cintiq12wx.
Dec 19, 2010 | Wacom Cintiq 12WX Interactive Pen Display...
I've had this same issue! My Wacom Cintiq 12WX tablet has been having this "Signal out of Range" issue all of the sudden with my Mac OSX Laptop. I've bought and tried new DVI cables and...
Hi 13ambreuer
is a problem between the graphics card, monitor, motherboard or graphics card port.
if you have to do troubleshooting on the monitor and display card, proved no problem to it. This means that the problem now is the motherboard and graphics card port.
(But should remember, problems ram, power supply and processor also causes the same error) * Sometimes *)
mean here you have to do the troubleshooting on all hardware on your computer
thnks&regards
Dec 08, 2010 | Wacom Cintiq 12WX Interactive Pen Display...
Cintiq 12wx
I had a similar problem with my cintiq 12WX - i have managed to sort this problem.
Hope this helps.
M
(p.s. you may have to improvise with the settings in the display bit to get it to work).
Mar 18, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
have a nice day
Feb 19, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
Problem with Cintiq 12wx
Hi...there Jenn!
Go to your toolbar bottom r/h side, look for VGA Display Icon. Open it and look for dual monitor setup. It's might be what you has been looking for... If not, read your cintiq user guide... Have a nice day!
Feb 03, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
Hi, having problems with my cintiq 12wx. It is only working as a tablet right now. Using my pen on the cintiq, and it just moves the cursor on my other monitor. I can't transfer anything from my monitor to...
Hey guys,
Hope this helps.
M
Wacom cintiq12wx Cintiq 12wx 12.1" Interactive Pen Display Logo
44 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
Ed Mac
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
