Question about HTC Rhyme
Htc rhyme is not opening with passcode?
When i enter the passcode it is not open
    Master:
  • 520 Answers
Hello My Dear Friend::
defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Jan 08, 2013
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
Why contact list is not opening ?
JUST UPDATE WITH LATEST FIRMWARE
May 14, 2014 | HTC Rhyme
Htc rhyme camera won't open
Hi pls factory reset or costom recover the ROM (if its rooted) the unit and try once again if it won't work the hard luck your h/w is faulty, go and find a good repair shop. :(
Feb 10, 2014 | HTC Rhyme
Restore the phone
HTC Rhyme has hugely potholed OS. There are many faults with the hardware itself. The maximum life expected of this device is around 2 years. Having said that, try factory reset. Also, if your device is old and beyond warranty, you might also choose to root your phone with custom ROMs available on the internet. I have chosen the same solution for my gf's phone, which tends to run extremely smooth since. Try Googling for xda forums HTC Rhyme custom ROM
Oct 23, 2013 | HTC Rhyme
Too many times pattern attempts
If you can't open your phone through Email and Password, you have to root your phone or re-install the Android OS, eg Ice-cream sandwich or Gingerbread
Oct 20, 2013 | HTC rhyme S510b purple unlocked gsm phone
Get htc rhyme out of safe mode
How do you turn the HTC RHYME out of safe mode!
Aug 15, 2013 | HTC Rhyme
It doesnt open with passcode
Hello My Dear::
Jan 08, 2013 | HTC Rhyme
How to unlock your screen on HTC rhyme
Hi, if you mean network unlock, you can use the solution available here: http://www.fastgsm.com/en/htc/htc/rhyme/unlock-code
Jun 08, 2012 | Cell Phones
My HTC magic mobile Bluetooth is not working
Hello
What you have to do is to is to open the bluetooth menu on your HTC phone and touch the bluetooth logo to put on the bluetooth radio.
Highlight add a new device,your HTC phone will search for bluetooth device that are within that range and when you see the name of your bluetooth device appear on the screen press next.
Enter the bluetooth device passcode,this can be found in the device owners manual.if the passcode is accepted then press done.The pairing process between your HTC phone and a bluetooth device is complete.
BEST OF LUCK
Jul 06, 2010 | Cell Phones
How to connect htc touch p3452 to laptop as modem to connect to the internet using bluetooth.
you should have a inbuilt bluetooth or external bluetooth for connecting your HTC mobile to laptop. If you have inbuilt bluetooth then just open the bluetooth software and turn on bluetooth on your mobile also. Pair both devices it will ask you to provide a passcode provide 1234 then it will prompt for password on your mobile enter 1234 and follow the instruction it will connected to internet. If you have external software then download the bluetooth software and follow the same steps as in inbuilt bluetooth.
May 17, 2010 | HTC Touch P3452 Smartphone
HTC Rhyme Logo
53 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
