Question about Whirlpool WED6200S Electric Dryer
I have a whirlpool cabrio dryer. The grey lever broke on the start button. I took the top panel off and super glued the piece back together. After the glue dried, I put the top back on and dried a load of clothes. The next day however I tried to dry something and it would not come on. The start button is still fixed and it clicks when I press it, but nothing happens. What could have happened within a few hours to stop it from drying?
  • 14 Answers
SOURCE: dryer will not dry cloths
Did you check the relay switch?
Posted on Sep 03, 2008
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
  • 198 Answers
SOURCE: LER8858EQ2 electric dryer will not come on.
Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
Posted on Jan 07, 2009
  • 6784 Answers
SOURCE: Clothes Not Drying well
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Posted on Jul 31, 2009
  • 396 Answers
SOURCE: Nothing happens when I push the start button.
There is a micro switch on the door to stop the dryer when you open the door during normal operation. Unplug the dryer and locate the switch by visually inspecting around were the door contacts the dryer and identify if you can remove the switch without opening the dryer top. If you cannot remove the switch from the front try to access the switch by lifting the top of the dryer cover off. Unplug one of the wires and touch the wire connector you removed to the other connector on the switch using electrical tape to insulate and hold it in place. Plug the dryer in and see if it works. If it does you need to order and replace the switch. If it does not the start switch could be bad and you will need to test it with an Ohm Meter which will be the safest way to test the switch.
Posted on Jan 21, 2010
Testimonial: "I appreciate the quick response on the problem with my dryer. The clear instructions will give me the ability to check it out. Thanks!"
Dryer super loud
This may be a structural defect and not repairable.
Sep 20, 2017 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio dryer has power but won't start
You may have a burnt out terminal block or start switch.
May 12, 2012 | Whirlpool WGD6400S Gas Dryer
Our Whirlpool Cabrio Elecetric dryer will not start. Model is WED6200SW1. We had just finsihed drying a load and put a 2nd load in, but it won't start. All the light come on. Could it be a sensor...
it could be that or it could be the start button, you can check the button by adding a jumper in the wires that go to it,, this should be done as a check and not left that way,, for safety
Jul 03, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer will not turn on. Start button light is blinking. All other lights functioning.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Apr 22, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a cabrio dryer and it will not start. It
control panel is bad, use your warranty and get it fixed for free since it is only 2 weeks old
Jun 15, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Seam is coming "unglued" in my 2001 VW Cabrio Convertible Top
I replaced mine 2x on a cabrio 2000 in Miami. Then I went to a local upholstary store and they stiched the hood for approx $250.- it has been fine since.
May 24, 2009 | 2001 Volkswagen Cabrio
Fixing the broken door.
the hook part points to the right because it has to engage the electric lock which is the right, in inside of the machine.
Dec 25, 2007 | Splendide 6200
How to open the case of the speakers?
since u hav removed the mesh and the 4 screws that hold the case of the speaker .As you said that the speaker has no opening points , most companies manufacture the speaker by sandwiching two parts together. In order to open the case of the speaker , you will have to see for a joint line on the edges . it indicates the attachment between the two parts of the speaker . If you find an opening at the back of the speaker as you have mentioned , try to remove the two joints of the speaker by pulling gently at the opposite ends .
Jun 20, 2007 | Altec Lansing 221 Computer Speakers
Whirlpool WED6200S Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
