Is this tv hdmi?
Bought this tv off a guy who said it was great - just had to be set up. The picture is terrible - tried many times to set colors by the book - doesn't work. Now he says we need to connect an hdmi cable to it. There deosn't seem to be a place to connect this. Can you please give some suggestions? Thanks
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
What is the Brand name and Model number to your TV? Just download the user manual to it by internet and check it. It will have all details about its input incompatibility.
Posted on Jan 08, 2013
SOURCE: HDMI input not working
I had the same problem with my 50 zenith when it was new. It needs a HDMI board replaced.
Posted on Jan 18, 2008
  • 105 Answers
SOURCE: JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Posted on May 06, 2009
phongnv
  • 56 Answers
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
Posted on May 12, 2009
SOURCE: LC32OEM9 says Not Supported Format on HDMI Input.
my playstation3 was hooked up on mine with hdmi, i only recived the message once. i turned the tv off then unplugged the hdmi cable and reconncted it, turned the tv back on and it has been fine ever since.
Posted on May 19, 2009
SOURCE: no sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Posted on Jun 03, 2011
All of a sudden, no sound on PS3, great pic though. Using HDMI cable...have checked all connections, reset PS3, etc. Still no sound! Guy from Sony said my HDMI cable(Monster) could be bad?! No sound, but...
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
Jul 17, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Jun 05, 2009 | LG 37LC2D Television
Vizio with terrible color
YES. Take it back. Also take your DVD and cables also. Have the store try the tv with their DVD and cables and see if you get the same problems. It it good, then try your cables. Or try your DVD with their cable. It's under warranty now so resolved it now. If you bought by credit card, that may have a brief warranty also.
Mar 04, 2009 | Vizio L32 32 in. LCD HDTV
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
Grainy LCD display
Are you in night mode? Sounds like you are in a high gain setting, like ISO 3200 or night mode.
Jul 17, 2008 | Canon PowerShot SD1000 Digital Camera
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
Only HDMI2 input works
try attaching all the sources you have to hookup, have the power on , on each unit and then go into tv menu and run auto program. if this is no help your tv may just need a firmware/software upgrade, I don't know if they give the download to the consumer or not but if the auto programming doesn't work call LG @ 800-243-0000 tell them your problem, 4 days old really don't recomend having extensive service work but it is under factyory warr. so you have the option but if they think it's the firmware upgrade and you have a usb flash drive they may send you an email with the software.
Feb 29, 2008 | LG 50PX4DR 50 in. Plasma TV
Philips lcd flat 32 in
what cable are uusing for dvd yello thats why cant use yello on these or s video go buy hdmi cable ok or reg green blue if dvd dont have hdmi outs
Feb 09, 2008 | Philips 23PF5320 23 in. HD-Ready LCD...
Just bought 42" Aquos but has bad picture quality in Analog & Digital cable
There is no secret to adjusting the picture settings on this unit. My unit is perfect with Hi Def signal and better with Blu Ray. I assume you are using HDMI cables and have tried a new HDMI cable to eliminate the possibility of a bad cable. If you have done this then the unit has a problem and I would take it back or contact Sharp to get an auth. service center involved.
Jan 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
It wont run through HDMI
Follow the guy aboves solution to reset your Ps3 to 480i. Turn the power to the system off from the switch on the back and then when you flip it back have the power button held down on the front of the system. This only resets the picture doesn't change anything else or erase any games, I had to do it and it works!!
Oct 22, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
