Question about Acer Aspire 5920-6727 Notebook
I can not get my Acer Aspire 5920 to load after turning on.
I turn on and the monitor shows "Acer" then attempts to load but only shows black screen. Will not load windows???
  • 3 more comments
  • fireman-134 Jan 20, 2009
    I did the ALT plus F-10 now it shows Please wait....how long do I need to wait?
    Well I guess I will wait a while. Its doing more now then what it was doing. Thanks. I may need more help later.
  • fireman-134 Jan 21, 2009
    Still says Please wait a moment......... Then does nothing. Real pretty Acer screen though. LOL!
    It does not take me to my Password screen. When it loads it does everything that it used to but when it gets to where my password screen normally comes up, the screen stays back and I can't do anything. Hope this clarifies my problem some. Thanks!!
    My wife said she was watching a show on the internet, then screen minimized and norton began scan, then everything froze after about a half hour she turned computer off. Could it be a virus?
  • 903 Answers
Try to see if it will boot in safe mode, by pressing F8 while the laptop boots up. If it allows you to boot in safe mode, try to do a system restore when you know that laptop was working with no problems. You can do this by clicking on start>all programs>accessories>system tools>system restore and choose a date and time when you know that the laptop was working with no problems. If this does not work or you cannot boot in safe mode (be aware that everything will look big in safe mode and when the computer reboots if asked how you want to start windows, choose start windows normally), try doing a recovery. This will restore your computer to the factory default settings when you purchased it. You can do this by booting the computer, when the acer screen appears hold down the ALT key and continuously press F10, this will open the recovery manager and you can restore it from there.
I hope this helps
Posted on Jan 20, 2009
  • 4 more comments
  • Debs
    Debs Jan 20, 2009
    I recovered my daughters acer and it took about one and a half hours from beginning to end. I
  • Debs
    Debs Jan 20, 2009
    okay, let me know if you need any nore help I will be online for another hour but will check back in tomorrow. Good luck :)
  • Debs
    Debs Jan 21, 2009
    wow, that is taking far too long. Did you hold down the ALT key and then press F10 quickly when the acer screen appeared? I know you have to be quick when the screen appears otherwise it will try to boot into windows and you want to avoid this if you want the recovery manager to open.
    Try rebooting, get ready to hold down the ALT key and press F10 quickly as soon as the acer screen appears.
  • Debs
    Debs Jan 21, 2009
    If it appears to load windows (visually) and then the screen goes black where your log in page should appear, you should be able to boot up in safe mode. Have you tried pressing the F8 key when the computer boots? You do not have to wait for the acer screen to appear for this method. Just reboot and when the computer starts to boot up keep pressing F8 until you hear a beep. You will then be given some options. Choose start windows in safe mode.
  • Debs
    Debs Jan 21, 2009
    If you do manage to get it start up in safe mode then make a note of your graphicscard because if a restore does not help then your graphics card may need an updated driver. If you go into control panel>system>hardware>device manager and click on the + sign next to display adapters then make a note of the graphics card.
    If this is the case let me know the name of the graphics card along with your version of windows and I will find a driver for you.
    Let me know how you are getting on.
  • Debs
    Debs Jan 21, 2009
    Anything is possible, do you have the original windows disk or a boot disk for your laptop? If not what version of windows are you running.
    You did not mention if you could get into safe mode either!
MY acer ZD1 screen has gone black how do i connect it to a pc screen blind
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the Right/Rear of the laptop.
Example of a VGA connector (Port), and a VGA Cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for an example of a VGA Cable.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Yes. You can also connect an HDMI cable to it, and HDTV with this capability.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings the display should show on the external VGA monitor.
If not;
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY
Press, and hold down on the Fn key. At the SAME time tap once on the F5 key. The F5 key is the Display Toggle-Over key.
Regards,
joecoolvette
Feb 19, 2013 | Acer Aspire 5920-6423 Notebook
When it gets to the startup screen it shows some updates then shuts down
If you have your windows installation disk you can try to do a system repair. To do this, turn on you laptop and when the bios starts (usually white text on black background or an acer backgroud) press the F12 key to change boot order. Now select your dvd or cd drive. Windows will load files and then ask what you want to do. Select system repair and follow instructions.
Oct 20, 2012 | Acer Aspire 5920-6335 Laptop
I'm using acer aspire 5920 ...it having problem once it is turn on it dont shutdown. i seen in some blog .there said update BIOS .i did it. it displays message automatically shutdown . But my friend...
If you show a Blue Screen, you have more problems then it not being able to turn off/shut down?? I would back out the battery so as to stop power from getting to it, AFTER you have it unplugged..then push battery back into to engage, plug the AC cord back into the PC. turn it back on and IF you still show a BLUE screen, you will need a tech to check it further...GOOD LUCK...
Sep 25, 2011 | Acer Aspire 5920 AS5920 Notebook
On turning on ACER Aspire 5920G laptop the laptop goes through the process of booting up, ie all relevant LEDs on power come on. The screen does not load up with usual ACER whitescreen and comes up with...
Hi. Yes, it could be a failing LCD screen but I would suggest to check the ribbon that connects the LCD screen to mainboard and make sure that it is not damage and properly connected.
Aug 20, 2010 | Acer Aspire 5920-6727 Notebook
My acer aspire 5920 boots then goes to a black
The hard disk has died. Replace it and reinstall Windows.
Apr 06, 2010 | Acer Aspire 5920-6335 Laptop
Recovering windows vista
it probably load drivers it needs automatically, you don't have to make selection on which one.
Aug 20, 2009 | Acer Aspire 5920-6727 Notebook
Acer Aspire 5920 laptop is showing blank scren w/blinking cursor
yea yur harddriv crashed... try formattin yur drive and create a new partion and load OS .. if it still doesn work then yu ll have to replac yur drive..
May 01, 2009 | Acer Computers & Internet
My Acer Aspire 5920 won t turn on The battery light blinks but it is plugged up
try pressing on fn+f5 or fn+f6 a couple of times each. Maybe the screen got switched to projector status by mistake.
Jan 07, 2009 | Acer Aspire 5920-6727 Notebook
Died.
try to plug in an external monitor to your acer and see if your able to see anything. If not, then you have to open the screen and clean/repair/replace the ribbon for your monitor.
May 13, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5920-6727 Notebook Logo
916 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
