Question about Sony Cyber-Shot DSC-P100 Digital Camera
Sony dsc p100
I have a sony dsc p100. I took some photos in multi burst mode and got 16 frames per photo. How do I turn these shots back into a single frame/photo?
  • Darin Brumby Aug 18, 2007
    yes I want to them back to a single shot?
    Genius:
  • 2,985 Answers
Not sure what you mean? You have 16 single shots one after another Now what do you want to do? Turn the camera back to single shot? Read the Manual -Full manual in PDF format on disk Do something with the shots themselves? Use image editor in computer Do none of these? Try another way of putting the question
Posted on Aug 14, 2007
  • john ash
    john ash Aug 18, 2007
    Still no getting this
    Do you mean you want to join them up into a panorama?
    What hems when you see them on the screen on the computer?
  • john ash
    Or if it is sixteen Identical shots
    delete q5 of them.
    Or do a screen capture of one and edit it in an image editor
    If you cannot follow any of this
    describe exactly what you have.
SOURCE:
Camera, Sony cybershot dsc -w55 is taking a '16- photo strip' instead of one photo, any suggestions? Thank You
You're in the "Multi-burst" mode. In the recording mode, press the MENU button, then use left/right to select "Mode," then use up/down to select "Normal."
Dec 09, 2010 | Cameras
I can"t turn on macro. When I push the button, I see on the display that macro is invalid.
I have a Sony W120 and had the same macro problem, tried all the "solutions" mentioned here without result. So I pressed the "Home" button, went to "Settings" (last menu item at right), then "Main Settings", and used the "Initialize" functio. Problem solved !
May 05, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Sony dsc t70 flash problem
Because you have set the multi photo mode.
when you set it back to single shot mode, then the flash menu will change to more option to turn on flash.
it's because the camera can not charge the flash fast enough to do a few shot per second if flash is on.
This is the same as other digital SLR camera.
Oct 15, 2008 | Sony DSC-T70 Digital Camera
Each picture has multiple tiny tiles of the shot
I think the problem is this:
Where the T7 does match the competition is with its Burst, Multi Burst and Movie modes. Burst mode records anywhere from 9 to 100 images in succession, depending on the image size, when you hold down the shutter button. Multi Burst records 16 small images in as little as half a second, then tiles them into a single frame. If you time it right, it's useful for analysing motion -- and a fun way to make montages.
Taken from <a href="http://www.cnet.com.au/digitalcameras/cameras/0,239036184,240055561,00.htm">here</a>
Apr 23, 2008 | Cameras
How to turn on/off the flash onthe samsung d900i phone
Using camera options in Capture mode
In Capture mode, press < ebdd9ac.gif > to access the following
options:
Record video: switch to Record mode.
Shooting mode: take a photo in the following
modes:
Single shot: take a photo in Normal mode. You
can select whether or not the camera automatically
saves a photo.
Multi shot: take a series of action stills. You can
select the number of photos the camera will take
and the shooting speed.
Mosaic shot: take several stills and save them in
one frame. You can select the layout.
Effects: change the colour tone or apply a special
effect.
Frames: apply a decorative frame.
Flash: determine the use of the flash.
Timer: set a time delay before the camera takes a
photo.
Go to My photos: access the My photos folder.
Camera settings: change the default settings for
taking a photo.
Apr 01, 2008 | Cell Phones
Flash settings Sony DSC-H7
I had the same problem with my DSC-H9. The flash setting is set off when in BURST record mode. Go into MENU, scroll down to REC Mode, change it back to NORMAL.
Now go shoot someone or something... with your camera of course!!
Mar 12, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Cybershot dsc-w70 stuck in video mode
Ok! I've searched and searched, so hopefully this will help you all out.
If the videos are very slow moving, you're in multi burst mode. Simple fix, actually...
Press menu button that's below the dial selector. There should be two small options near the bottom of the screen "mode" and the little suitcase.
Go into mode and make sure that Normal is selected. Multi Burst is actually a 16 frame per second function good for sports. It shows as a slow motion video on the camera and a sort of collage on your computer.
Hope this helps. :)
Nov 30, 2007 | Cameras
Cant take pictures
Return to seller under warranty for replacement.
Jul 25, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-Shot DSC-P100 Digital Camera Logo
339 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
