Radiators go cold after cooking programme ends
We have just moved into a house with an oil-fired rayburn. We have set up programmes for the heating and cooker. It works fine until the cooker programme finishes when the radiators all cool down and don't come back on even though the heating is technically on. Even the override command can't get the radiators back on
  • Heating & Co... Master
  • 2,522 Answers
Sounds like this is wired in to the oven think you could be missing a link (elec link ) on the rayburn , try the aga rayburn web site they do have atech line
Posted on Jan 09, 2013
  • 16 Answers
SOURCE: Honeywell smarfit set to OFF but radiators go on
have you got a motorised valve problem
Posted on Aug 17, 2009
  • 149 Answers
SOURCE: heating turns off every sunday
programble thermostat/ if so check program
Posted on Jan 19, 2010
  • 2522 Answers
SOURCE: I have a Y plan heating/domestic instalation.The
Hi the cylinderstat controls the hot water only not the heating the boiler stat controls the water temp the room theromstat controls the rads , if you have one ,
so boiler stat set on 180f or number 5 cylindersat set on 140f to 120f roomstat to your comfort , the boiler stat works as a over heat so if the cylinder stat or roomsat fail it will turn off on the boiler you should beable to check wiring from that .
Posted on Mar 10, 2010
  • 2522 Answers
SOURCE: I have Netaheat 16-22. Recently
check out the pump see if it is working , or has air in it , sounds like the pump to me
Posted on Sep 29, 2010
  • 4 Answers
SOURCE: ST6400C programmer, heating switched off.
Have had a lot of these programmers with this fault.Integral fault with electronics.Programmer will need to be replace as unrepairable.You should be able to find a straight replacement version from your heating supplier.
Posted on May 14, 2011
The hw/ hw+ch rocker switch on my danfoss set 2e heating programmer is not working
Rocker switch stuck on replace programmer or diverter valve stuck in ch postion .
Aug 13, 2012 | Heating & Cooling
ST6400C programmer, heating switched off. Switch hot water on only, tank full of hot water but pump runs and radiators get hot. Wall stat is set at zero. When programmer is touched and the flap dropped to...
May 11, 2011 | Honeywell Programmable Thermostat Heater
I moved into an apartment in a very old house; 2 floors, each floor has it's own oil tank and furnace. Problem: I bought a programmable thermostat, removed the old one, hooked up the new one, and now the...
Most programmable thermostats have a configuration setting for the type of system you are using. They also normally have a configuration setting for the Heating Cycle Rate, Assuming it is wired correctly, I suspect the problem might be somewhere in one or both of those two configuration settings. Let me know what you find or if you have any further questions. :-)
Mar 16, 2010 | Honeywell Programmable Thermostat Heater
Have hot water but no radiators. Checked pilot
sounds like your circulating pump is bad or electronic zone valves
Oct 26, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat CM921, how to set the heating for a 6.30am??
if you have a programable tstat you need to go through the settings for each day and time. usually the buttton will say prgm or program sometimes it will be set try to get into the settings menue and then you can adjust times
Sep 02, 2009 | Honeywell Programmable Thermostat Heater
I have a Honewell CM921/927 wireless programmable room thermostat that is operating the combi boiler in AUTO mode even when the time setting is meant to be off (no output). The target temp is 20 deg and...
If the room is at the set temperature even when the rad are warm the boiler is doing its job. It takes steel rads up to an hour to cool down so if they stay warm to the touch that is normal.It takes steel rads a long time to heat up when they get cold so its cheaper to let them not get real cold.I was told not to put a programmable thermostat on our boiler simply because it takes a lot of gas to bring your house up even two degrees. I run a non programmable and set our heat at 72 degrees and do not touch it all winter. There should be a water shut off on each rad so if you want your bedroom cooler just shut that shut off on that rad off.
Apr 10, 2017 | Honeywell Heating & Cooling
Heating & Cooling Logo
129 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
