This is my boiler. Can anyone have a guess at what might be wrong with it based on the vid? I have had 2 plumbers look at it and several new parts but still this happens pls help if you can thanku
  • Steve Taylor Jan 08, 2013
    Just read redhase89's solution, yes what he say's is right, any air in the pipes can cause water lock, it is essentially the same as blocking the pipe with a cork. If you have good water pressure & a separate hot water system run that through the line that's connected to OUT on the boiler, until it comes out the IN line, let it run awhile, until you see no air coming out, not forgetting to fill boiler too, as these have a pump to circulate the water, though I would have thought there would be a purge air button on a system like this...
  • 3 Answers
I can't tell if it's igniting, I assume it's gas powered, can you hear the main burner light? or see the pilot light at all? If you answered yes to either, then I'd say it's the safety cut out, not having enough time to heat the sensor. See if there is a way of holding it in the start position for say 30 seconds, then release, if not then ask repair man if there is a way of adjusting the starting hold-on time, hope this helps...
Posted on Jan 08, 2013
3 Suggested Answers
redhaze89
  • 854 Answers
SOURCE: I'm a new plumber. I
1. You need to fill the entire system with water before you fire it, boiler AND radiators... Then, you would normally vent as much of the trapped air in the system as you could... It's not like you are only going to fill just the boiler and then pump that water through the pipes.
There is a temp setting on the boiler, but I don't think that's a solution. Remember that the water in the system is going to begin circulating as soon as you start the boiler. So, it will start circulating when it's cold, and then gradually warm up.
Your problem is not the sudden rush of hot water, it's going to be filling the system in the first place, and getting the boiler started before the system freezes up ...
I don't really have any suggestions for you though, other than perhaps renting one of those construction heaters ... and bring the building temp up a bit. But there's certain dangers associated with them too... Carbon Monoxide for one, fire is another (if used improperly).
Just thought of something: Fill the system with glycol based anti-freeze solution that's designed for heating systems. That oughta do it...
I'm guessing there's not a functioning water heater either at this point, is there ? If there was, you could possibly rig something up to fill the system with lukewarm water, and fire it before it freezes up.
2. You don't have a lot of choice. You have to fill the system, fire the boiler & wait.
It is going to take a long time to get the system up to temperature. Instant circulation is a double edged sword. The upside is you get a little bit of heat into the water & have it moving making freezing less likely. The downside is, it's hard on the boiler with that much cold water coming back you are likely to have condensation.
Posted on Apr 22, 2009
  • 13 Answers
SOURCE: The problem is as follows
What parts were replaced?
Sounds like the thermostat or relay are faulty.
Posted on Aug 31, 2011
What's wrong with a leaking shower head following new boiler and how do I fix it?
The valves are leaking. It's not the shower head itself. Sometimes shower faucets require special tools to service the valves. If you have thought about new shower valves, now would be a good time to replace. Repair may be half the cost of installation of new. In other words, plumber's time to repair or replace is about the same. Get several quotes. TV show This Old House had one on a replacement. It may be available online. Home Depot or Lowes or Ace Hardware may be able to help, Or similar Hardware outlet in your area.
Feb 13, 2015 | Water Heaters
I have wired up 6 x outside lights via a dawn dusk sensor ( 4 x 20w lights and 2 x 60w ordinary bulbs) which are connected to the Garage & Boiler circuit via a 3amp fuse box. Whenever the boiler kicks...
The way you describe the connections, it looks like your 3Amp fuse is presently hooked up to protect the 6 lights, and by calculations, it will. Are you saying that this new hook up is feeding from a circuit that also runs the boiler? My guess is that the load from the boiler, with the extra draw from the lights exceed the breaker circuit limit. Let me know if that's what you mean! I would say if that's the case, find a separate feed for the lights in the circuit breaker panel so it does not load the boiler circuit. Let me know if this makes sense for your situation.
Dec 27, 2013 | YouTube Videos
Hi, I am a caretaker in a 12 suite apartment block. The building has an old gas-fired hydronic Weil McLean boiler (maybe 10-20 years old). The gas pilot switch was regularly flipping (about 2 times at...
IS ANYONE CHECKING GAS PRESSURES? A BLOWING PILOT COULD BE UNSTABLE AND LIFTING OFF.IF IT IS WIND RELATED TRY A PIECE OF TIN FOR A "WIND SHIELD" AROUND THE PILOT
Jan 05, 2011 | Heating & Cooling
Exactly the same problem
what u need to do is turn off all your rads except the 1 that is working and run the heating that should push any blockage round the system do the same with other rads that are blocked then try bleeding the rads and filling boiler if neccecary
Jun 06, 2009 | Combi Centre DX - Mango
Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
May 15, 2009 | Water Heaters
I'm a new plumber. I was asked to restart a burnham gas fired steam boiler in a fire damaged apartment. The boiler was drained last winter along with the radiators but was not winerized. I am their plumber...
Apr 22, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
