Question about Sony PlayStation 2 (PS2) Console
Playstation 2 Problem
I asked this question before, however the question I asked wasn't enough detail. I have several games, I am able to play one of them but not the others. What is going on?
  • 4 more comments
  • ejbarrows20 Jan 20, 2009
    I cannot get the covers off.
    How do I do this?
    The Discs do play on other playstations. It seems that the games that don't play have a silver underside, the ones that play have a purple or blue underside.
    tried opening it up but can't get the bottom away from the machine.
    Tried blowing to clear it out and this didn't work.
    no i'm doing this and its not working. there is no need to be rude.
    Scholar:
  • 58 Answers
I had this same problem when I was a soldier stationed in Iraq. As you can imagine, there is a lot of dust and heat in Iraq. I think we had to go through 3 playstations while I was stationed there. The dust wasn't smooth, it was gritty and ruined disks and lenses. I would have to agree with everyone above and say that you may have a dirty lens. The fact that black plays and the silver will not seems to be because black absorbs more light than silver. If the lens is dirty or scratched, it will have a better chance to read a black or dark colored disk than a silver one. On a side note, I also found out that if the disk doesn't spin up fast enough that there will be a read error also. You may have to open the unit like suggested above and clean the lens manually with a soft cloth. Make sure you get the dust too while your in there. I think I'm going to have to do this with my ps3 because my house is dusty.
Posted on Jan 20, 2009
  • Sony Master
  • 19,396 Answers
To disassemble a PS2 you need to remove the 8 screws holding the cover.
Be very careful not to damage cables and ribbon connectors when you take the unit apart.
If the unit reads only certain disks, depending on surface, then it is a lens problem, try cleaning the lens with Qtips and isopropyl alcohol, or replace the lens pickup.
YouTube - 01 - Console Repair - PS2 Disassembly
PS2 - Disassembly I
YouTube - Play Station 2 "How disassemble a PS2"
Tweak3D.net - How to Repair a Malfunctioning Playstation 2
  • Ginko
    Ginko Jan 20, 2009
    Wow, you refused my answer before reading it, well evidently you do not need my help in here.
    Have a nice day.
  • Ginko
    Ginko Jan 21, 2009
    One last hint,
    when the PS read ony certain disks, and disks are fine on other consoles, then it is usually a lens problem.
    Before taking apart the PS try a DVD lens cleaner like this one:
    JVC Cldvdlau Dvd Lens Cleaner
    Sergeant:
    Novelist:
  • 326 Answers
To open the bottom after removing the screws just ***** something from the sides to create the space and open up the inner locks holding the bottom.thanks
  • 11,896 Answers
The lens inside needs to be cleaned. You can open your disc tray and blow inside a couple times. This usually always works. The lens get dusty and touchy. BLowing the dust of the lens is much easier than removing the cover and cleaning and yet has same outcome.
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    Here is a link to step by step directions on how to repair your PS2
    http://ps2repairs.amenet.co.uk/dre.htm
  • 8,197 Answers
Go to this site below it will give you step by step directions to fix. It will help you get the games playing again.
http://arstechnica.com/articles/paedia/hardware/ps2.ars/1
Good Luck
  • Jyackle5
    Jyackle5 Jan 20, 2009
    Youdid not even look through the post I put. Because in the link it told you how to realign the laser for the disks that you aretrying to use. It looks like you want us to do it for you.
    Good luck with it.
    President:
  • 846 Answers
Make sure the bottom of the disc, are in good shape (no big, deep, large number of scratchs).
* Obviously they are playstation games...I hope you didn't miss that kind of mistake.
* Shouldnt HAVE to upgrade the software/firmware that's not a typical problem with store bought games.
* If they are copys of games if might not have been burnt properly, you need a special chip to play some copied games as well.
  • Quickfx PC Repair Jan 20, 2009
    I don't see why it would play some games just fine, but others not at all if it was the laser. You would have the same problem with all games, so its the disc's themselves.
    President:
  • 1,990 Answers
Welcome to Fixya! Try to Clean the Lens using a DVD Cleaner Disk. It has Small Brushes on the Disk that will Clean the Lens while in Motion. It is available at Wal-Mart. Should fix this Problem. Worked on My PS2.
    Genius:
  • 2,920 Answers
Have u checked to make sure they are all play station 2 games? if they arent that may be why you cant play them all
    Sergeant:
  • 378 Answers
Just upgrade your firmware with latest software.only that is the problem.
    Genius:
  • 1,269 Answers
What game is it? It could be the CD. You can try to transfer the game to another disc (cd burn) then try it again.
  • Sony Master
  • 13,433 Answers
You may have a dirty lens, or a fauly drive, generally our ps2 plays all dvds and games its supposed to. is it covered by warranty?
  • Ekse Jan 20, 2009
    there are screws hidden, on those feet and other soft objects, under them, those plastic small covers on the screws come out.
  • Ekse Jan 20, 2009
    there are quite a few screws, under those feet, all around the machine. you either have a dirty lens, or a fauly lens on the drive, just other fault in the drive, generally clean the lens or replace the drive, some shops sell the lens but might be better to replace the whole drive if its not working.
My new psp will no longer read any games
just do what i did call playstation support tell them the problem and send it back for repairs my ps3 was doing the same thing it wasn,t the lens that wasn,t reading the disc it was the disc drive that wasn,t moveing check it out
May 08, 2012 | Sony PlayStation (PS) Console
Will not play World tour
Is the Playstation 2 and the Game from the same Region? Games from other regions will not play on systems from different regions. Need more details.
Dec 27, 2010 | Sony PlayStation 2 Slimline Console
I got 007 quantum of solace a few weeks ago and completed it on game mode so thought would have a go on multiplayer, although when i tryed to play it just leaves me hanging in match game lobby asif nobody...
As this game is old now, Infinity Ward may have turned off the servers as there is not enough support for the multiplayer aspect. This happens regularly with game that are a couple of years old and not many people play online.
Dec 16, 2010 | Dmm Bond 007: Quantum of Solace PS3 for...
Why do i have to play woods 09 golf playstation 2
look up in the instrusion book it might tell u or ask some 1 to help u
Feb 25, 2010 | Electronic Arts Tiger Woods PGA Tour 09...
Problem with bratz movie game is i try to go to london and the screen goes black what can i do
dont worry ask some one who has played the game b4 ask them to help you out good luck
Feb 18, 2010 | THQ Bratz: The Movie for PlayStation 2
Switch disk in psone slim
possible problem with the discs. but i run into that problem when the play station is not getting enough power.i don't understand how it works but try a different outlet.
Aug 09, 2009 | Video Game Consoles & Games
It says..please insert a playstaion or playstation 2 disc format.
It's not asking for a specific disc, it's asking for a properly formatted PlayStation disc.
This message could mean that any one of several things has happened:
* You are trying to play a Japanese disc on a US PS2, or vice versa
* You are trying to play a game that has been copied onto a CD-R/DVD-R
* Your disc is scratched/dirty/otherwise unreadable
* Your disc isn't a format that the PS2 recognises (i.e. CD, DVD, PS CD-ROM, PS2 CD-ROM, PS2 DVD-ROM, etc)
* Your PS2 is broken
May 05, 2009 | Video Game Consoles & Games
PS3 says not enough memory
you need 2 delete data or get a memory stick
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
My son purchased a Playstation 2 game that's in Japanese. Do they make a format disk, so that my son can play the game on a U.S. Playstation 2 ?
you can either go to your local game store and ask if they have a copy or there some programs that create backup files of the game and than you can burn them on to a normal DVD of CD-Rom and play it on your playstation 2.
Aug 01, 2008 | Video Game Consoles & Games
Sony PlayStation 2 (PS2) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
