Question about RCA RP5010 Digital Voice Recorder
How do I erase files? - RCA RP5010 Digital Voice Recorder
How do I delete a recording off my Sony Sony - ICDBX140 - 4GB
  1. Slide the HOLD?POWER ON/OFF switch in the direction of "POWER ON/OFF" to turn on the IC recorder, or towards the center to release the IC recorder from the HOLD status. The stop mode window appears.
  2. Select the file you want to erase when the IC recorder is in the stop or playback mode.
  3. Erase a selected file. When the IC recorder is in the stop mode, press and hold ERASE.
    When the IC recorder is in the playback mode, press ERASE.
  4. Press ERASE. "ACCESS" appears in the display window and the selected file will be erased.
    When a file is erased, the remaining files will advance so that there will be no space between files.
Hint
  • To cancel erasing, press souni_stop.png(stop) in step 3.
  • To erase a part of a file, divide the file into two files first, and then proceed with steps 3 through 4.
Mar 10, 2015 | Sony Video Cameras
Olympus DS-30 recorder: memory is full but there are no files to delete
1.Press the FOLDER button to choose a folder.
Every time the FOLDER button is pressed, it cycles through folders and the List display will appear (+P20).
Press the + or button to choose the file you want to erase.
Press the ERASE button. The “Cancel” indicator flashes.
Press the + button to choose “Erase”.
5
Press the OK button. The display changes to “File Erase!” and erasing will start. “Erase Done” is displayed when the file is erased. File numbers will be reassigned automatically
Apr 04, 2008 | Olympus DS-30 Digital Voice Recorder
Hi i own a RCA digital voice recorder model# rp5030A i can not figure out how to delete recordings
Erasing selected file
You can delete a file by the following steps:
1. Select folder (A, B, C , D or )
2. Select file.
3. Press ERASE once and DELETE will blink on the screen.
4. Press and hold ERASE for 3 seconds to confirm deleting. (or press STOP to cancel erasing file)
Erasing all files in a folder
You can delete all files in a specific folder by the following steps:
1. Turn on the unit.
2. Select a folder (A, B, C , D or ).
3. In Stop mode, press FORWARD continuously until "ALL" appears on the display.
4. Press ERASE and "DELETE" will blink on the display.
5. Press and hold ERASE for about 3 seconds, all files in the selected folder will be erased completely (or press STOP to cancel erasing all files).
Tip: File numbers that come after erased one will be moved forward by one automatically.
See page 12 for more info: http://www.rcaaudiovideo.com/docs/common/RP5030/RP5030_OM.pdf
Dec 29, 2012 | RCA RP5030 Digital Voice Recorder
I have lost my info manuel. How do I erase unwanted dialogue
There are two types: Cassette and Digital. Which one (Model #) do you have?
In the cassette model, press ERASE and Fast Forward.
Failing that, you may need to record over the whole tape.
The Digital modells will allow you to erase one file at a time.
You may have to press PLAY and then ERASE while the file is playing. If that does not work, press ERASE at the beginning of the file.
It will ask you if you are sure you want to erase it.
If YES, then press ERASE again.
In either case, the erased files are not recoverable.
Jun 02, 2011 | Thomson Audio Players & Recorders
I can`t erase any of my recordings.
Make sure you press erase twice and wait a few seconds for all of the files to pack. The unit fills the holes when a file goes away. You can erase say file 3, then it will pack all the files to put #4 in 3's old place, 5 in 4's old place and so on. Make sure you dont keep erasing the same number file becuase the new #3 file is the old #4.
Sep 18, 2009 | Sony ICD-B7 Digital Voice Recorder
I need to delete a recording
2. Select file.
3. Press ERASE once and DELETE will flash on the screen.
2. Select a folder (A, B).
3. In Stop mode, press FORWARD continuously until “ALL” appears on the display.
4. Press ERASE and “DELETE” will flash on the display.
Aug 14, 2009 | RCA RP5010 Digital Voice Recorder
Erase recorded files on my Cenix VR-P490 voice recorder
You have to select the file to erase hold the erase button and when "ERASE" blinks in the display you have to press the erase button one more time. Do this for each file you wants to erase.
Jan 20, 2009 | Panasonic RR-QR150 Digital Voice Recorder
I LOST THE MANUAL. CAN'T FIGURE OUT HOW TO ERASE PERVIOUSLY RECORDINGS.
How are files erased from the VN-3100PC?
Individual selected files or the entire contents of a selected folder can be erased from the VN-3100PC.
To erase a selected file:
  1. Press the [REW]or [FF] button to select the file.
  2. Press the [ERASE] button.
  3. Press the [REW] or [FF] button to select YES.
  4. Press the [PLAY] button.
To erase the contents of a folder:
  1. Press the [REW] or [FF] button to select the folder.
  2. Press the [ERASE] button twice.
Erased files cannot be retrieved.
hope this helps! =]
thanks for using fix ya
Aug 01, 2008 | Olympus VN-3100PC Digital Voice Recorder
I need to erase the files
Normally, hold down the erase button until the folder begins blinking, then release the button and press it again. You will have to do this for each file in the folder.
Sep 25, 2007 | Panasonic RR-US395 Digital Voice Recorder
Sony tape recorder- ICD-B310F there is no erase button, how do you erase messages
I have the same recorder (Sony ICD B310F) and in playing around with the buttons, I figured out how to ERASE THEM!!!
Go to the file you want to erase
Hold down the menu button (have to do this the entire time ) until you see the word "MODE"
While holding the menu button, press the forward arrow (like FF) and scroll until you see the word "ERASE"
Still holding down the menu button, press the play button.
Your file number will blink along w/ the word "ERASE", press the play button.
You should notice your file numbers decreased by one file. You have successfully erased the file.
Aug 03, 2007 | Sony ICD-B310F
RCA RP5010 Digital Voice Recorder Logo
19 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
