Question about ASUS Motherboard M5A78LM LX AMD AM3 780GBSB710 PCI Express SATA Microatx Retail (111585B22
Asus ami boot error FEAF - what does it mean?
ERROR message appears on boot the says 'press F! to continue'. Boot up then continues normally.
tom19511
  • 1601 Answers
SOURCE: ucode error
The bios needs to load a patch table that supports your processor. Go to the ASUS website and ensure that processor capatibility with your MB, and if there is a BIOS update for it.
Posted on Jan 18, 2008
  • 21 Answers
SOURCE: Asus A8V Error Message
How many whats is your power supply? Sounds like not enough voltage.
Posted on Nov 27, 2008
map9966
  • 2351 Answers
SOURCE: chassis intrusion
You need to check the chassis intrusion pin setting located on the motherboard. See page 1-30 (Number 11) in your manual.
You need to add a jumper as shown.
The system should no longer halt.
Cheers!
Mike
Posted on May 05, 2009
  • 788 Answers
SOURCE: Fails to boot, fans and lights on, no bios or anything
My recommendations would be to remove all connections to the board.
Remove the CMOS battery.
Remove the CPU fan and CPU.
Look at the top of the CPU, if you have a crust over the top of the CPU, you will need to remove it to a clean surface.
Next, your CPU fan should be a 3 wire connection on the motherboard, within two inchs of the CPU holder.
After cleaning the CPU, re-inseart and apply a heat sink lub for good heat transfer.
Re-install CPU fan and plug in to board connection.
Re-install your CMOS battery and power up unit.
With the CMOS battery removed, the time and date will need to be reset.
Also, in the BIOS for that board, you should be able to see temps. and rpm readings. ??
Hope the CPU has not taken a dump on you.!
Before you plug in the drives and other devices, check temps. rpm and voltages.
Have fun, hope this has helped you.
Posted on Oct 06, 2009
  • 644 Answers
SOURCE: asus p5gc-mx/1333 cpu fan error
There are usually three wires on a fan to connect to mother board 1 red "+" positive, 1 black "-" negative and 1 yellow which feed the bios with information about the fan, i.e. how many rpms it is running at. To check the fan you will need to open the pc by taking the side panel off, you should do this when the computer is running or you will not be able to check the fan is working or not, but be carefull not to touch anything inside the case. If the is not spinning check the cable is in the socket properly by turning the computer off first, if it is you will need to replace it, other wise the processor will burn out. If the fan is spinning then the bios is not receiving the infornmation from the fan, therefore you need to shut down the pc and unplug from mains and check the cable(give it a littke wiggle) and make sure it is making a good connection, try blowing any dust of the connectors, power the pc again and if the bios is still giving you the same message you will definatly need a new fan, you can by them from any pc store, take the old one with you to ensure you get the correct size fan.
Posted on Jan 25, 2010
P4c800-e gives error bios not loaded
this motherboard is supposed to have crash free BIOS an overclocking ability and power loss restart
is it happening on boot up the drivers have not been loaded or might not be detecting a bootable device the first things to check are the leads motherboard to your hard drive make sure they are securely seated with no dust built up also the same with computer ram and cmos battery and make sure the sockets are cleanThis message is generated by computers with SCSI / RAID controllers when no bootable drive is detected on the controller. This is not an error message unless you have a bootable drive on the SCSI / RAID or you are wanting to use a SCSI or RAID drive. If you are not using a SCSI or RAID drive and your computer has onboard a SCSI or RAID controller, this message can be disabled by entering the computer CMOS Set up and disabling the onboard SCSI or RAID During the boot process you will see on the screen to press delete to enter setup Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart If your computer is unable to boot or you wish to restore the BIOS back to bootable settings and your computer uses an ACER BIOS, press and hold the F10 key as you turn on the computer. While continuing to hold the F10 key, you should hear two beeps indicating that the settings have been restored. AMI BIOS Older AMI BIOS could be restored back to bootable settings by pressing and holding the Insert key as the computer is booting.
BIOS / CMOS diskettes
Early 486, 386, and 286 computers may have required a floppy disk in order to enter the BIOS setup. These diskettes are known as ICU, BBU, and SCU disks. Because these diskettes are unique to your computer manufacturer, you must obtain the diskettes from them. See the computer manufacturers list for contact information. Early IBM computers Some models of early IBM computers required that the user press and hold both mouse buttons as the computer was booting in order to enter the BIOS setup.
Other suggestions
Finally, if none of the above suggestions help get you into your CMOS setup you can cause a stuck key error, which will usually cause the CMOS setup prompt to appear and remain until you press a key to continue. To do this press and hold any key on the keyboard and do not let go (you may get several beeps as you're doing this). Keep holding the key until the computer stops booting and you're prompted with an option to enter setup or to press another key to continue booting.
hope this helps
Jul 28, 2011 | Intel ASUS P4C800-E Deluxe 875P Socket 478...
My xbox keeps freezing when I play my games then sometimes I get an E 71 error??? what do i need to do?
E71: Dashboard Error - Error within Xam.xex
Try resetting the console - Clear All Installed Game Updates and Console Cache
  1. Go to the "system" blade
  2. Select "memory"
  3. Press Y on the HD symbol
  4. Press X,X, Left Bumper, Right Bumper, X,X
  5. A message will appear saying: "Do you want to perform maintenance on your Xbox 360 storage devices?"
  6. Select Yes
Clear Any Failed system updates that cause the console to error.
  1. With the console off, press and hold the sync up button (the small white one)
  2. While holding the sync button press the power button to turn on the console
  3. Continue to hold the sync button until the Console has booted up completely.
  4. During the boot process the console should clear any failed updates, allowing you to use it normally.
If that doesn't fix it, you'll need to set up a repair with MS.
In the US Customer Support can be reached at 1-800-4-MY-XBOX (1-800-469-9269)
Jun 27, 2011 | Video Game Consoles & Games
On my computer i have to push f1 to start it
first try to notice the message before the (press F1 to continue) message, it could be a bad component (memory, hard drive, etc...) or the time & date is not set correctly in the BIOS, this would help a LOT thank's...
Jun 25, 2011 | Dell Computers & Internet
Fatal error P5GC MX1333
Press and hold delete during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Feb 12, 2011 | ASUS P5GC-MX/1333 - Motherboard - micro...
Latitude delld610 Boots with the following
press F2 to get into the dell bios and be sure the HDD is listed as first to boot, Then if restart turns the same error, press F10 and run the pre-boot system assesment check. if error 0141 appears, your HDD is failing and needs to be replaced
Aug 24, 2009 | Dell Computers & Internet
Checksum error
Hi robynonis
Yes, definatly the cmos battery. Please make sure you replace with same type battery.
Regards Go-Tech
Dec 22, 2008 | ASUS P4PE Motherboard
Lexmark c510 error message ;83 photodeve cart missing
See User Reference
http://www.lexmark.com/publications/pdfs/c510/eng/userref.pdf
Understanding printer messages
pages 184 and 185
"Message:
83 Photodev Cart Exhausted
What this message means:
The photodeveloper cartridge is completely used.
What you can do:
Replace the photodeveloper cartridge.
See also: Replacing the photodeveloper cartridge [page 73]
Continuing below
Message:
83 Photodev Cart Life Warning
The photodeveloper cartridge is nearing the end of its life.
What you can do:
• Press Go to clear the message and continue printing.
• Replace the photodeveloper cartridge.
Continuing below
Message:
83 Photodev Cart Missing
The photodeveloper cartridge is either missing or incorrectly
installed.
What you can do:
Correctly install the photodeveloper cartridge to clear the message and continue printing.
See also: Replacing the photodeveloper cartridge [page 73] "
Nov 26, 2008 | Lexmark C510 Laser Printer
PC will not reboot.
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | Gateway GX7022E (RBGX7022E) PC Desktop
My serial and password will not register my dvdxcopy
Check
1 Beep
2 Beeps
3 Beeps
4 Beeps
5 Beeps
6 Beeps
7 Beeps
8 Beeps
9 Beeps
10 Beeps
11 Beeps
Continuous Beeping
Oct 28, 2007 | 321studios DVD X Copy Platinum (200000)...
ASUS Motherboard M5A78LM LX AMD AM3 780GBSB710 PCI Express SATA Microatx Retail (111585B22 Logo
180 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
