Question about Pentax Optio Cameras
Lens error 0x2119
I did not knock my camera. But since I was on a journey it displays me lens error 0x2119 as soon as I zoom and die out.
BillB-SA
  • 2761 Answers
SOURCE: when zooming, i get a
If the camera has recently been dropped it may have lens damage that is shutting the camera down. If it hasn't been dropped, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and charge them. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Posted on Dec 01, 2009
SOURCE: Lens error
Powershot S3 IS: lens error message, lens juddering on startup but not coming out. Tried all tricks on internet without success, so decided to dismantle camera. Localised fault to optical position encoder on first transfer gear of the ultrasonic motor which controls lens position. Sensor was misaligned and/or dirty, so the camera could not detect motor rotation. Removed sensor, cleaned it, glued back in position with cyanoacrylate glue. Reassembled camera (only one internal bolt left over - not bad!) Working 100% again.
Posted on Jul 29, 2010
lock123
  • 6831 Answers
SOURCE: Zoom Error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
lock123
  • 6831 Answers
SOURCE: Every time I try to zoom the screen reads Lens
Hello
Regards
Andrea
lock123
  • 6831 Answers
SOURCE: zoom error displayed on lcd
Hello
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 12, 2010
Camera won't zoom correctly.
Lens errors (Zoom Errors on FinePix) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Nov 12, 2011 | Fuji FinePix F20 Digital Camera
I got a sony cyber-shot dsc-t900 what is error 61:10?
The error is: E 61 10 Zoom operations fault Inspect the lens block zoom reset sensor
Here are some things that are reported to work:
Reset the camera:
Home>Settings>main settings>Initialize>ok
If that doesn't work give the camera bottom a couple of slaps against the palm of your hand or strike the bottom against a book to knock the lens mechanism back in place. Be resonable with the force, you don't want to break the thing. It may take a half dozen wackings to get things settled.
Hope that helps,
BAX
Feb 24, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
When zooming, i get a ''lens error: 0x2119 error and the camera shuts down. how can i fix this?
Dec 01, 2009 | Canon Cameras
Lens error 122,1,0,0
Most likely, the lens movement gears are misaligned. There's also a good chance you misaligned the lens elements by knocking the lens sideways. It is not going to work, since it cannot move the lens to focus or zoom now. Your choices are to repair or replace the camera.
Oct 15, 2009 | Kodak Easyshare M753 Digital Camera
Camera lens wont extend, has zoom error
It seems the mechanism has been damaged or is faulty is someway.
The devices are very fragile and the slightest knock can send th askew.
As it appears to be new - lets assume it is a faulty camera and return it to vendor
Nov 06, 2008 | Fuji FinePix A360 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Casio EXILIM camera lens will not extend fully!!!
It's the focus lens gears. The often times get knocked out of alignment by an impact, or debris gets in there. This can be fixed, but Casio won't help. Hint...google my username. ;)
Jan 21, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Cameras Logo
63 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
