RCA digital tv converter box keeps turning off
  • amterry24 Mar 09, 2009
    I am having the same problem only with the sigma converter box,it cuts off for no reason,this is a big problem when your trying to record shows
  • 227 Answers
Take remote and select menu, then select 3, then hit down arrow to off-4
Posted on Jan 20, 2009
Go to menu-turn the timer off.
Posted on May 18, 2009
I need the code for rca digital
Which code? For the Universal Remote? If so, it has a scanning function on it.
Dec 18, 2011 | RCA Analog (RCA) to Digital (VGA)...
I need a 3 digit code for RCA converter box for a Orion tv.
You haven't given a clear problem post ebefore me. You have only give the model number and brand name of your TV only. Not give the model number of your RCA converter box. Yet i posts a solution to your problem, assuming that your RCA Converter box model number is " DTA 800B1 " The three digit setup codes for Orion TV with this RCA converter box are: 029, 189, 200
Oct 04, 2011 | Orion STV2763 27" TV
Hello, the remote has quit working for the volume
Ur free air DTV converter box have problem taking in the programs codes belong to ur tv,belong to the remote.Turn the converter box off/on to reboot ur DTV converter box.Read ur owner manual,re enter ur tv codes,belong to ur tv.U tv should be up and running again.
Jul 31, 2010 | RCA Televison & Video
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
Ok my Magnavox digitla converter box has been
Something is wrong with the box, you most likely will need a new one.
Jun 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Magnavox DTV box
I would say you got a bad one. They have an auto-shutdown setting, but shutting off as soon as you power it on sounds like a defective converter. How long ago did you purchase it? There should be a 1 year warranty on it. If it is new, return it to the place of purchase. There is also a toll free number on the enclosure that will be able to replace it if it is still under the warranty.
Thanks for using Fixya.
Jun 04, 2009 | RCA Analog (RCA) to Digital (VGA)...
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
Converter box turns off every 15-45min
reset it to factory defaults reset switch or power bur\tton for 10 seconds.
Jan 05, 2009 | RCA Analog (RCA) to Digital (VGA)...
Televison & Video Logo
263 people viewed this question
Top Televison & Video Experts
