Question about Plantronics CS60 Professional Headset
After subscribing headset to base green talk indicator light is flashing
Initial problem was that the the headset indicator light was not on. I followed the "subscription" details to match the head set with the base unit. After "re-booting" the green indicator light is now flashing rapidly and the headset is still not working.
5 Suggested Answers
Peter Denton
  • 16 Answers
SOURCE: plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Posted on Nov 05, 2008
  • 5 Answers
SOURCE: Plantronics Voyager 500a Bluetooth Headset
Try re-syncing the headset to the base unit:
http://plantronics.custhelp.com/cgi-bin/plantronics.cfg/php/enduser/std_adp.php?p_faqid=8165&p_created=1128461658
Posted on Jan 07, 2011
HDI Headsets
  • 537 Answers
SOURCE: headset not working. red light
It sounds like the headset may have lost connection with the base, try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Plantronics 500A Pairing Instructions
Good luck from Headsets Direct!
Posted on Oct 28, 2011
HDI Headsets
  • 537 Answers
SOURCE: While the headset works frequently,
It sounds like the battery is no longer holding a good charge. There is no replacement battery for this headset. If you are using the original 510 headset you can replace it or pair a different bluetooth headset up to the 500A base. Just keep in mind if you decide on a different style of headset you will not be able to charge it in your base. I have included the link for the 510 replacement headset below.
Plantronics Voyager 510 Replacement Headset
Posted on Oct 31, 2011
I can't hear the other people on my plantronics cs 70 which is connected with my cisco ip phone 7941 phone
• Check that all cords and jacks are connected correctly.
• Check that the base has power (red indicator light) and the headset battery is fully charged.
• Try other phone configuration dial settings on the base unit. Ensure the selected number is in line with the position indicator.
• Ensure you are in headset mode. Press the call control button to select correct mode. The talk indicator light on the base is green.
Sep 09, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I lost my ear piece for my Plantronics Voyager 500A so I am trying to pair a new earpiece. How do I do this?
1. On the base, press and hold both speak volume fine adjust buttons until the blue talk/on line indicator light and red power indicator light (on the front of unit) start to flash.
2. On the headset, press and hold the listen volume adjust + button and call control button until the status indicator flashes red and blue.
3. Pairing is complete when the talk/on line indicator on base illuminates solidly, and the status indicator light on headset flashes blue.
Important: Make sure your headset is not connected to any other Bluetooth device when attempting to pair.
Jul 13, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Can sync earpiece to base. Please help.
Here are the pairing instructions for your Plantronics Voyager 500A base:
On the base, press and hold both speak volume fine adjust buttons until the blue talk/on line indicator light and red power indicator light start to flash.
Now put the headset into paring mode that you will be using with the base.
Pairing is complete when the talk/on line indicator on base illuminates solidly.
Here is the link to the 500A user guide:
Plantronics Voyager 510S User's Guide
Jun 20, 2011 | Plantronics Voyager 500A Deskphone Adapter...
We had to order a new headset (ear piece) to our CS70 system. Do we need to program it? It is not picking up the handset.
To pair another headset to the same base, you must first enable the multi-shift
pairing feature. Long press (5 sec.) the speaking volume minor adjust up button on
back of base until the power indicator light flashes.
2. Place a charged headset in charging cradle and red indicator light on base will flash
for 2 seconds if the multi-shift pairing feature is enabled. Within 10 seconds of
doing so, press either the "+" or "-" listening volume button for 3 seconds until the
headset talk indicator lights to indicate pairing mode, and goes out after successful
pairing. Repeat steps
Jul 11, 2010 | Plantronics CS70 Wireless Headset
Is it compatible with an IPCC nortel network phone?
I am personally using a Plantronics CS60 wireless headset with a Meridian Nortel M2006 Phone and it works just fine.
Here is how you can setup the Plantronics CS60 wireless headset.
NOTE: Before setting up the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
Jun 02, 2009 | Plantronics CS60 Wireless Headset
Plantronics CS55 requires lifting handset on phone
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
7. If this procedure does not resolve your issue to try a system reset.
May 28, 2009 | Plantronics CS55 Wireless Headset
Headset compatability
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
Apr 22, 2009 | Comdial 8012S-GT Corded Phone
Plantronics CS55/HL10 Wireless Office Headset System with Lifter won't lift headset
You may need to re-subscribe the headset.
To Re-Subscribe:
Jan 12, 2009 | Plantronics CS55/HL10 Wireless Office...
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Headset CS50
It sounds like you need to re-register the earpiece to the base. To do this, use the following steps:
Headset Docking Cradle
Speak Volume Adjust Buttons (+/-)
on the back of base unit for a
minimum of 5 seconds. The
Red Power Indicator will then
flash
3. Press and hold the Headset
Mute Switch (black button on top
of earpiece) for a minimum
of 5 seconds. The On-line
indicator (green light on boom)
will then illuminate.
4. Subscription completion is
indicated when the Power
Indicator is fully illuminated
and the On-line Indicator is
extinguished.
5. If subscription fails within 2
minutes the headset will return
to the un-subscribed state.
Aug 19, 2008 | Plantronics CS50 Wireless Headset
Plantronics CS60 Professional Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
