Question about Gigabyte Ga H55m D2h Desktop Motherboard Intel Socket H Lga 1156 Multi Gpu Support Crossfirex (GBTH55MD2H
Temp sensor damaged
Pc works when air conditioner is switched on and room is brought to 22 c. But when the AC is switched off room is at 30c and pc keeps restarting like crazy. Just changed the heatsink but still the same crazy rebooting. Feel like throwing my pc out the window!!
  • Gigabyte Master
  • 3,606 Answers
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=3572#dl
Did you by any chance overclock the cpu in the bios ???
If so select a setting that is lower.
Have you added some thermal grease between the cpu and the cooling element ???
Is the fan connected right to the mainboard ???
The fan must be connected to the CPU_FAN 4 pin connector on the mainboard so the bios can control the speed, when the cpu gets hot.
I don`t know what size you case is but, you can add a 120 mm fan
below the power supply, and connect the power plug to SYS_FAN on the mainboard.
This should give a better airflow in the case.
In the end, i think a bios setting is wrong. Try to download a manual and check the settings in the bios and also you electrical connection.
The pc should not switch off before it reaches 70 degees celcius.
Hope you will get a cooler pc after this.
Posted on Jan 08, 2013
  • 2 more comments
  • arun kumar Jan 09, 2013
    thnx fr ur time boss.... did everything u said... but still same prob... what other parts other than cpu depend on the temp.
    cpu temp 29c system temp 40c also have placed a big fan in frontvif the cpu but still doesnt work unless i switch on the air cinditioner.
    even flashed my bios at no avail
    temporarily solved the problem by directly pointing a 45 cm fan directly in front of the motherboard. hope this sol doesnt damage it further.
A short while after turning the unit on (AQV24V) it displays the error code E4 64. does mean? Thanks
  • Samsung E464 Code=IPM Over Current
Measure the current into the condenser to see if this is as per name plate,then check the gas charge
Nov 22, 2014 | Samsung AQV24VBE Vivace Wall Mounted...
My AC 1200BTU work in heating 5min. and than stopped
Check temp setting and also room sensor. Setting must be minimum 3 degree more than room temp. Check continuity for sensor. If open replace it. Check coil , air filter and heater element are cleaned.
If high amps, replace heating element. Thanks.
Feb 07, 2011 | LGLXA1230 Air Conditioner
Out door is not working
Check for communication from indoor to out door.Check power in out door unit. If not, check the following.
Keep cool mode and temp setting minimum 3 degree less than room temp.
Check indoor unit return air sensor. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace air sensor
Check Indoor Pipe Sensor Disconnect from PCB and measure resistance. Pipe sensor = 5kOhm at 25C. If not replace pipe sensor.
Thanks and hope helpful?
Feb 04, 2011 | LG LS-L1210CL Mini Split Air Conditioner
No cool and compressure not coming on
Please follow the steps one by one.
1.Check room sensor by ohms. ( Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor). 2. Keep cool mode and set temp minimum three degree less than room temp. 3. Wait for 3 minutes. Check compressor starts by sound. 4. Keep hand on discharge line near to compressor , is warm. Hope helpful. If still problem not solved, please write clearly what error code is there. Thanks.
Jan 27, 2011 | Mitsubishi Heating & Cooling
HI I ahve a MSH-07NV airconditioner. It has had this problem before. I called a repair man and he said it was operator error. It turns on remotely then the fan stops and it goes down to 1 light that flicks...
As you don't mention the error code. There are 2 reasons for your unit as hereunder.
Check your indoor room temp sensor and coil sensor
Indoor unit return air sensor fault. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor.
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor.
Jan 07, 2011 | Mitsubishi Heating & Cooling
Unit lights up when turned on but fan and compressor does not come on
If you can't operate by remote, try with touch screen in your unit to start.If still no start,
A/c unit room air sensor fault. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor.
Jan 06, 2011 | GE AEW08LN Air Conditioner
When I turn on ac, temp in room comes down, temp on machine reads 95F could problem be exhaust hose has some tears?
The temp sensor is located on the upper rear just behind the air filter. Slide the filter out and give it a cleaning. Look for a small wire visible. Inspect the temp sensor; it gets dusty.
If the hose was leaking you would feel the heat in the room.
Jul 09, 2010 | Danby DPAC120068 Air Conditioner
I get a E1 error code on my window ac unit. What
Indoor room temp sensor defective. Replace it.
May 26, 2010 | Haier hwr10xc6 Air Conditioner
Air conditioner turned itself on to 22 degrees.
If it got to 22 degrees the Ac unit should have self destructed. What brand and model is that unit?
I think I would love to have one here in Georgia.
Aug 21, 2009 | Royal Sovereign ARP-4012 Portable Air...
I want to put room temp on 30c but the default 24c
If you want the room at thirty C, it would appear you want the aircon to heat. To do this it would need to be a heatpump model which is capable of heating. If this is true, then it is a matter of changing the mode setting from cooling (default 24) to heating which would default at 30. Hope this helps. Look for a button with three or four icons, one should resemble an ice crystal (cooling) another should look like a radiating sun.
Jun 09, 2009 | LG Heating & Cooling
Gigabyte Ga H55m D2h Desktop Motherboard Intel Socket H Lga 1156 Multi Gpu Support Crossfirex (GBTH55MD2H Logo
47 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
