Question about Home Security
Coromaster mach 2 resetting limits
How do I short out the pushbutton and the common? Many thanks
Scotsman ice machine is not making ice goes through the motions but no ice
h=harvest 2=harvest problem 8=makes ice to fast 0=off.most common issue is your senors/ice mach needs to be descaled and clean
Feb 25, 2014 | Kitchen Appliances - Others
Coromaster garage door motors limits
When in doubt, Google it. If this gear attaches to a chain, it gets a little difficult to keep the chain in control. Usually parts like this are held in place by a set screw, requiring the correct allen wrench. Working this stuff up on a ladder is no fun.
Nov 24, 2013 | Building Materials
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
Jul 02, 2011 | 2003 Pontiac Sunfire
How to programme remote for coromaster 2000 garage motor
To re-program the open and close limits do the following: Ensure that the door is open at least a couple of feet. Press the reset button once or twice Short out pushbutton and common and hold until close limit and then release. Door should stop at your new close limit. Wait 5 seconds. Short out pushbutton and common and door will open. Hold the short until open limit and then release. Limits should now be set.
Jun 14, 2011 | GPS
I replaced hot surface ignitor. Furnace started working in short 2 minute intervals for a couple of hours then it stopped igniting and the purge fan stays on constantly. can anyone help me diagnose?
check flame sensor, clean with steel wool. turn power on and off to clear any faults on board, also with volt meter check for 24 volts at white(heat) and common(blue or a black wire) you should never loose voltage, some thermostats cause short cycling, also check for any manual reset limit switches
Nov 26, 2010 | Heating & Cooling
Where is the thermal fuse? Where can I get a replacement?
What you are talking about is a thermal limiter, they reset automatically, unless some problem remains. Bra wires or other metal gets into the burner, and shorts it.
There are 3 or 4 limiters in dryers. if you need to test them, pull the plug first. You can easily get electrocuted in there...
A MUCH more common problem is 1/2 of the 220 volt breaker trips and you cannot tell. Forcibly turn the breaker FULLY OFF, push hard...and back on, and try dryer again.
Oct 17, 2010 | Dryers
How do I reset my garage door opener. It is a Coromaster 2000 motor. The closing and opening setting are out and the motor only stops due to resistance.
The Coromaster 2000 does not operate off limit switches. It has a quarter-revolution optical pulse counter. To re-program the open and close limits do the following: Ensure that the door is open at least a couple of feet. Press the reset button once or twice Short out pushbutton and common and hold until close limit and then release. Door should stop at your new close limit. Wait 5 seconds. Short out pushbutton and common and door will open. Hold the short until open limit and then release. Limits should now be set.
Sep 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
The second hand on my luminox 8150 does not reset to 12 o'clock
Pull out crown to the first click. Push and hold pushbutton at 2 o'clock till the seconds hand reaches desired position. Push the crown back. You may need to operate pushbutton at 4 o'clock instead of pushbuttton at 2. Try both.
Rate me, please.
Mar 23, 2009 | Watches
Board does not start!!!
Try to reset cmos. You might have caused a short in the motherboard circuit and the cmos might just need to reset.
Thanks,
lolita
Nov 06, 2007 | Mach Speed Matrix P4MBMS Motherboard
Home Security Logo
27 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
