Question about HP Computers & Internet
My hp compaq tc4200 wont turn on.if i plug power cable it shows charging after few seconds it wont charge i removed battery but the problem still
    Novelist:
    Champion:
  • 233 Answers
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test your compaq tc4200 power supply with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Posted on Jan 10, 2013
  • 8 Answers
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
Posted on Apr 28, 2009
stif_NEC
  • 441 Answers
SOURCE: hp compaq nx7400 - battery died and power cord will not turn comp
If your system won't boot up with just the AC adapter connected, it means to say that there's a problem with the AC adapter or the motherboard of the computer. Basically, if the AC adapter or the motherboard is damaged, you won't get a charged battery. If there's another AC adapter that you can try your computer with then that will be great. If antoher AC adapter works, then you just have the AC adapter replaced. If a known AC adapter didn't work then you may need to consider replacing the motherboard of the computer.
Posted on May 07, 2009
  • 36 Answers
SOURCE: Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
Posted on May 23, 2009
  • 1043 Answers
SOURCE: Battery charging for few seconds before it stops
Either the electronics in the charger or the battery have failed. If you still have any warranty left on the laptop call Dell support and they will assist you in identifying which one has failed.
Posted on Sep 17, 2009
  • 37 Answers
SOURCE: hp compaq nx6310 wont turn on. When pressing power
it will either be the batery is no good, or adapter ot the port on your laptop
Posted on Feb 27, 2010
HOW TO CLEAR CMOS?
Most times you remove the CMOS battery your manual can be found on compaq website Manuals for HP Compaq tc4200 Tablet PC
May 26, 2014 | Compaq tc4200 Tablet PC
Its plug in but battery wont charge
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 28, 2012 | HP Compaq nc2400 Notebook
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
Hp compaq doesnt charge
I have the same problem with yours, what I did was, I just removed the battery at the back of the laptop then turn it off for at least 10 seconds then after that put your battery back, plug the power cable then turn it on again.
If you did the suggested above, then I would that your battery or your adapter might be defective.
Jun 28, 2011 | Computers & Internet
I have an hp compaq 6720s and my charge port light blinks rapidly, it wont let me charge my battery and the computer wont turn on when the battery is full any thoughts?
Usually a rapid blinking charge light is alerting you of a battery fault. Try taking the battery out, plugging your computer in, and turning it on (with the battery out). If it boots up, then your battery is to blame, call customer service right away and see about getting a new battery.
Mar 24, 2011 | HP Compaq 6720s Notebook
HP Compaq 6515b laptop: Diplay is blank, Few times it came back after some time, But now it is titally blank,
With an extensive use of the notebook,
some times notebook would store some static charges which
indeed will stop the notebook from powering up or charging
the battery. The procedure to remove this static charges from
the notebook is known as power drain. Performing a power
drain procedure will not effect any personal data or delete
any pictures from the hard drive on your notebook.
I recommend you use Power Drain procedure by following these
steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Dec 07, 2010 | HP Compaq 6515b Notebook
New battery will not charge, shuts down
have you tried connecting it up, leave it for say 8 hours and don't use, try it then?
Jan 31, 2010 | Compaq tc4200 Tablet PC
Ihave hp laptop model#ze4200 it wont boot nothing happens on pressing the on/off button. only the a/c charging ledflashes for a while and turns off after few seconds
Besides a really serious failure, there are a few things to try...Remove the laptop battery, then hold the power button down for 10 seconds. Plug the AC adapter in, and leave the battery out. If the laptop starts up, you could just have a battery issue.
Nov 16, 2009 | HP Compaq Motherboard
No power
As far as a reset button is concerned you can hold down the power button for a few seconds to turn the power off completely and then power it back up.
If your having power issues and you have a new power adapter thats known working you can try disconnecting the power take out the battery leave for a few seconds then re-insert plug in power and try again.
If this fails try starting just with battery power, if this fails try taking out the battery and attaching just the power adapter and starting up.
Also check that the battery is getting charged there should be a light on the notebook that tells wether its charging.
If this all fails you may have damaged the power adapters connection to the notebook when you bumped it. Hence the battery cannot get recharged to start up.
Let me know how you go.
Mar 23, 2009 | Compaq Presario V4000 Notebook
Battery is not charging
Let the battery go all the way dead. You may have to adjust the settings in your bios so that the laptop will stay on until the battery goes completely dead. Then charge the battery. Do this a few times if it does not fix the problem you do need a new battery.
Jan 21, 2008 | Compaq tc4200 Tablet PC
Computers & Internet Logo
107 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
