Question about Whirlpool GU2400XTP Built-in Dishwasher
Quiet partner III taking over 4 hrs to complete normal wash cycle
I have a quiet partner III model GU2200XTSB 2 that is over 2yrs old that all of a sudden is taking well over 4hrs to complete the normal wash cycle. I have read about the incoming water temp, and mine is at 130F degrees
  • 2 more comments
  • linbacm Jan 21, 2009
    I will check the draining.
    I ran it last night without the soak and scour option that is enabled by default just pressing the start button (normal wash) and it completed what seemed to be a normal time.
    One other thing I noticed is that the dishes are not fully dry when removing them after the completed wash.
  • linbacm Jan 23, 2009
    I am using the jet dry. It is on the lowest setting, I will turn it up.
    As for rinse water, I will check. Does it heat the water up hoter then what is being feed in?
    Thanks a bunch for your help.
  • linbacm Jan 28, 2009
    Things are back to normal; resolution was to increase incoming water temp, replaced drain hose (old was partially clogged) and read the owners manual. Increased the jet dry setting took care of the dishes not being fully dried.
    soak and scour adds 4hrs to was cycle.
    sanitize rinse add additional time because it increases the water temp.
    Thanks for all the help, now onto the drier problem :)
  • linbacm Feb 03, 2009
    I did not post the drier problem yet, broken snowmobile took priority
  • 640 Answers
Ok check how fast the water is draining,,might be a bit slow...onthejob
Posted on Jan 21, 2009
  • 1 more comment
  • onthethejob1
    onthethejob1 Jan 23, 2009
    are we using our jet dry,,maybe we need to turn it up a touch if your using it,,also check that last rinse water and make sure that hot,,,it help drys the dishes,,onthejob
  • onthethejob1
    onthethejob1 Jan 24, 2009
    the dishwasher will only he the water about 1 degree per mintue...
  • onthethejob1
    onthethejob1 Jan 28, 2009
    whats wrong with drier...is problem posted,,,
Whirlpool quiet partner II stops running or won't complete it's was cycle, sometimes is will wash for a few minutes and stop or it will stop before the water even starts to flow.
I had the same problem with my dishwasher. After hearing that the motherboard was the problem I decided to take a closer look. There were two capacitors (1000 microfarads, 6.3 volts) that looked a little suspect. The tops of capacitors should be flat...these looked like soda cans that had been left in the freezer. Got on eBay, located the capacitors for roughly $3 and $4 shipping, for approx total of $10. Soldered the two new capacitors into the motherboard and put it back together. As soon as I closed the door, the dishwasher started draining the water. When I ran a Normal cycle it completed successfully. Saved myself over $120!
Aug 02, 2013 | Whirlpool Gold Dishwasher with Quiet...
Whirlpool quiet partner 1 is suddenly loud
Dear Sir : please see the diagram attached.
May 08, 2012 | Whirlpool Dishwashers
My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Mar 12, 2010 | Whirlpool Dishwashers
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Not cleaning properly
Our Whirlpool Quiet Wash plus is 20+ years old and was on its way out the door because of erratic white residue, spotting, and film.  Nothing worked: vinegar, different soaps, more soap, less soap. Today I opened it up and started digging behind covers and checking the insides - multiple places were clogged with a soap/mineral film - ugly! I sprayed the insides with Restore 4 (a tile cleaner) and scraped and brushed and broke loose the hidden deposits. The only thing I didn't open was the sump pump - but now know how to do so. (thanks FixYa) Then I added about a 1/2 quart of vinegar and ran it full hot on the heavy wash cycle, added more vinegar between each cycle and let it dry.  It looks super inside - the gunk is gone.  I am now washing a load of glasses and am hoping for the best!
Feb 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
The most obvious failure would be the mechanical timer that is behind / part of the knob used to select the cycle.
But, you may want to inspect the heating element in the sump area -- some dishwashers will wait (and wait) for the water temp to come up high.
Good Luck!
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Whirlpool Quiet Partner II not washing or sensing.
I have a whirlpool quiet partner II and for some reason it does not drain the water out any more and I cannot figure out why....people say that it is the filter but that is unbelievably hard to get to and I cannot find any instructions online or paper work that tells how to break it down. If anyone has any insight please let me know
Nov 16, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner Doesn't finish cycle
FIX YA IS A JOKE I WOULD LIKE TO BURY THE ************** WHO CREATED IT!
Jul 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
1,348 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
