Question about Canon PowerShot A95 Digital Camera
Macro mode and date imprint
Macro mode does not seem to be working. When I choose Macro, there is no change in the ability to focus closer than when in normal mode.
This is not affected by use of the zoom lever. The camera was purchased in August, 2005. I seem to remember that Macro worked when I checked all the functions, but I seldom use this mode, so I don't know when it failed, or indeed if it ever did work properly!
Also, the icon for date imprinting on the image is grayed out and not selectable, yet the manual describes how to use this function thus indicating that it is a standard feature.
Thanks for your help.
In Macro mode, you have to hold the shutter release down halfway and hold it until the focusing system has time to work, then take picture.
Date/Time stamp on image only works in Postcard mode.
Posted on Jan 22, 2009
I have a Nikon L810,Just bought it,and I really can't get a pic in focus with the zoom taken right up to the object,it seems to go in and out of focus for a few sec'and then I click,and it's out of...
Are you in the macro mode? To focus on something closer than about 0.5 meters (1 ft 8 in) you have to be in the macro mode. This will let you get about 1 cm (0.4 in) from the subject. See page 57 of this manual:
Oct 22, 2013 | Cameras
How do i get a close up
That depends on the type of camera.
Many compact cameras have a macro mode, which allows the lens to focus much closer than normal.
With an interchangeable lens camera, one usually uses a macro lens which is designed to focus closer than non-macro lenses. One can also use extension tubes or bellows to put the lens farther away from the camera (which brings the focal plane closer). Another technique that works for many lenses is to reverse it (putting the lens on backward), though this requires a reverse adapter.
To get even closer, many cameras can be mounted onto a microscope.
Dec 23, 2010 | Cameras
Cannot figure out how to take good macro shot with new Tamron len
With an SLR you only get true macro focussing on a lens that has proper macro focussing abilities. Unfortunately in the photogaraphy world, there are a huge number of lenses which claim to have macro ability but are stretching the term far too much.
Strictly speaking, macro means that the lens is capable of producing images on the sensor which are the same size as the actual subject or even bigger, at life size this is described as 1:1 macro. Your Tamron lens is only capable of a maximum 1:3.7 "macro", and that's only at the 200mm zoom setting with the subject no closer than 45cm from the lens. By SLR zoom lens standards, that's actually pretty good, but if you want to go closer and get greater magnification you need to either use a supplementary close-up filter lens or for better optical quality use a set of extension rings. The trade off with close up filter lenses is poor image quality and usually plenty of colour fringing and with extension rings is that if you're using a 2x magnification at 200mm, your f5-ish maximum aperture at 200mm becomes a very dark f10.
The only way to get good macro results is to either use a proper (=expensive) macro lens and excellent lighting, or use extension rings plus a good ring flash unit. However you can improve your macro by investing in a more capable zoom lens with a closer minimum focus distance and a better aperture at the telephoto end of the range. This can be expensive, or you can pick up some very cheap 35mm film SLR lenses. Using an adapter will never allow you to achieve infinity focus on a Canon digital SLR but you can get a close focussing 200mm f3.8 very cheaply. The crop factor of your smaller sensor means it will have the same angle of view as a 310mm lens but the aperture will remain at f3.8. As Canon digital SLR's have the deepest body register (lens to sensor distance) of the current systems then you'll also have the effect of using it on an extension ring. The downside is that you'll have to use the lens in a totally manual mode as no information will be communicated to your camera body. By mounting the lens back to front using a reversing ring you can achieve some really stunning macro magnifications but then you need a tripod, powerful flash and absolutely no wind... There was also a Makinon 80-200mm zoom which sells for next to nothing on auction websites, but it had a macro collar which allowed it to achieve around half size macro (1:2).
Alternatively, if the Fuji still works and does the job just keep it in your camera bag ready for those types of shots. overall, that seems the easiest and best solution unless you really want to get heavily into macro shooting.
I hope that I've helped you, please ask more if there's anything unclear. I've tried to keep a very complicated subject as simple as possible. Please also take a moment to rate my answer.
Mar 05, 2010 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
The camera will not focus when I try to take up-close shots. Such as an eye. I would like to photograph just an eye but whenever I try to zoom or walk in close enough the camera refuses to focus, haha....
Normally the closest focus you can get is 1.6 ft at W and 3.0 ft at T. In Macro mode you can get down to 3.9 inches. In Super Macro mode you can get even closer.
To get into Macro mode, press the Flower button until the flower appears on the LCD. To get into Super Macro mode, keep pressing the Flower button until an S appears inside the flower.
For full details, refer to your manual. In my copy, it starts on page 56.
Feb 20, 2010 | Canon PowerShot S2 IS Digital Camera
Canon SX200 IS macro focus problem
I have the exact same problem, with macro, super macro, or manual focus. Sometimes the macro focus works so well that I can actually capture finger prints on a subject. Other times (most of the time) the focus in macro mode just does not work.
I have read in some forums that it may be related to the amount of light being used when in macro mode; although that doesn't seem to fix the problem for me, maybe that will help your solution. Could you try it out, ie. try macro mode with a brighter light source?
Jan 26, 2010 | Canon PowerShot SX 200 IS Digital Camera
Focus problems
There are two likely reasons for the blurry pictures. One possibility is, as you surmised, a slow shutter speed. Try mounting the camera on a tripod or other stable support. You might also try turning on the flash.
The other reason is focus, or lack thereof. You didn't specify what cameras you have, but if they're Coolpixes, they most likely have a close-up or macro mode that will allow the lens to focus closer. If you're using a DSLR, you will need some other way to focus closer. Macro lenses, extension tubes, and close-up filters are three ways of achieving this.
Jan 20, 2010 | Cameras
When zooming in for a close shot it will not focus
When using the tele, the closest you can be to a object is probably more that one meter. If you need to get closer you should switch to macro mode.
Oct 01, 2009 | Canon PowerShot SD850 IS Digital Camera
My Jazz JDC25 cannot take closeup pictures without blurring. Is there a button or switch for macro mode that I can't find. Can it even do closeups?
According to the specifications for the camera, the focus range is from 19.62 inches to infinity, so anything closer than this will be progressively more blurred, depending on the distance. The camera has no macro focus options. The specs also say that this is a 0.3MP camera with VGA (640x480) resolution. Unless this is strictly a camera intended for web graphics, its' uses are quite limited anyway and an upgrade may be worth considering. Most modern point and shoot digital cameras have excellent macro abilities at a very reasonable price. To me, this might be worth considering. I like the Olympus lenses for macro work in this catagory and there are several others worth considering as well- Canon, Nikon, Pentax, Sony and Panasonic all offer great options for close-up photography at reasonable prices.
Wish I could give you better news, but am guessing that camera is quite old.
Jul 14, 2009 | Jazz JDC25 Digital Camera
Can't use macro
Select Macro Mode - this is a fairly obvious first step but I’m always surprised by how many digital camera owners haven’t explored the shooting modes that their camera has. Macro mode is generally symbolized with a little flower and when selected it will tell your camera that you want to focus on a subject closer to your lens than normal (the minimum distance allowed will vary from camera to camera - consult your instruction manual to find yours). Macro mode will also usually tell your camera to choose a large aperture so that your subject is in focus but the background is not.
Read more:
Jul 07, 2009 | Cameras
Your camera has the ability to shoot Macro and Super Macro, although in some Dial Modes, you can't use Macro.
To engage the Macro mode, press once the button on the left side of the lens/camera that looks like a Flower. To engage the Super Macro mode, press and hold the same button for more than one second.
Macro mode range 3.9 in. - 1.6 ft
Super Macro mode range is 0 in. - 3.9 in.
To cancel Macro mode, press the Flower icon button once.
Zoom levels are limited, and you will know that when the zoom bar turns yellow. This means the zoom is not available at that zoom level.
Hope this helps.
Nov 24, 2007 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot A95 Digital Camera Logo
63 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
