Sorry B.H. Countryman, trying respond I pressed inappropriate by mistake. First time using this app. Here is the model number. Thanks again
    Sergeant:
  • 291 Answers
Your
machine is newer than my machines. However only the agitator,
coupling and basket look much different. The transmission has a
different shape but otherwise looks the same with the exception of a
pair of wires.
Unplug
the machine.
Open
the loading door and see if the agitator spins. If agitator turns
freely in both directions and tub sits motionless either your
agitator or the coupling that holds it to the transmission is shot.
Usually the coupling. If it spins you found the problem. But if it
doesn\'t spin...
The
panel on the front of your machine is easy to remove. From either
edge slide a putty knife inserted about 3/4" along the top edge of
the panel. About 4" from the edge you will come into contact with a
clip. Remove the putty knife and insert where the clip is. Push in a
little and you should feel a springy resistance. Push in harder and
you will lift the clip past a cut-out notch at the top of the panel.
If you push till the blade comes to a stop you should be able to put
your fingers on the top corner of the panel and give it a slight tug
to free it. Don\'t pull too hard just enough to clear the clip. Then
repeat procedure on other corner. Once it pops open set it aside but
prop it up with something. When they fall over they sound like a gun
going off the way they slap the floor. Do your heart a favor.
You\'ll
need a flashlight. See any water? There should be none. There is a
floor in your machine, not all machines have those. See how the tub
is suspended there? That\'s kind of cool. Everything looks pretty easy
to get to. Not that complicated really. There is a motor right out
front bolted to a platform that is bolted to the tub. On the floor to
the right of the motor is the drain pump.
For
now let\'s look at the drive belt. If you shine your light toward the
middle of the machine under the tub behind the motor you should see
the transmission bolted to the platform. My transmissions don\'t have
two wires coming from them, yours does. I can\'t tell you where those
wires go or even what they are for but make sure the connector is
well seated wherever it goes. If it\'s not plugged in or seated
properly you may have discovered your problem. You have to get down
low to see the belt. It is under that platform and it goes from a
pulley on the motor to a pulley on the transmission. If you see oil
on it you will probably see a line of oil that has been slinging
around in there that goes all the way around the inside walls of your
machines outer shell. It came from and means you need a new
transmission. If it\'s not oily the drive belt should be dry and not
cracked. It should be pretty tight but not tight-rope tight. If it\'s
bad it will need to be replaced. But I don\'t think it is your
problem. It may look a little rough around the edges with a few
cracks in it, but hopefully it\'s dry and still fairly snug. Again,
if it\'s in sad shape put one on the list, it\'ll need replaced, but
I\'ve seen some belts in bad shape that continued to function. We\'d
have to see it in action to tell for sure. The only way to do that is
to plug the machine back in and start it up.
But
first, let\'s agree that when the machine is operating we won\'t go
proddin\' and pokin\' at it. Nor will we reach inside the cabinet for
any reason with our hands or head. There will be moving parts and HOT
Electricity, so let\'s be extra careful and extra aware. Okay?
Okay.
So this is another one of the places where things get a little
different for us. My machines are commercial machines with coin
mechanisms and money boxes that sit in a housing that hides the timer
and lid switch as well. Your timer is housed behind the backsplash of
the control panel and almost certainly more complicated than my
timer. But it should function basically the same. Yours will have a
knob with marks on it that indicate cycles and their lengths, mine
doesn\'t. So just set everything to Normal Wash (or whatever it says)
and pull the control knob out (or whatever you do to start the
thing.)
Water
should begin entering the tub. Because the tub is plastic we can see
the water line begin to rise inside it. This machine is designed not
to agitate unless it\'s full of water. Since we know the drain pump is
good we could continue filling it and wait for the agitation cycle to
kick-in. But we aren\'t going to do that, yet.
Just
as the machine will not agitate without a full tub, it will not spin
unless it\'s empty. Both of these functions are controlled by the
pressure switch. The pressure switch is behind the backsplash of the
control panel. They seldom fail and can give a shock if touched wrong
while the machine is plugged in so leave it alone for now. You can
see the hose or tubing that leads to the pressure switch over on the
left side of the tub. It actually connects to the tub via a small
squarish box that protrudes from the side of the lower part of the
tub. You can see water in there if you look, even with the tub empty.
With a good light you can see that there are a couple of little
compartments in there and the water is probably contained within
those compartments. If you look really close you might see that there
are two smaller-than-a-dime sized holes on the tub side within the
compartments. Those holes allow water to enter the box at a rate
commensurate to the filling of the tub. As the box fills (it doesn\'t
fill much) it creates pressure that pushes a diaphragm that closes or
opens a switch (the pressure switch) that sends a signal to the motor
to spin in the direction of agitation. The timer controls the length
of agitation.
Generally
a failed pressure switch will make itself evident by a tub that
overflows. Even then, it is usually not the pressure switch that has
failed. Most pressure switch "failures" are caused by either the
pressure switch hose becoming blocked, loose, or completely
dislodged. The hose can also develop wear spots, because if not
properly adjusted it has a tendency to kind of saw back and forth on
these models. However the hose is really a very flexible thick walled
tubing that can take a lot of abuse. I\'ve never had to replace one
and I\'ve seen some pretty badly worn pressure switch tubing. Also
that sawing motion can usually be fixed by slight adjustments in the
positioning of the tubing; a slight tug here or there and maybe a
twist where it connects to the tub for example. Personally I don\'t
think the pressure switch is causing your problem but it is possible
so let\'s check.
First
open the lid so the machine can\'t agitate or spin. When the water
level is about an inch above the top row of drain holes in the
loading basket the pressure switch is designed to trigger. So we want
the water level close to that but just below the holes is fine too.
You can shut off the water at that point and unplug the machine to be
safe. Now remove the hose from the box. The box has a nipple the hose
slides over so pinch there and pull straight up. You may have to get
a good hold on it and give it a little twist as you pull. It will
come off quick and sudden so take care not to bang your hand up and
be aware that there is sharp metal around. After it comes off I
always stick it back on then pull it off again just to get the feel
for it and to make sure it still feels tight. When you remove the
hose the water level in the box should begin to rise. Depending on
the depth of the water in the tub it will rise either very slowly or
fairly rapidly. If you put your finger over the hole it will stop
rising. If you remove your finger the water level should rise
steadily to the top of the box and squirt a 4" high stream of
water. If it does, put the tube back on. If we were doing this with
the machine running and still filling we\'d need to stop the filling
manually. It will not stop filling on it\'s own at this point.
If
it doesn\'t shoot a stream of water you need to ream out the nipple in
the top of the box with a paperclip or piece of wire. It\'s a super
simple procedure that should probably only need to be done once or
twice in the entire lifetime of the machine. Don\'t worry about the
water, the floor in the bottom of the machine will contain what
little there is. Once it\'s flowing replace the tubing. Again you
would have to stop the fill manually if water was still running. Now
plug the machine back in, close the lid, set it to drain and restart.
Remove the hose when the tub is about empty so the box drains to
it\'s idle level. Stop the machine when the tub is empty.
Okay
one more pressure switch test and we\'re done. With the box drained to
it\'s idle level, the tub empty and the machine off, pull the hose
off the box. If you blow very lightly into that hose you will feel
the diaphragm in the pressure switch move. Don\'t blow hard, it could
mess it up. Try it a couple of times. It just takes a little bit of a
breath and you will feel it mostly, if it\'s real quiet you may hear
it as well. You may have to pull on the hose a little to get it past
the outside of the machine so your head is not in the cabinet. That
whole tub assembly is going to move suddenly an solidly and we want
no body parts near it when it does. If you are satisfied you can do
so safely, without your head in the cabinet, let\'s see if we can make
the machine agitate. Close the lid. Turn the dial to start a normal
wash and restart. Don\'t worry about the box on the side we\'ll be done
before the water in it even begins to rise. With water entering the
tub hold the tube with your left hand and place your right hand on
top of the machine. Very lightly blow into it just as you did
earlier. When you feel the diaphragm do it\'s thing the machine should
begin to agitate or spin. As soon as you can tell whether it is
agitating or spinning stop blowing and place the hose back on the box
you are done. Go ahead and stop the machine. It was supposed to
agitate. If it spun you probably need a new transmission. If it
agitated you probably need a new timer. Let me know.
Posted on Jan 09, 2013
  • B.H. Countryman Jan 09, 2013
    After taking another look at the basket full probably isn't an inch above the top row of holes on your machine. Likely that would be over full.
All of my apps on my iPhone won't open even after i have reset the phone and powered it down how do i fix it
iOS An app you installed unexpectedly quits stops responding or wont open
iOS: An app you installed unexpectedly quits, stops responding, or won't open Learn what to do if an app you downloaded from the App Store on your iPhone, iPad, or iPod touch unexpectedly quits, stops responding, or won't open.
Follow the steps below and test the app after each step.
Restart the app Close the app and open it again. Restart your device Turn the device off and on. Update your device software and your apps Update your device to the latest version of iOS.
Update your apps:
  1. Open the App Store and tap Updates.
  2. If updates are available, tap Update All.
  3. If asked, enter your Apple ID password. The updates will download and install.
You might need a Wi-Fi connection to update some apps. Install another app from the App Store If your installed app won't open, download and install a free app that isn't on your iOS device. This should reset your Apple ID authorization.
Remember to use the same Apple ID that you used to download the app that you're having issues with. Reinstall the app Remove the app from your device and reinstall it. Remember that deleting an app also deletes its data.
  1. Delete the app.
  2. Press the Home button.
  3. Go to the App Store and download the app again.
  4. Wait for the app to download, then open it from the Home screen.
If the download stops, you can resume it. Contact the developer If you see the issue again, contact the developer of the app for help:
  1. Find the app in the App Store.
  2. Tap the app and tap Reviews.
  3. Tap App Support.
Information about products not manufactured by Apple, or independent websites not controlled or tested by Apple, is provided without recommendation or endorsement. Apple assumes no responsibility with regard to the selection, performance, or use of third-party websites or products. Apple makes no representations regarding third-party website accuracy or reliability. Risks are inherent in the use of the Internet. Contact the vendor for additional information.
Last Modified: Nov 14, 2014
Apple Customer Phone Number Shortest Wait Best Support
Jan 12, 2015 | Apple iPhone 5c
How to set the digital clock pls
Without your model number this is a GENERIC answer that is applicable to MOST microwave ovens.
1. Press Stop//Pause
2. Press Clock
3. Set Time
4. Press Clock
Time is now set and the Microwave is ready for use.
If this does not work.. I need you to respond with your model number to look up your exact steps.
Thanks for choosing FixYa,
Kelly
Sep 13, 2011 | Microwave Ovens
It is blocking me
One reason why your account might have been blocked is Skout service are looking into all accounts and deleting all user under 18 years of age. Many users set their age to 18, and so account is deleted. Another reason for blocked or deleted accounts is if you are posting inappropriate content to skout site. If none of these reasons apply to you,Kindly email support@skout.com and someone will assist you with your problem ASAP.
Sincerely, Thiyaga
Aug 31, 2011 | Skout DatingA Singles Network
How do I get an Appeal to Skout to get back in the Chat Room? There may have been unknowingly inappropiate language used but that situation has been solved. Now, what procedure do I use to get back into...
If this works and helpful, please give a testimonial and vote by pressing button four thumbs up icon.
Sincerely, Thiyaga
Aug 22, 2011 | Skout Flurv FlirtingA Singles Facebook for...
How do I change the company name that's displayed on the top of the page of a fax??? It's a Canon Faxphone B740.
On the right hand key pad
1). Press Function
2). Press 01 (data registration
3). Press set twice
Display the tel number, change if that is wrong
4). Press set twice again
Enter the company name (unit name)
Use the numeric keys-max 24 characters
if you have otehr problem, please to to the following link and download the users manual.
http://www.usa.canon.com/cpr/pdf/Manuals/B740CanonUserManual3-13.pdf
May 22, 2009 | Canon FAXPHONE B740 Plain Paper Bubblejet
In samsung mobile how to remove the number from reject list?
fallow these staps
satting- application satting - call - all call - auto reject - reject list-
click option and remove number from reject list
May 04, 2009 | Samsung SGH-J600 Cellular Phone
Why are your retarded? No simple answer there?
what is wrong here is you asked for a model and manufacturer of an item that only you know what it is
it is up to the person asking the question to clearly understand that the responsibility to get a good answer lies with them as fixya site crystal balls are broken
It it was marked as inappropriate , it is wrong --it should have been marked as irrelevant
If you care to read the questions being asked and the natrocious spelling and grammar with a total lack of detail posted you will understand fixya site experts in trying to answer
Mar 07, 2017 | HP OfficeJet 6110 All-In-One InkJet...
A little more info on our poblem
The problem may be resolved by placing a 330 PF capacitor across the mic's two input lines. With countryman you cannot access the mic capsule easliy so it is best to take the TA5F connector apart,( this would be the connector that plugs into the beltpack) and place the capacitor across the two lines. LECTROSONICS.COM has the capacitors and a wiring diagram to help solve this. The part number for the capacitor is SCC330P
Good Luck!
Dale Robertson
Mar 31, 2008 | Countryman ISOMAX E6i (E6IOW5BC2)...
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
