Question about Craftsman 10" Table Saw
How to change blade on 10" Craftsman table saw?
How do I change the blade on a 10" Craftsman table saw?
  • 3 more comments
  • Anonymous Mar 16, 2014
    how toinstall the front and rear fence guides on a craftsman table saw 113 298051
  • Anonymous Mar 23, 2014
    which to turn hex nut to remove blade
  • Anonymous Mar 24, 2014
    blade tilts during use
  • Anonymous Mar 26, 2014
    I have had this saw for many years. Today is the first time I have tried to do a bevel cut. The wheel on the side of the saw turns, but the blade does not move. Help please.
  • Anonymous Mar 28, 2014
    I have a craftsman table saw mod 137218251 and I am trying to find a manual free for it
  • 80 Answers
You need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
New to table saw use, have my husbands old 10 craftsman, was learning to rip with it doing fine, then it started to bog down during cut until the blades stops, moving. put on a new blade and noticed...
If I understood correctly, you started using your husband's table saw and while ripping boards, you managed to stall out the blade AND motor?! If that's the case, you probably have a very dull blade and are binding your board on the blade. Neither is safe and it sounds like trouble is brewing.
First and foremost, get someone to show you how to safely and properly use and adjust the saw if you are new to wood working and power tools. That saw is capable of turning your lumber into a high speed missal if you do things improperly.
It also sounds like you tried installing a new 10" saw blade. Changing the blade requires 2 wrenches. One to hold the arbor and one to tighten the nut. The blade itself should rest on the arbor between two large washers. Also make sure you install the blade so the front face of the cutter teeth face you and rotate toward you. Make sure the saw is unplugged when changing the blade and never turn on your saw with a loose blade.
Oct 20, 2013 | Craftsman 10" Table Saw
10 inch table saw blade not square with table
Sounds like the bolts that hold the motor assembly on the table may be loose allowing the blade assembly to move. Look underneath the table and clean out all the dirt and loosen all the hold down bolts and realign the blade and tighten back up.
Oct 25, 2011 | Craftsman 10" Table Saw
Adjusting the saw blade for exactly 90 degrees on an old craftsman 10 " radial saw
If the saw is adjustable for angle we usually use an engineers square against the blade to get it upright and then you may find an adjustable stop or stops somewhere so you can set the position ready for the next time you need to set it.
Jun 03, 2010 | Craftsman 10" Table Saw
Problem with 10" craftsman table saw
Your adjustment should be done on the rip fence which will align it to the blade for strait non binding cuts.
May 11, 2010 | Craftsman 10" Table Saw
Replacement blade
Use a 10" blade. As for the number of teeth...the more teeth the finer the cut will be. The only drawback is a a finer toothed blade will cut slow. For your purposes I'd suggest a fine toothed blade.
Mar 07, 2010 | Craftsman 10" Table Saw
Craftsman model 708100 table saw tilt lock won't stay locked
Try removing the lock knob and putting a toothed lockwasher on the shaft. reinstall the knob.
Dec 11, 2009 | Craftsman 10" Table Saw
Key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Sep 14, 2009 | Craftsman 10" Table Saw
I need to change the blade on my 10 in. tabel saw,
OK. first of all unplug it. Then remove the plate that surrounds the blade. Wrenches came with the saw so hopefully you still have them.
You need two special wrenches which are sold at any sears hardware store if you don't have a set. The only thing to remember is that the outer nut has reverse threads so turn it clockwise to loosen it and counter clockwise to tighten it. Note the direction the saw teeth point in and duplicate that with the new blade.
Get back if you have any other questions.
May 03, 2009 | Craftsman 10" Table Saw
Craftsman 10" Table Saw Logo
1,509 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
